POV-Ray : Newsgroups : moray.binaries : RIB exporter results. Server Time
10 Jun 2026 13:35:27 EDT (-0400)
  RIB exporter results. (Message 1 to 6 of 6)
Subject: RIB exporter results.
Date: 1 Feb 2000 08:05:18
Message: <3896DA4D.EEDE9998@mninter.net>
I've attached a couple of zip files, with two images in each. They show
the differences between rendering in POV-Ray and rendering in BMRT. The
UV's seem a bit messed up in the exported RIBs, though...also, the
parameters to the plastic shading style in BMRT are far different from
the parameters to the POV-Ray standard finish for textures.
You Know You've Been Raytracing Too Long When:
  You take your POV-Ray to work and raytrace a little animation while
out for lunch.
Produced by Alex Magidow's Sig File Randomizer(YKYBRTTL jokes courtesy
of c.g.r.raytracing)
Download 'beztest.zip' (70 KB) Download 'ribandpov.zip' (80 KB)
Subject: Re: RIB exporter results.
Date: 1 Feb 2000 09:13:03
Message: <3896e9ef@news.povray.org>
its quite nice to see there is very little differemce in these two renders,
kinda shows the quality of povray.
on a side note, i tried a few test renders, but kept getting the message
that the povpointlight shader could not be found, even tho it was in my
shaders dir, or anywhere i put it.
"Alex Magidow" <axi### [at] mninternet> wrote in message
news:3896DA4D.EEDE9998@mninter.net...
> out for lunch.
Date: 1 Feb 2000 23:28:29
Message: <3897B2FA.5CEF71CD@mninter.net>
AFAIK, you need to set path = youshaderdirectoryhere or add this line of code
to the RIB file:
Option "searchpath" "shader" ["youshaderdirectoryhere"]
the setting the path thing is the best idea, IMO.
Well, depends on what you mean by quality. POV-Ray doesn't have programmable
shaders...I'd rather dare you to compare the quality of the two when that is
taken into consideration. The shadows are a bit weird, as they don't seem to be
in the renderman standard(and the usual arealight trick doesn't seem to work
too well in renderman). But then, neither could you do something like
windowhighlight.sl- try cutting that from this
site(http://www.renderman.org/RMR/Shaders/RCShaders/index.html), compiling it,
then applying it to an object. Its pretty impressive. Or use windowlight
instead of a standard povray light(just change the name in the RIB file).
> Rick
> > out for lunch.
  You take your POV-Ray to work and raytrace a little animation while out for
lunch.
Produced by Alex Magidow's Sig File Randomizer(YKYBRTTL jokes courtesy of
c.g.r.raytracing)
Date: 1 Feb 2000 23:35:41
Message: <3897B4AB.9CE45D09@mninter.net>
Or if you really want to see what can be done with BMRT, look to this page:
http://www.bmrt.org/bmrtgallery.html
Specifically, I'd suggest looking at this image. Its really awsome:
http://www.bmrt.org/bmrtimages/merritt-fruit3.jpg
Nothing in it is an image map- everythings procedural and antialiased.
> to the RIB file:
> > Rick
> > > out for lunch.
> lunch.
> c.g.r.raytracing)
lunch.
c.g.r.raytracing)
Date: 2 Feb 2000 04:21:01
Message: <3897f6fd@news.povray.org>
i got a version of brmt that was pre set up for use with rhino, and i have
entered the dirs in my autoexec file, but it seems not the be working.
news:3897B2FA.5CEF71CD@mninter.net...
code
> to the RIB file:
renders,
programmable
is
to be
work
it,
> > Rick
show
The
> > > out for lunch.
for
> lunch.
> c.g.r.raytracing)
Date: 2 Feb 2000 07:55:52
Message: <389829E5.C194C4D0@mninter.net>
In that case, I'd suggest that you just add that line to the RIB file before
rendering. I haven't been able to get the autoexec.bat thing to work
either-xander just told me about it. Perhaps you ought to ask him.
> Rick
> code
> > to the RIB file:
> renders,
> programmable
> is
> to be
> work
> it,
> > > Rick
> show
> The
> > > > out for lunch.
> for
> > lunch.
> > c.g.r.raytracing)
 You wonder why you ever collected those 200 megs worth of paint and image
manipulation programs now rusting somewhere on your hard drive.
c.g.r.raytracing)
