POV-Ray : Newsgroups : povray.unofficial.patches : Showing two shiny spheres. Server Time
6 Apr 2026 18:11:08 EDT (-0400)
  Showing two shiny spheres. (Message 1 to 3 of 3)
Subject: Showing two shiny spheres.
Date: 28 Oct 2004 22:29:34
Message: <4181ab0e$1@news.povray.org>
In a thread I brought up elsewhere,  Christoph suggested:
<< For two spheres you just do:
#declare Start_Idx1=mechsim:face_count;
MechSim_Generate_Sphere(...)
#declare Start_Idx2=mechsim:face_count;
and later:
MechSim_Show_Sphere(Start_Idx1, Start_Idx2-Start_Idx1, ...)
MechSim_Show_Sphere(Start_Idx2, mechsim:face_count-Start_Idx2, ...)
However, the _Generate_Sphere _ code would only be used in frame 1, and you
need to show the objects on frames 2 through the end.
I know I'm truly ignorant here, but I'm tempted to ask if it is a limitation
of the mechsim system that it cannot work with more than one sphere and make
them both shiny.  Or you have to do some arithmetic on paper to figure out
the numbers that the Idx variables would represent.
Subject: Re: Showing two shiny spheres.
Date: 29 Oct 2004 04:15:02
Message: <clsu3s$1o0$1@chho.imagico.de>
> and later:
For the other frames you would need to write the numbers to a file.  A
set of MechSim_Write_Index()/MechSim_Read_Index() macros could be useful
but is fairly straight away to write.  You can also simply print the
numbers in the message window using #debug and insert them manually.
This is not a flaw in the system but completely intentional.  It is the
only way it can work.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 29 Oct 2004 06:32:39
Message: <41821c47$1@news.povray.org>
Yes, as Christoph says, I find by far the easiest way (for me) is to #debug the
numbers to the
message window. Inserting them manually for just two spheres takes seconds, and unless
you
change the topology only needs to be done once.
In fact, the easiest way would be to #declare the numbers outside of topology
generation
rather than insert them into the MechSim_Show_Sphere() macro directly. So..:
#declare Start_Idx1=0;// Add number returned from #debug here
#declare Start_Idx2=80;// Add number returned from #debug here
//Then..
...would work
Andy
