Jaap Frank <jjf### [at] casemanl> wrote:
> Because triangles are not solid objects but surfaces only, you can't carve
> something out of it.
No primitive in POV-Ray is solid. Everything is just a surface.
What "solid" means in terms of CSG is that some points can be defined
to be "outside" the surface and others "inside" it. Thus "closed surface"
would be a much more accurate term than "solid".
The problem with eg. the triangle primitive is that it's not a closed
surface, but on open one. Thus it can't have a defined interior (ie. there
aren't points which can be said to be "inside" a triangle).
OTOH, a closed triangle mesh can be defined as being "solid" because
POV-Ray can determine whether a point is inside this closed mesh or not.
This can be done by using the inside_vector feature of meshes.
Patrick Elliott nous apporta ses lumieres en ce 2008/03/01 23:31:
> To be more specific. This is what it looks like, when everything is
> where is supposed to be, except the fill in for the sides:
> camera{
> orthographic
> location <0,0,-3> look_at <0,0,0> angle 60
> right x up y
> light_source{<5,5,-10>,1.5}
> #declare octaside =
> //intersection {
> union {
> sphere {<-1,0,0>,0.075}
> sphere {<1,0,0>,0.075}
> sphere {<0,sqrt(2),0>,0.075}
> cylinder {<-1,0,0>,<1,0,0>,0.075}
> cylinder {<0,sqrt(2),0>,<1,0,0>,0.075}
> cylinder {<-1,0,0>,<0,sqrt(2),0>,0.075}
> texture {
> pigment {rgb <1,1,1>}
> //triangle {<-1,0,-0.075>,<0,sqrt(2),-0.075>,<1,0,-0.075>}
> //triangle {<-1,0,0.075>,<0,sqrt(2),0.075>,<1,0,0.075>}
> rotate <45,0,0> // test purposes, move to last statement in final
> object, with translate.
> translate <0,0,-1>
> // box {<-1,0,-0.075>,<1,sqrt(2),0.075>}
> union {
> object {octaside}
> object {octaside
> rotate <0,90,0>}
> object {octaside
> rotate <0,180,0>}
> object {octaside
> rotate <0,270,0>}
> union {
> object {octaside}
> object {octaside
> rotate <0,90,0>}
> object {octaside
> rotate <0,180,0>}
> object {octaside
> rotate <0,270,0>}
> rotate <0,0,180>
> rotate <0,10,0>
As it is now, you construct a single face with 3 spheres, 3 cylinders, a visible
triangle, and an other triangle that will never show.
You then combine eight of those to form the complete shape, with 4 spheres at
each summits and 2 sylinders at each edges, resulting in many coincident surfaces.
Triangles are only single faces objects with no inside.
You can create your octaedron from the intersection of 8 planes.
#declare SQ = sqrt(2);
intersection{plane{<0,1,SQ>,1}
plane{<0,1,SQ>,1 rotate 90*y}
plane{<0,1,SQ>,1 rotate 180*y}
plane{<0,1,SQ>,1 rotate 270*y}
plane{<0,-1,SQ>,1}
plane{<0,-1,SQ>,1 rotate<0,90,0>}
plane{<0,-1,SQ>,1 rotate<0,180,0>}
plane{<0,-1,SQ>,1 rotate<0,270,0>}
This give you an octaedron with sharp edges. You can then chop those edges using
12 aditional planes. Now, add in an union the spheres and cylinders to create
the rounded edges. Only add a single sphere per summit and a single sylinder per
edge.
If you want it to be transparent, use a merge instead of an union.
Laughter is the shortest distance between two people.
In article <47ca860c@news.povray.org>, jjf### [at] casemanl says...
> > camera{
> > orthographic
> > rotate <0,0,180>
> > rotate <0,10,0>
e
> If you use prisms instead, you get something solid.
> Manual: 3.4.1.8 Prism.
> Succes,
> Jaap
Ah. Right. Didn't think about that one. lol Thanks.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
In article <47caee36$1@news.povray.org>, ele### [at] netscapenet
says...
> > camera{
> > orthographic
> > right x up y
> > #declare octaside =
> > //intersection {
> > union {
> > texture {
> > translate <0,0,-1>
> > union {
> > object {octaside}
> > object {octaside
> > rotate <0,90,0>}
> > object {octaside
> > rotate <0,180,0>}
> > object {octaside
> > rotate <0,270,0>}
> > union {
> > object {octaside}
> > object {octaside
> > rotate <0,90,0>}
> > object {octaside
> > rotate <0,180,0>}
> > object {octaside
> > rotate <0,270,0>}
> > rotate <0,0,180>
> > rotate <0,10,0>
visible
s at
surfaces.
> plane{<0,-1,SQ>,1}
s using
eate
der per
> edge.
