POV-Ray : Newsgroups : povray.advanced-users : Computer locked up Server Time
16 May 2026 20:32:43 EDT (-0400)
  Computer locked up (Message 1 to 10 of 25)
Subject: Computer locked up
Date: 13 Aug 2015 01:04:17
Message: <55cc2551$1@news.povray.org>
My computer just locked up due to lack of memory. I got a black screen
and had to reboot. Is this supposed to happen? Shouldn't POVray be
switching over to virtual memory?
Windows 7 Pro x64
8GB RAM
POV-ray 3.7.0.msvc10.win32
Not sure how much swap memory got used up during the render.
Mike
Subject: Re: Computer locked up
Date: 13 Aug 2015 02:22:49
Message: <55cc37b9$1@news.povray.org>
The system is in charge of virtual memory. Povray is just an application
with sometime huge need of memory.
> Windows 7 Pro x64
> 8GB RAM
Next time, open the task manager before starting the render, to see how
it goes.
The handling of swap (virtual memory) by most OS can be such a slow down
with random access that it turns super-speedy processor into very slow
snail. Some operating system do not even have protected special pages of
memory for themselves (excepted the swap routine... if you swap that
part of memory on disk, you're dead soon), and that might include the
data to draw the display: so, when refreshing the picture, such as when
moving the mouse and asking a redraw to all applications when exiting
screen-blank-economy mode (or other), it would need to access a lot of
pages while an active process is still asking a hell lot of other
pages... so refreshing the screen would take hours... hence your black
screen.
Usually swap is used with huge documents (photos or movie, or even
texts) whose only a tiny part need to be access at once, and the
distribution of the data is such that the accessed part for the current
task is usually a small set of continuous portions of the memory, so
putting the remainder of the memory on the disk is invisible to the user
(and the program is waiting 99.9% for user's interaction, so reaction
time is not impacted).
Povray with a huge scene is not like that: it takes all the CPU it can
for rendering, and want to access unpredictable locations all the time.
You might help to keep the reaction time for the user in a reasonnable
area by using less cpu-cores (via the -WT option), if at least you have
more than one true cores.
Some operating systems can enforce a memory limit per process: once
reached, they kill the offender without negotiation.
Date: 13 Aug 2015 02:42:22
Message: <55cc3c4e$1@news.povray.org>
So it should probably give an option of a maximum amount of memory to
ask the OS for? I have similar issues with simulation tools on my
windows box, but they (the apps) all give an option to limit the total
amount of RAM used. If you set it just under the amount of physical RAM
then at least you get an error before things go very screwy.
The problem is when you have a scene (or simulation in my case) where
you've done something that unexpectedly asks for a huge amount of RAM
(eg typo in a loop or something). Before you have chance to realise it,
your machine has effectively locked up.
Does anyone actualy render anything that takes more RAM than they have
physically? Wouldn't it take a lifetime to render?
Date: 13 Aug 2015 03:03:53
Message: <55cc4159$1@news.povray.org>
> it goes.
I am using Process Hacker 2. Not sure how to monitor swap usage. I can
only find the option to monitor physical memory, which does not take
long to deplete.
Can POV-Ray monitor this type of stuff? Would be nice to have it log the
info automatically.
Mike
Date: 13 Aug 2015 03:25:28
Message: <55cc4668$1@news.povray.org>
It might be nice to be able to set an upper limit on how much memory
POV-Ray is allowed to use and then fail gracefully when this limit is
reached.
The Lego town I am working on takes a lot of RAM when you turn the
little top studs on.
Mike
Date: 13 Aug 2015 03:29:38
Message: <55cc4762$1@news.povray.org>
>> it goes.
> long to deplete.
You need to look how much RAM the POV process is using. If it's anywhere
near the amount of physical RAM in your machine then it's going to start
causing major slowdowns.
Date: 13 Aug 2015 06:29:11
Message: <55cc7177$1@news.povray.org>
Am 13.08.2015 um 09:25 schrieb Mike Horvath:
> reached.
If you are happy with a fixed limit of 3GB, a simple solution would be
to use the 32-bit version of POV-Ray.
As for setting an arbitrary limit, it should be no surprise that this is
something that's not portable across operating systems.
 From what I'm finding on the 'net, on Windows machines "Job Objects"
seems to be a viable mechanism to achieve this. The idea would be to
tell Windows that it should simply pretend to POV-Ray that it is out of
memory if POV-Ray's memory requests exceed a given total size; POV-Ray's
failure mode would be the same as with the 32-bit version exceeding the
3GB limit. Whether this causes it to "fail gracefully" depends on
whether every nook and cranny of POV-Ray deals gracefully with an
out-of-memory condition; I currently can't vouch for that.
Alternatively, the front-end could continuously monitor POV-Ray's memory
consumption (it already does that for the status bar display anyway),
and if it exceeds the set limit it could send an abort request to the
back-end. This would make sure POV-Ray doesn't crash, and instead just
terminate the render; however, this mechanism may fail if memory
consumption increases too fast.
On Unix machines, the problem isn't that much of an issue, as operating
systems designed for multi-user operation are typically quite robust
against all sorts of ways an application could possibly run amok.
Date: 13 Aug 2015 06:43:53
Message: <55cc74e9@news.povray.org>
Am 13.08.2015 um 09:04 schrieb Mike Horvath:
>> it goes.
> long to deplete.
No need to look any further - if POV-Ray has to resort to virtual
memory, rendering performance will degrade fast, to the point where it's
pointless to continue the render. Worse yet, on Windows it will drag the
entire system into a state I call "Swap Hell", where even a simple thing
like opening the task manager may take half an hour.
> info automatically.
The Windows version already displays its current memory usage in the
status bar; and the render statistics output includes the peak memory
usage during the render (IIRC the Unix version does that as well).
Date: 13 Aug 2015 09:57:12
Message: <55cca238$1@news.povray.org>
Eventually Windows will step in and terminate the program, at which time
any statistics are lost unless POVray stores them somewhere on disk.
Mike
Date: 13 Aug 2015 09:57:58
Message: <55cca266$1@news.povray.org>
> Windows 7 Pro x64
> 8GB RAM
> Mike
I just increased the size of the swap file to 32GB and that still wasn't
enough. Time to give up.
