POV-Ray : Newsgroups : povray.windows : How kill IDLE using command line? Server Time
3 Apr 2026 03:38:02 EDT (-0400)
  How kill IDLE using command line? (Message 1 to 7 of 7)
Subject: How kill IDLE using command line?
Date: 31 Aug 2013 07:10:01
Message: <web.5221cbf7299c68557a3e03fe0@news.povray.org>
How automatically close IDLE window after rendering ???
Open OS Windows - 100000 problem add :)
-d this is not that. -d - not open render window, but subprocess.wait() closing
IDLE.
Why opens if the command line is used?
It is very serious bug :)
Subject: Re: How kill IDLE using command line?
Date: 31 Aug 2013 10:42:36
Message: <522200dc$1@news.povray.org>
Am 31.08.2013 13:08, schrieb LanuHum:
> IDLE.
AFAIK It's currently not possible to automatically close POV-Ray for
Windows after rendering; however, if you have thousands of images to
render (and for some reason can't make use of the animation feature),
you can avoid that many windows to open by using POV-Ray's "keep single
instance" option.
As long as all the images have the same resolution, I'd suggest trying
to use the animation feature though.
Date: 31 Aug 2013 13:00:01
Message: <web.52222007e42918d7a3e03fe0@news.povray.org>
> > IDLE.
> instance" option.
I use povray also for texture preview.
Look:
http://yadi.sk/d/2dGKINsP8XpWI
In Linux - very good option -d. Process in shadow. Press button "update
preview", wait 3-5 s, image 256x256 automatically opens in small preview
viewport in Blender
In Windows: Press button "update preview", public open IDLE, user press quit
IDLE, only then image 256x256 automatically opens in small preview viewport in
Blender.Inconveniently, ugly, roughly, not on the feng-shui(geomantic (omen))
Date: 31 Aug 2013 14:00:58
Message: <52222f5a$1@news.povray.org>
Le 31/08/2013 18:55, LanuHum nous fit lire :
>>> IDLE.
>> instance" option.
> Look:
> viewport in Blender
It seems someone need a /EXIT on the command line so that *Blender*
behave the same way on Linux and Windows.
At least that information of context is coming only after 3 messages.
(Or did the 3.7 windows version get a removed /EXIT ?)
Date: 31 Aug 2013 14:12:03
Message: <522231f3$1@news.povray.org>
no, it is still there and works as it did in the past.
-- Chris
Date: 31 Aug 2013 14:28:36
Message: <522235d4$1@news.povray.org>
> IDLE.
Not a bug, it is working as documented in the manual.
  http://wiki.povray.org/content/Documentation:Windows_Section_3
See the above for how to make it exit.
-- Chris
Date: 31 Aug 2013 15:30:01
Message: <web.5222441ce42918d7a3e03fe0@news.povray.org>
> -- Chris
Thanks, I found an option in GUI!
Render\On completion\Exit Povray for Windows
Gui close after render!
Very,very good! :)