I started trying to use the shapes2.inc octahedron. The problem is,
chopping bits off of arbitrarily shaped objects is a pain in the ass.
lol
Note, I am also an idiot. Moving the triangles up above the texture gave
me a surface, but not a solid. Where they are now they generate an
error. Jaap Frank has suggested a prism, so I will try that.
I really wish there was a built in way to define, or at least convert,
boxes into the same format as cylinders though, i.e.:
altbox {<endpoint1>,<endpoint2>,base_width}
It would make things a whole damn lot easier to set arbitrary points for
where its supposed to "touch", rather than the corners, some times. Its
what always bugged me about Moray too, since the precision in that never
matched what POVRay could do, it was often literally impossible to make
exact matches to where you wanted things, since there was no clear way
to tell it, "Put this end here, and the other end there!" Sure, the
precision would still be slightly off for a box using the above too, and
more computation would have to be done to position it, but at least I
wouldn't have to be the one **doing** the computation myself. Making
everything a unit size and in a specific position, then having to scale
and rotate it, like Moray... just takes what could be a simple matter of
scratching a few things on a note pad for an idea, then entering the
numbers, and turns it into a crash course on math I forgot 15 years ago,
or never took in the first place. :(
Hmm. looks like yours will produce the same basic "shape" that I am
working with anyway, so for the crystal version it would be quite
helpful. Planes to clip it.. Not even sure how to manage that, but I can
probable figure it out. Figuring out how to shave the bits off I don't
need though is usually the single biggest pain. That is why I tried to
find a solution that would let me do *one* side, then duplicate it,
rather than trying to shave all of them. Its really not practical to use
anything but a flat surface to cut off the parts that will stick out
past the cylinders, but, while this shape isn't that bad, see the above
box comment for why its often a complete pain in the ass. ;) lol
In any case, the main goal was to just make something I could carve into
and I might not do a crystal one anyway, so I may not need such a
complete solution. Nice to have one though, if I decide to go that way.
void main () {
else
Attempted a compromise solution. Using the prism to "fill" the gaps,
then the planes to "fill", with proper scaling, the hole inside. This is
the resulting scene:
camera{
orthographic
location <2,2,-3> look_at <0,0,0> angle 60
right x up y
#include "textures.inc"
light_source{<4,4,-9>,1.5}
#declare octaside =
merge {
prism {0,-0.075,3,<-1,0>,<0,sqrt(2)>,<1,0>}
rotate <45,0,0>
translate <0,0,-1>
#declare roundocta =
merge {
object {octaside}
object {octaside
rotate <0,90,0>}
object {octaside
rotate <0,180,0>}
object {octaside
rotate <0,270,0>}
union {
object {octaside}
object {octaside
rotate <0,90,0>}
object {octaside
rotate <0,180,0>}
object {octaside
rotate <0,270,0>}
rotate <0,0,180>
plane{<0,-1,SQ>,1}
scale <.85,.6,.85>
object {roundocta
pigment {rgbt <1,1,1,1>}
interior {ior 1.45
fade_distance 2
fade_power 2
caustics 2.0}
rotate <0,10,0>
plane {z, 1.7
texture{pigment{rgb <1,1,1>}}
plane {-y, 1.7
texture{Jade}
plane {-x, 1.7
texture{pigment{rgb <1,0,0>}}
Something just doesn't seem right about the result. Without caustics, or
viewed from a different angle, it looks even worse imho, and I am not
entirely sure what the problem is... Well, other than the obvious
possibility that his hack job is producing gaps I don't see when simply
clipping half the object off, to look for them, or coincident surfaces.
I kind of don't get why the plane based geometry isn't quite a correct
match either. I specifically picked the points as I did to give a
specific "known" triangle between the meridian, the top and 0,0,0, so I
would be sure the spheres and other things lined up where they needed
to, and I am not scaling anything, so in theory, the points where the
intersecting planes meet *should* be the same shape as what I
produced... Sigh... I have no clue what I am doing, do I? lol
void main () {
else
Warp napsal(a):
well, umm, thanks. And remember the sun doesn't move. But that doesn't
stop us from saying it does. I often say the sun has moved behind the
even though there is no such thing as a horizon and the doesn't move at
all (well, it does). It is because the result is the same (up to some
feeble effects).
By saying "a sphere is solid" i imply "with respect to the context" and
I mean "a sphere behaves just like it was solid" i.e. "you can do CSG
with spheres". (actually, the sphere *doesn't* behave, it has no brain).
What I'm trying to say, people often describe what do objects do
(interface) rather than how do they do it (implementation).
Your comment would be appropriate as a response to someone claiming the
raytracer considers the whole object interior when raytracing it. IMO
your comment is inappropriate here I don't mean to be rude, I simply
find it strange that you defend something that's not being denied. If
not inappropriate, your comment is not very hepful (neither is mine, I
admit)
You know you've been raytracing too long when...
you ever saw a beautiful scenerey and regretted not to take your 6"
reflective ball and a digital camera, thinking "this would have been a
perfect light probe"
-Johnny D
You can use Reorient_Trans() from transforms.inc and VDist() from
math.inc to align the box and a vector average (p1+p2)/2 to position it.
