POV-Ray : Newsgroups : povray.advanced-users : 3D Sinewave Server Time
21 Dec 2025 20:55:52 EST (-0500)
  3D Sinewave (Message 1 to 10 of 11)
Subject: 3D Sinewave
Date: 12 Oct 1999 16:40:40
Message: <38039C86.6495FF94@pacbell.net>
Using this code I can create a 2D representation of a sinewave in
the x/y plane:
#declare i=0;
  #while (i<90)
    sphere {0,1 pigment {rgb <1,0,0>}finish {ambient 1.0}
    translate <i,10*sin(i*pi/30),0>}
  #declare i = i + 1;
  Is it possible to extend (not extrude) the sine wave pattern into the
z plane as well ?
  The final result if I can describe it correctly would be alternating
mounds and valleys.
Anyone ?
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: 3D Sinewave
Date: 12 Oct 1999 19:27:48
Message: <w8IDOHDO5OcrUhoHNT=1YMVHBQNX@4ax.com>
>z plane as well ?
>mounds and valleys.
>Anyone ?
Try:
#declare X=-50;
#while (X<50)
  #declare Z=-50;
  #while (Z<50)
    sphere { <X,5*sin((X+Z)/30),Z>,1 }
    #declare Z=Z+1;
  #end;
  #declare X=X+1;
Unchecked!!!
Peter Popov
ICQ: 15002700
Date: 12 Oct 1999 19:55:07
Message: <3803CA1B.889E7692@pacbell.net>
Peter Popov wrote:
> Try:
> #declare X=-50;
> #while (X<50)
>   #declare Z=-50;
>   #while (Z<50)
>     #declare Z=Z+1;
>   #end;
>   #declare X=X+1;
> #end
> Unchecked!!!
Thanks Peter but this gives an extruded sine. Maybe it's my explaination.
I'll try to make a csg example and post it later in pbi.
Date: 12 Oct 1999 20:20:38
Message: <wM8DOP6D1RKujo1QWpBTxzgdrTVH@4ax.com>
No, Ken, your explanation is perfectly clear and I have even seen the
thing animated realtime (on a 486 DX40) but my math is wrong.
POV finished rendering (maybe I should post the result? Haven't posted
a pic in a #while...) so I will check my formula and post a bit later
(half an hour?)
Peter Popov
ICQ: 15002700
Date: 12 Oct 1999 20:29:24
Message: <3803D2DF.677D27AC@compuserve.com>
I think this:
#declare X=-50;
#while (X<50)
  #declare Z=-50;
  #while (Z<50)
    sphere { <X,5*(sin(X/30) +sin(Z/30)),Z>,1 }
    #declare Z=Z+1;
  #end;
  #declare X=X+1;
will do what you want.
Date: 12 Oct 1999 20:36:00
Message: <dtMDOPlEzW7Ut5Dv2DTMhryV1vVm@4ax.com>
On Wed, 13 Oct 1999 03:19:37 +0300, Peter Popov <pet### [at] usanet>
>(half an hour?)
Here you go:
#declare X=-100;
#while (X<100)
  #declare Z=-100;
  #while (Z<100)
    #declare Y=5*sin(X/10)+5*sin(Z/6);
    sphere { <X,Y,Z>, 2 pigment { blue 1 green (10+Y)/20 } }
    #declare Z=Z+2;
  #declare X=X+2;
light_source { 1000*y color rgb 1 }
camera
{ location <20,60,-80> up y right x sky <3,10,0> look_at -35*z }
Render a swuare image. Enjoy the dive :)
Peter Popov
ICQ: 15002700
Date: 12 Oct 1999 20:40:24
Message: <3803D573.A275F98C@compuserve.com>
Note: I did not test this code, I actually made an isosurface with this
function:
function {y - 5*(sin(x/3) + sin(z/3))}
and a threshold of 0. Of course, this requires the Superpatch.
This has been tested:
union {
 #declare X=-50;
 #while (X<50)
   #declare Z=-50;
   #while (Z<50)
     sphere { <X,5*(sin(X/5) +sin(Z/5)),Z>,1 pigment {color Yellow}}
     #declare Z=Z+1;
   #declare X=X+1;
 scale 0.1
Date: 12 Oct 1999 21:34:31
Message: <3803E166.FA4FE476@pacbell.net>
> function:
> union {
>  #declare X=-50;
>  #while (X<50)
>    #declare Z=-50;
>    #while (Z<50)
>      #declare Z=Z+1;
>    #end
>    #declare X=X+1;
>  #end
>  scale 0.1
Worked great. Thanks Chris.
Date: 12 Oct 1999 21:35:34
Message: <3803E1A8.6D6BBAE9@pacbell.net>
> >(half an hour?)
> Here you go:
> #declare X=-100;
> #while (X<100)
>   #declare Z=-100;
>   #while (Z<100)
>     #declare Z=Z+2;
>   #end
>   #declare X=X+2;
> #end
> camera
> Peter Popov
> ICQ: 15002700
Worked great. Thanks Peter.
 Swuare image ? :)
Date: 12 Oct 1999 23:15:10
Message: <3803F96A.11F24BD@xs4all.nl>
> the x/y plane:
> #declare i=0;
>   #while (i<90)
>   #declare i = i + 1;
> #end
> z plane as well ?
> mounds and valleys.
> Anyone ?
If I remember right Spider did a lot of this last year.
There must still be something somewhere in the b.i.-group.
Remco
