POV-Ray : Newsgroups : povray.advanced-users : Math help needed please. Server Time
22 Dec 2025 01:52:03 EST (-0500)
  Math help needed please. (Message 1 to 10 of 40)
Subject: Math help needed please.
Date: 18 Apr 1999 18:41:58
Message: <371a51a6.0@news.povray.org>
Starting with the following code:
sphere {
    <0,0,0>,1
    scale <0.25,1,0.25>
    translate <-0.5,0,0>
    texture { MyTexture }
plane
    y, -1
I wish to rotate the sphere clockwise on the z axis by 180 degrees, at the same time
translating it along the x axis by 1 unit, so that it ends up at <0.5,0,0>.
The question is, how do I mathematically model the vertical motion so that the shape
appears to be rolling along the plane?NOTE: I may wish to alter the scale of the shape
*during* the anim, so this must be taken into account in the equation.
Any help appreciated.
Andy
--The Home Of Lunaland--
--visit my POV-Ray gallery--
--listen to my music--
www.acocker.freeserve.co.uk
Subject: Re: Math help needed please.
Date: 18 Apr 1999 19:49:48
Message: <371A602B.49520542@pacbell.net>
Andrew Cocker wrote:
> Hi,
> sphere {
>     <0,0,0>,1
>     scale <0.25,1,0.25>
> plane
>     y, -1
shape
> Andy
Hi Andy,
  While not a definitve answer to your question one of the first examples
given in the animation tutorial section of the Pov-Ray docs provides scripts
showing how to roll a sphere along a floor, have it turn and then come back
halfway. Scaling the object as it rolls would involve subtacting the
difference in size and using it as a function to specify the y translation
component of the objects translate action. While not a super easy thing to
figure out it should not take advanced math functions to get the job done.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 18 Apr 1999 21:40:09
Message: <371a7b69.0@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote in message news:371A602B.49520542@pacbell.net...
> Hi Andy,
Thanks Ken,
    Yeah, I was aware of that example. I approach all problems like this absolutely
befuddled. Sometimes, after some thought, the answer jumps out at me, but this time it
didn't/hasn't yet. Obviously it's easy to work out the vertical translation at clock
0.5,
as it's the post-scaled radius of the sphere plus the plane's y translation ( in this
case -0.75 ). But I can't get my head round how to work out the amount for clock 0.24
etc.
It's probably really simple.
    I should point out that I haven't even started coding this one yet ( trying to
think
it through first ), and doing so may prod my sleeping brain into ( slothfull ) action.
thanks again,
Andy
Date: 18 Apr 1999 22:09:36
Message: <371A80F1.7AF191A8@pacbell.net>
> > Hi Andy,
> Thanks Ken,
it
0.5,
this
0.24 etc.
think
action.
> thanks again,
> Andy
 I would think you simply attach the scaled difference to the clock
function inside the translate statement. If you need this action to
only occur within a certain time frame as you indicate is the case
you can set up the movement of the object for that particular segment
of the clock using #if #else statements. This too is detailed in the
tutorials section of the docs althought the possible uses are not so
well defined for you.
  This is one case where you would benefit from breaking up the movement
into different segments instead of treating it as a function of the entire
clock cycle of 0 - 1.
It would be kind of like this:
 // do nothing between clock 0 - .25
#if MyClock = (clock < .25 )
object { stuff translate <0, 0, 0> }
#else
 //do something between clock .25 - .5
#if MyClock = (clock <= .5 )
object { stuff translate <0, -.25*MyClock, 0> }
#else
 // do nothing between clock .5 - 1
#if MyClock = (clock > .5 )
object {stuff translate <0, 0, 0> }
#else
  This is the basic idea even if I screwed up the syntax of the example.
See the docs for the correct way to specify it.
 This also gives you the ability to have many different objects performing
differnt actions based on a clock cycle of 0 - 1 but each acting within
a predefined segement of that clock cycle.
 There are users out there that can give better examples than I can.
I have studied the animation process enough that I know it's possibilities
but do so little animation work that I have little practical experience
to provide you with working examples.
Ken Tyler
Date: 18 Apr 1999 22:33:41
Message: <371A87C9.59BD8717@aol.com>
Warning! I'm not a "Advanced User" I just play one on the home computer.
If I gather this right, sounds like you need a sin cos type thing for
the translation (one for x and one for y). However, why not just rotate
-clock*180*z while moving 1*x and use a math function on the scale y.
Without trying it out I don't know exactly what this would be.
sphere {
    <0,0,0>,1
    scale <0.25,H,0.25> //H increases/decreases to keep touch with floor
   rotate -clock*180*z  translate clock*x
plane
    y, -1
Sound about right anyone? Well, even close then?
Date: 18 Apr 1999 22:45:42
Message: <371A89A4.398EDE83@bahnhof.se>
Well, I haven't done animations in POV yet. (I don't need a 4th dimension, I
have my head full with 3.)
>>>>>>>>>>>>Bob Hughes wrote:
<snip>
<remaking>
sphere {
  <0,0,0>,1
  translate <0,-H/2,0> /* I think this must be added,
		    so it will keep in touch with the plane */
  rotate -clock*180*z
  translate clock*x
> plane {
>     y, -1
>   http://members.aol.com/inversez/homepage.htm
>  mailto:inv### [at] aolcom?Subject=PoV-News
//Spider
                "Marian"
        By: "Sisters Of Mercy"
Date: 18 Apr 1999 23:03:10
Message: <371A8D63.50789135@pacbell.net>
> >>>>>>>>>>>>Bob Hughes wrote:
> <snip>
> <remaking>
> sphere {
>   <0,0,0>,1
>   rotate -clock*180*z
>   translate clock*x
That was a good catch with the translate being one half of the spheres
scaled difference. If you used the total scale amount you would be
translating for the difference in size of both halfs of the radius.
and end up to 2 times farther that you need to be to stay in contact
with the surface of the plane.
To complete the above example and tie it to the clock try this:
// Assume the shere is 1 and you wand to have finish size of 0.5
  #declare Diam = 1;
 sphere {0, Diam
         scale clock*0.5
         rotate clock*180*z
         translate < -0.5*clock, -Diam*0.5/2*clock, 0 >
  I think !
Ken Tyler
Date: 18 Apr 1999 23:05:49
Message: <371A8E1D.AFAC9B51@pacbell.net>
>   rotate -clock*180*z
Remember especialy with animations to rotate then translate or your object
will orbit instead of rotate.
Ken Tyler
Date: 18 Apr 1999 23:06:01
Message: <371A8E66.D0A492AD@bahnhof.se>
Another good point, but wouldn't it be better to calculate the diameter formula
outside the sphere?
That way, you only need to do one change instead of two(I'm talking about the
Diam*0.5 .... lines..)
//Spider
                "Marian"
Date: 18 Apr 1999 23:11:11
Message: <371A8F60.26C98EED@pacbell.net>
> outside the sphere?
> //Spider
You need to remember that scaling in an animation is time dependant and by
using the clock the object will appear to gradualy deminish in size instead
of being seen as an instant change. The translate and the rotate need to be
tied together with a circumference operation to account for the fact
it is rolling as opposed to sitting and spinning but moving too. It's covered
in the docs like I said before. Good example that one.
Ken Tyler
