POV-Ray : Newsgroups : povray.advanced-users : clipped_by, complex unions and bad csg results Server Time
28 Sep 2024 12:13:27 EDT (-0400)
  clipped_by, complex unions and bad csg results (Message 1 to 6 of 6)
Subject: clipped_by, complex unions and bad csg results
Date: 11 Oct 2007 18:04:26
Message: <470e9dea$1@news.povray.org>
Greetings,
I've been making an object library which allows me to make beveled,
filleted and chamfered objects, to be used for stone pillars and the
like. Not wanting to deal with slow csg operations, I opted to make
everything from basic shapes with the clipped_by modifier applied.
It all works very well, since the (hollow) surfaces meet up with each
other if used properly. To see how well, I tested the closed objects
with interior_texture, transparency, media, refraction, and interior
attenuation. All these features work as they should, and the render time
is relatively fast, as expected.
The problems come when I try to apply traditional csg techniques to my
objects (difference, merge, intersection). Strange artifacts appear,
such as transparent planes, partial csg results, and other strange things.
I'd rather not post my code here, as the definition for each object is
rather large.
Has anyone else encountered strange results when trying to difference,
intersect or merge unions of clipped_by objects? Was there a workaround?
I'm beginning to think there isn't a solution....
Sam
Subject: Re: clipped_by, complex unions and bad csg results
Date: 11 Oct 2007 18:15:01
Message: <web.470e9fc35c01085976e65db0@news.povray.org>
Samuel Benge <stb### [at] THIShotmailcom> wrote:
> Greetings,
> rather large.
> Sam
Good initiative!
Unfortunately, I nearly never happen to use objects with clipped_by, and I
can't be of much help for your problem. Hope someone else can.
Bruno.
Date: 11 Oct 2007 23:03:58
Message: <470ee41e@news.povray.org>
Samuel Benge nous apporta ses lumieres en ce 2007/10/11 18:05:
> Greetings,
> rather large.
> Sam
It could be a bounding problem.
Have you tried adding: bounded_by { clipped_by }? This will add a manual
bounding conforming to the clipping object.
Unitarianism: Come let us reason together about this shit.
Date: 12 Oct 2007 02:02:53
Message: <470f0e0d$1@news.povray.org>
I tried several variations of your suggestion, and either nothing
worked, or it made things worse. I will have to try a simpler test to
see if I can find success.
Sam
Date: 12 Oct 2007 07:09:24
Message: <470f55e4@news.povray.org>
  A short example scene demonstrating the problem would be helpful.
  My guess is that it's the infamous coincident surfaces problem.
(I actually don't know if this problem happens if two *clipping* surfaces
coincide, but it could well be.)
Date: 17 Dec 2007 00:10:01
Message: <web.4766047b5c01085978dcad930@news.povray.org>
> > Sam
I have a suggestion--which may not have any relevance--but you might try
changing Remove_Bounds=on/off and/or Bounding_Threshold=*some integer* in your
..INI file. That has helped me in some *odd* situations. Sorry I can't be more
specific as to *why* this trick (sometimes) works; I don't quite understand it
myself. The default Bounding_Threshold in POV-Ray is 3--or so it seems--not 25
as mentioned in the docs. Try alternately changing it to 1, or to 50 or more
(i.e., two extremes.)
I'd be curious to know if this helps.
Ken
