POV-Ray : Newsgroups : povray.advanced-users : Box using different points Server Time
12 Jun 2024 02:58:53 EDT (-0400)
  Box using different points (Message 1 to 9 of 9)
Subject: Box using different points
Date: 8 May 2015 12:35:00
Message: <web.554ce5a3d4e4487a4fa5c5bf0@news.povray.org>
Hello, I am using Box macro for making box but it uses only two points.
I have eight points as
a<0, 0, 0>
b<1, 0, 0>
c<1, 1, 0>
d<0, 1, 0>
e<0, 1, 1>
f<0, 0, 1>
g<1, 0, 1>
h<1, 1, 1>
How can I make a box using all these eight points?
Gurwinder Singh Bains
Subject: Re: Box using different points
Date: 8 May 2015 12:53:46
Message: <554cea1a$1@news.povray.org>
> a<0, 0, 0>
> b<1, 0, 0>
> c<1, 1, 0>
> d<0, 1, 0>
> e<0, 1, 1>
> f<0, 0, 1>
> g<1, 0, 1>
> h<1, 1, 1>
You can't. POVRay deals only real objects
Kurtz le pirate
Compagnie de la Banquise
Date: 8 May 2015 13:00:32
Message: <554cebb0$1@news.povray.org>
Hash: SHA256
Le 08/05/2015 18:53, kurtz le pirate a écrit :
>> points. I have eight points as a<0, 0, 0> b<1, 0, 0> c<1, 1, 0>
>> d<0, 1, 0> e<0, 1, 1> f<0, 0, 1> g<1, 0, 1> h<1, 1, 1>
There is 8 corners to a box, povray only wants you to specify the two
in pair along any of the four great diagonal.
a,h is ok, as are (b,e), (c,f) and (d,g).
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2
iJwEAQEIAAYFAlVM668ACgkQhKAm8mTpkW2XCgP/Ztf10l6je4uV765krTsJJp0p
VR+eXy6YS9zRi1ZkAXC+WLGqQsgdFQZ911ZIbK6joGCNYEDCZztW8FtAksSTvvlA
8W8/nB2mAJRRpuKZHTUx9kogvmSpfGksmo71Il/6V8fQs+PvTAniHddEtfSSq5rU
QNJpNlJ92SB/FNzoE3g=
=GDH0
-----END PGP SIGNATURE-----
Date: 8 May 2015 13:01:52
Message: <554cec00$1@news.povray.org>
> a<0, 0, 0>
> b<1, 0, 0>
> c<1, 1, 0>
> d<0, 1, 0>
> e<0, 1, 1>
> f<0, 0, 1>
> g<1, 0, 1>
> h<1, 1, 1>
I'm not sure if I'm missing something here, but surely you only ever
need two points. In your example, these would be <0, 0, 0> and <1, 1, 1>
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 9 May 2015 13:00:00
Message: <web.554e3be060156bc7fedbcc650@news.povray.org>
maybe it's better to say, you only ever need
1) Two points, and
2) The side condition that these two points are opposite corners
But it's never reasonable that you define a box by 8 points, since 8 points
don't always form a box - even 3 points might be too much: 2 define the box, and
the third might be located elsewhere in space (if I'm tight ...).
> > a<0, 0, 0>
> > b<1, 0, 0>
> > c<1, 1, 0>
> > d<0, 1, 0>
> > e<0, 1, 1>
> > f<0, 0, 1>
> > g<1, 0, 1>
> > h<1, 1, 1>
> John
> Protect the Earth
Date: 9 May 2015 17:09:27
Message: <554e7787$1@news.povray.org>
On 09/05/15 17:54, Sereib wrote:
> Hi,
> 1) Two points, and
Indeed. I didn't make my self clear enough - mea culpa
John
Protect the Earth
Date: 10 May 2015 02:10:51
Message: <554ef66b@news.povray.org>
> a<0, 0, 0>
> b<1, 0, 0>
> c<1, 1, 0>
> d<0, 1, 0>
> e<0, 1, 1>
> f<0, 0, 1>
> g<1, 0, 1>
> h<1, 1, 1>
By definition, a box have faces that are parallel two by two and are
also perpendicular to the other 4 faces.
As, initialy, the box's faces are all parallel to the base planes, you
only need two oposite corners.
If you realy need more than that, you are no longer dealing with a box
but some variation of an hexaedron.
If, additionaly, those faces are not flat, you have a twisted hexaedron,
or some other beast that may, or not, self intersect.
Date: 10 May 2015 05:10:01
Message: <web.554f1f9260156bc77a3e03fe0@news.povray.org>
> a<0, 0, 0>
> b<1, 0, 0>
> c<1, 1, 0>
> d<0, 1, 0>
> e<0, 1, 1>
> f<0, 0, 1>
> g<1, 0, 1>
> h<1, 1, 1>
#declare Default_texture = pigment {rgb 0.8}
#declare a = <0, 0, 0>;
#declare b = <1, 0, 0>;
#declare c = <1, 1, 0>;
#declare d = <0, 1, 0>;
#declare e = <0, 1, 1>;
#declare f = <0, 0, 1>;
#declare g = <1, 0, 1>;
#declare h = <1, 1, 1>;
#declare Box = mesh{
triangle{a,b,c}
triangle{a,c,d}
triangle{a,d,f}
triangle{e,d,f}
triangle{c,d,e}
triangle{c,e,h}
triangle{a,b,g}
triangle{a,f,g}
triangle{b,c,g}
triangle{g,h,c}
triangle{e,f,g}
triangle{e,g,h}
texture{Default_texture}
Box
Date: 18 May 2015 02:15:01
Message: <web.5559820f60156bc75d0ff6fc0@news.povray.org>
> > a<0, 0, 0>
> > b<1, 0, 0>
> > c<1, 1, 0>
> > d<0, 1, 0>
> > e<0, 1, 1>
> > f<0, 0, 1>
> > g<1, 0, 1>
> > h<1, 1, 1>
> triangle{a,b,c}
> triangle{a,c,d}
> triangle{a,d,f}
> triangle{e,d,f}
> triangle{c,d,e}
> triangle{c,e,h}
> triangle{a,b,g}
> triangle{a,f,g}
> triangle{b,c,g}
> triangle{g,h,c}
> triangle{e,f,g}
> triangle{e,g,h}
> Box
Great, thats what I was trying but can get it because I was doing mistake by not
writing all the triangles into mesh.