Not that tough.
-Johnny D
"Jan Dvorak" <jan### [at] centrumcz> schreef in bericht
news:47cb13c8$1@news.povray.org...
> Warp napsal(a):
>>> carve something out of it.
>> there
> stop us from saying it does. I often say the sun has moved behind the even
> though there is no such thing as a horizon and the doesn't move at all
> (well, it does). It is because the result is the same (up to some feeble
> effects).
> By saying "a sphere is solid" i imply "with respect to the context" and I
> mean "a sphere behaves just like it was solid" i.e. "you can do CSG with
> raytracer considers the whole object interior when raytracing it. IMO your
> comment is inappropriate here I don't mean to be rude, I simply find it
> strange that you defend something that's not being denied. If not
> inappropriate, your comment is not very hepful (neither is mine, I admit)
> -Johnny D
What Warp means, I think, is that you can make a 'solid' octahedron
by placing eight triangles between the points
<1,0,0>,<-1,0,0>,<0,1,0>,<0,-1,0>,<0,0,1>,<0,0,-1>.
It's a closed object, so you now can treat it as a 'solid', given an inside
vector. You can use this object in CSG. I hadn't thought about that.
Nevertheless Patrick wants rounded edges, so there is some more work to do.
Maybe he can start with this object and figure out how deep he has to cut
off the rims and points to put his spheres and cylinders for the rounded
edges. That's not easy, for this has to be so deep that the newly formed
stripes have precisely the right width.
At the moment I don't see how to calculate this.
Patrick,
I think you forgot that prisms are made along the Y-axis and you
define the points in the X-Z-plane. Later you have to rotate the prism.
If you use your selfmade rounded triangle eight times, then all edges are
double and all angelar points are quadruple so you get coincident surfaces
and weird errors in your surfaces.
I think the best way is to make eight different rounded triangles the
way you did and omit the parts that are not needed: make a drawing of
the beast and put it then together.
Maybe you can use conic_sweep to make pyramids with a summit that
will meet all other pyramids in the center of the octahedron, but I'm not
sure about this, for I have never used conic_sweep before and the
manual is not clear about this.
If you make a 3D-drawing with the points I gave, you will see what I
mean (I hope :) ).
Success,
Jaap
Patrick Elliott napsal(a):
> Decided to rework the design of the octahedron, so that it *should*
> allow me to do this:
> #declare octoside = {blah}
> union {
> object {octoside
> rotate <0,90,0>}
> and get the result I want. The problem is, this is as far as I got:
> camera{
> orthographic
> location <0,sqrt(2)/2,-3> look_at <0,sqrt(2)/2,0> angle 60
> right x up y
> //intersection {
> union {
> texture {
> //rotate <45,0,0> <- test purposes, move to last statement in final
> //translate <0,0,-1>
> Neeless to say, since the original used intersection, I took a chance on
> that working. It didn't. The **best** solution would be if I could tie
> triangles to the center points and weld them to the main object, to
> produce a solid, or at least one solid enough to cut sections out of and
> have material left behind, instead of a hollow shell with a hole in it.
> It only get worse if I want to late make a crystal version, or some
> other such thing, where the entire inside has to be solid, instead of it
> being hollow. There has got to be some means I can fill in the sides,
> like I want, and also the rest of the interior of the final object. I am
> just not seeing it at the moment. And, if its something blindingly
> obvious, like using triangles some how, then I can even set the exact
> points I want, instead of using the 45 degree angle trick and computing
> the sqrt(2) length for the side being rotated into place. Can't imaging
> why I didn't try something like this before... lol Might have been
> easier to model this bloody thing as a patch.
When I think about it now, wouldn't it be possible to use a superellipsoid?
-Johnny D
The center's a bit off, but this should work if
you don't cut it too deep.
#local A = <-1,0,0>;
#local B = <1,0,0>;
#local C = <0,sqrt(2),0>;
#local D = <0,0,1>;
#local RAD = 0.075;
#declare tetra = mesh {
triangle {A,B,C}
triangle {B,C,D}
triangle {C,D,A}
triangle {D,A,B}
inside_vector (A+B+C+D)/4
translate <0,0,-RAD>
#declare octaside = union {
sphere {A,RAD}
sphere {B,RAD}
sphere {C,RAD}
cylinder {A,B,RAD}
cylinder {C,B,RAD}
cylinder {A,C,RAD}
object{tetra}
rotate <45,0,0>
translate <0,0,-1>
#declare pyramid = union {
object {octaside}
object {octaside rotate <0,90,0>}
object {octaside rotate <0,180,0>}
object {octaside rotate <0,270,0>}
#declare octagon = union {
object {pyramid}
object {pyramid rotate <180,0,0>}
