POV-Ray : Newsgroups : povray.advanced-users : HDR and brightness Server Time
29 Apr 2024 05:24:33 EDT (-0400)
  HDR and brightness (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: HDR and brightness
Date: 23 Feb 2018 08:01:42
Message: <5a9010b6@news.povray.org>
Le 18-02-22 à 18:51, Mike Horvath a écrit :
> Can I achieve the same brightness using an HDRI sky as using a light
> source? Or are there limits on how bright a scene can be?
> Mike
Yes. In fact, an HDRI sky can be TO bright, leading in an image that is
over exposed like.
For that to work, you need to use radiosity.
Next, you can apply the HDRI to a sky_sphere or a very large sphere
enclosing the scene.
In the case of the world sphere, it need a finish similar to :
finish{
  diffuse 0
  emission 1
If the scene is to dark, you increase the emission value, and reduce it
if it's to bright.
Date: 23 Feb 2018 13:20:00
Message: <web.5a905ac0b63c42a4a47873e10@news.povray.org>
I haven't yet used an HDRI image/image_map in a scene, but I would assume that
the maximum rendered brightness on-screen would be clipped to 1.0 (typical
maximum white)-- or rather, as bright as your monitor can reproduce 1.0, just
like with any scene.
The saved file is another matter, if it's saved as HDRI. (POV-Ray can do that,
right? I haven't read the documentation enough to know.)
Date: 23 Feb 2018 13:30:30
Message: <5a905dc6$1@news.povray.org>
Am 23.02.2018 um 00:51 schrieb Mike Horvath:
Technically, that depends on the HDRI file format used.
In POV-Ray, light source brightness is stored internally using so-called
"single precision" floating point values; these can range as high as ca.
3.4*10^38.
The Radiance HDR file format uses a proprietary floating point-ish
format with values ranging as high as ca. 1.7*10^38, so not much
difference there.
OpenEXR files are usually stored using "half precision" floating point
values; these can range no higher than 65504 (ca. 6*10^4). However,
OpenEXR can also use "single precision" floating point values as an
alternative. (It even allows for the use of "double precision" floating
point values, which can range as high as ca. 1.8*10^308, but POV-Ray
would limit them internally to single precision.)
In practice, I don't expect the limitations of standard (half precision)
OpenEXR to be of any significance except in fringe cases, such as trying
to model a very bright point-like light source.
Date: 23 Feb 2018 21:50:30
Message: <5a90d2f6@news.povray.org>
Yes, you can save as high dyamic range image. Just need to add +fe
(*.exr) or +fh (*.hdr) to the command line. Then, there is no clipping.
Date: 24 Feb 2018 06:08:52
Message: <5a9147c4$1@news.povray.org>
>> assume that
>> (typical
>> 1.0, just
>> do that,
I wonder if it would be easier to render my sky and fluffy clouds once,
and then include it in subsequent renders as HDRI.
Mike
Date: 24 Feb 2018 07:02:08
Message: <5a915440$1@news.povray.org>
>>> assume that
>>> (typical
>>> 1.0, just
>>> do that,
I would not do that if I were you. The fine details of the sky/cloud
structures would be lost. The resolution of the sky dome is not that
good and those images are not intended for crisp backgrounds but for
(global) illumination.
Date: 24 Feb 2018 07:16:02
Message: <5a915782@news.povray.org>
>>>> assume that
>>>> (typical
>>>> 1.0, just
>>>> can do that,
>> once, and then include it in subsequent renders as HDRI.
er.... I might contradict myself here because I may have misunderstood
what you intend to do :-)
If you intend to build a spherical sky probe to be used as hdri/exr sky
spheres in later scenes, then yes by all means, do that with a spherical
camera. However, be aware of my comment above at the same time. I attach
an example scene I made years ago to show what that means.
Download 'hdri_test1_mp_mt7.jpg' (35 KB)
Preview of image 'hdri_test1_mp_mt7.jpg'
Date: 24 Feb 2018 10:46:12
Message: <5a9188c4$1@news.povray.org>
I think that in addition to spherical HDRI formats, there are also cube
mapped ones. Does POV-Ray support these as well? (Cube mapping tends to
look nicer IMO.)
Mike
Date: 24 Feb 2018 12:05:46
Message: <5a919b6a$1@news.povray.org>
>>> assume that
>>> (typical
>>> 1.0, just
>>> do that,
> Mike
It can be done, but be aware that the clouds won't cast any shadow at all.
Depending on the specific of the rendered scene, this may be a problem.
Date: 24 Feb 2018 12:10:26
Message: <5a919c82$1@news.povray.org>
>> sky spheres in later scenes, then yes by all means, do that with a
>> spherical camera. However, be aware of my comment above at the same
>> time. I attach an example scene I made years ago to show what that means.
> look nicer IMO.)
> Mike
In a way, you can use the cubic maping, but you need to rotate the image
that is usually an upright cross sideway, then undo that rotation by
rotating the textured box.
If it comes as 6 images, then, the cubic pattern is appropriate.
