POV-Ray : Newsgroups : povray.windows : messagewindow doesn't wrap? Server Time
24 Feb 2025 01:16:39 EST (-0500)
  messagewindow doesn't wrap? (Message 1 to 8 of 8)
Subject: messagewindow doesn't wrap?
Date: 2 Oct 1998 19:41:39
Message: <3615654A.B8CA5CB4@xs4all.nl>
I have a problem reading messages in the messagewindow. The lines don't
wrap. I already experienced that with 3.01, but I seem to remember that
with some twiddling I could read the rest of the line (with a
scrollbar). I can't seem to get this done in 3.1. What am I doing wrong
and/or what can I do about it?
Remco de Korte
Subject: Re: messagewindow doesn't wrap?
Date: 2 Oct 1998 20:01:47
Message: <36155B05.26C1157C@pacbell.net>
> Regards,
> Remco de Korte
 Is your screen resolution set for 640x480 ?
I recall a warning that you get once when you first
install pov that says:
"your system is using 640x480 but POV-Ray is designed to be used
with resolutions of 800x600 or greater. If you use this mode some
features of the editor may not work correctly"
Well if not verbatim it said something to that effect anyway.
Ken
Date: 2 Oct 1998 22:46:02
Message: <361581DF.4BA7EEB4@flash.net>
I have the same problem... the scrollbar disappears and
I am unable to see text to the right.  And I use a small
font (New Courier 8) with 1024x768 resolution.
Dan
> Regards,
> Remco de Korte
http://www.flash.net/~djconnel/
Date: 2 Oct 1998 23:38:07
Message: <36159C45.70737B77@xs4all.nl>
> Ken
No, but even then. I have my screen set at 800x600 and to read the
message I changed it to 1024x768 (something went wrong and I didn't
understand - that's what the messages are for, aren't they?). Even at
that resolution the last part (not significant) ran of the screen.
Remco
Date: 3 Oct 1998 00:09:47
Message: <36159527.EB4FA6D9@pacbell.net>
> Regards,
> Remco
  I'll bet it is something else then : )
Ken
Date: 3 Oct 1998 10:40:04
Message: <361637D6.B5CC7E43@xs4all.nl>
> > Regards,
> > Remco
> Ken
I wonder...
Date: 3 Oct 1998 23:29:22
Message: <3616DD3B.165E5583@nctc.net>
> Regards,
> Remco de Korte
I got the same problem.
Stephen's Plumbing and Well Service
Stephen Nichols
sni### [at] nctcnet
Date: 12 Oct 1998 23:01:18
Message: <3622B582.1FFE@phoenix.net>
Good Lord! I get a headache just reading that. :)
I've been wondering about line wrap too, BTW.
> Dan
