On 3/17/2017 4:49 AM, clipka wrote:
> There. Now you know the common property of all reflection spectra that
> map to the surface of the shape you're after. I hope this helps you
> devise an algorithm to compute them in a systematic fashion.
I was able to get some coding help from Bruce Lindbloom to generate the
XYZ coordinates. So, I have points and I have colors. But I do not have
a mesh. Do you have any tips on generating the mesh? Did you use one
color for each triangle, or did you create some sort of gradient?
Mike
> Mike
Also, is the shape stacked like a wedding cake? Are there the same
number of sections in each layer?
Mike
Am 18.03.2017 um 23:08 schrieb Mike Horvath:
I created and linked the points according to the following scheme:
where each `.` represents an interval in the spectrum that's at 0% power
and each `#` represents an interval in the spectrum that's at 100% power.
- On each line from left to right, the "box" spectra have a constant
width, but the starting point and end point shift from blue to red.
- On each line from bottom left to top right, the "box" spectra have a
constant starting point, but their width increases as the end point
shifts from blue to red.
- On each line from top left to bottom right, the "box" spectra have a
constant end point, but their width decreases as the starting point
Remember to define a point where your spectrum wraps around from red to
blue. The "mod" function helps a lot with that.
The layers shown as horizontal lines in the diagram above will /not/ be
perfectly horizontal in the colour space, due to the varying brightness
associated with each wavelength interval; but each layer will have the
same number of points.
Did you use a function to color the shape, or did you color each
triangle in a solid color? I am doing the latter at the moment using the
xyz2RGB() macro that comes with Lightsys. It works okay, but you can see
each and every triangle as a result. I don't like that.
I also tried re-using the function I used to color the sRGB gamut, and
the result is very wonky and random looking. Not good.
Mike
Am 19.03.2017 um 23:04 schrieb Mike Horvath:
I used an average of three function pattern pigments, each representing
the R, G or B component, respectively (multiplied by 3, so that the
average effectively implemented a sum), of the colour space in question
(CIE xyY in the particular case).
The functions did not go via sRGB, but straight from xyY to XYZ and from
there to linear RGB (with sRGB primaries).
As the entire shape is outside the linear RGB gamut, a straightforward
implementation of the functions would inevitably have exceeded the 0..1
range, and thus have caused undesired wraparound in the function
pattern; I therefore designed the functions to nominally return values
in the range from 0.5 to 0.6, and chose the colour map in a manner to
compensate (using e.g. `color_map{[0, red -5*3][1, red 5*3]}` for the
red component; note that the values of -5 and +5 compensate for the
uncommon nominal function range, while the factor of 3 is the one
required to effectively turn the average into a sum).
I was able to do this. The result is colors that are kind of dull and
muted. Is there a way to brighten them up?
Also, I don't understand why I can color each triangle by converting XYZ
to RGB and have the result look okay, but when I try to do the same
thing with a function the result is messed up (unless I follow your method).
Weird.
Mike
> method).
> Weird.
> Mike
Never mind. I forgot that when coloring the triangles I had also turned
on emission. Fixed now.
Mike
Am 20.03.2017 um 01:08 schrieb Mike Horvath:
> method).
That's because when you colour individual triangles you're using the
colour conversion function directly; but when you're using (an average
of multiple) function pigments, the function is used via a pattern,
where an implicit mod(f,1) is applied to the function, wrapping around
values outside the range 0..1 (e.g. a function value of 1.1 gets
translated to a colour map index of 0.1).
Or at least that's what I presume you're seeing. Been there, seen that.
>> method).
Is there a way to disable the wrapping using a keyword? It might make a
nice feature addition.
Mike
Am 22.03.2017 um 02:43 schrieb Mike Horvath:
Nope.
Not yet, that is. I have a plan to implement this as a kind of special
wave type; but on that occasion I would like to re-implement some of the
existing patterns to also provide a "no-wrap mode", which requires a bit
of thought and care.
