POV-Ray : Newsgroups : povray.advanced-users : Stop rendering using a break statement Server Time
18 May 2024 20:11:46 EDT (-0400)
  Stop rendering using a break statement (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Stop rendering using a break statement
Date: 8 Feb 2015 15:20:32
Message: <54d7c510$1@news.povray.org>
Am 08.02.2015 um 20:26 schrieb Mike Horvath:
> Is there a easy way to stop rendering based on a condition, sort of like
> a break statement in a loop? I know I can wrap my entire scene in a
> condition, but I am hoping there is something simpler. Thanks.
POV-Ray is quite a fascinating thing: It provides ways to do plenty
different things, sometimes in more than one fashion.
Therefore, rather than ask about a very specific mechanism, it is often
a more promising approach to ask about the goal you ultimately want to
achieve; the mechanism you have in mind for it might be unavailable, but
there might be other ways around it.
Date: 8 Feb 2015 15:32:10
Message: <54d7c7ca$1@news.povray.org>
One thing I want to do is stop parsing when frame_number equals some
number. I've created an animation with duplicates that I don't need. But
I can think of other instances where this could be handy.
Date: 8 Feb 2015 16:18:38
Message: <54d7d2ae@news.povray.org>
You just want the +EF option ( end-frame, followed by the number of the
frame after which to stop the rendering of the range.)
Look also at SF (start frame) to start after the first one.
Date: 8 Feb 2015 19:31:02
Message: <54d7ffc6$1@news.povray.org>
No. For example I may want frames 1-3 and 5-6 parsed and rendered, but
not frame 4. Your suggestion doesn't work in this case.
Date: 9 Feb 2015 02:18:46
Message: <54d85f56@news.povray.org>
Am 09.02.2015 um 01:31 schrieb Mike Horvath:
So what you're after is not really stopping a render, but skipping
individual frames in it.
No, at the moment I can't think of any mechanism by which POV-Ray might
support this (other than rendering only subsets of the animation in the
first place). The "#error" directive came to my mind, but it does not
only abort parsing of the current frame, but also the entire render job.
Date: 9 Feb 2015 03:14:25
Message: <54d86c61$1@news.povray.org>
Do you not want frame 4 rendered to save time, or because you physically
don't want the file to be created?
If you want to save time, but don't mind the file being there, then just
let it render an empty scene with no objects for the frames you don't
want, it will only add a fraction of a second.
It should be easy if you could render another .pov file, and put
something like this in it:
#if(frame_number<>4) // or whatever condition
  #include "mainPOVscene.pov"
Date: 9 Feb 2015 03:23:43
Message: <54d86e8f$1@news.povray.org>
If frame 4 has already a output file, I wonder if the -C (or is it +C ?
I know they are opposite of each other, but cannot remember which one
would try to look if the output image already exist and is complete)
option would not skip the render of it when detecting that it is already
complete ?
Just because nobody complains does not mean all parachutes are perfect.
Date: 9 Feb 2015 15:01:23
Message: <54d91213$1@news.povray.org>
> complete ?
If frame 4 exists most likely the others will as well. I tend to
accumulate renders and not delete them for years at a time.
Date: 9 Feb 2015 15:02:35
Message: <54d9125b$1@news.povray.org>
> #end
I'm sure there's a workaround for every example I can come up with. A
break statement would just be a lot simpler and easier.
Date: 9 Feb 2015 22:12:45
Message: <54d9772d$1@news.povray.org>
Am 09.02.2015 um 21:02 schrieb Mike Horvath:
 From the user's point of view - yes, probably.
 From the developer's point of view - not so much. The current, grown
architecture doesn't lend itself to just skipping the parsing of a
frame, as all the set-up (most notably the deletion of an existing file
with the same name as the output file!) is done before invoking the
parser module.
