POV-Ray : Newsgroups : povray.unofficial.patches : First try with Photons - help? Server Time
5 Jul 2026 14:07:07 EDT (-0400)
  First try with Photons - help? (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: First try with Photons - help?
Date: 14 Mar 2001 19:43:31
Message: <3ab01033$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message news:chrishuff-> > Any
idea what causes the black streak in the middle of the wall?  I
> > always figured it was a shadow of the tip of the glass, but the
> > streak is in all directions, not just where the tip is.
> It looks like a solver error...is the wall or glass a sor, lathe, poly,
> or anything else which can use the sturmian root solver? If so, did you
> try using "sturm" or moving the camera/light source around a bit?
It's a simple curve made with a cylinder.  I tried moving the light source a
tad, nothing I can use with strum.  I posted the code in a reply to Ken.
--John
Date: 14 Mar 2001 20:06:16
Message: <chrishuff-C04E3E.20015214032001@news.povray.org>
In article <3ab00fe5@news.povray.org>, "John M. Dlugosz"
<joh### [at] dlugoszcom> wrote:
> difference {
>    intersection {
>       cylinder { <0,0,0>, <0,18,0>, 12 }
>    cylinder { <0,0,0>, <0,18,0>, 11.5 }
You have a coincident surfaces problem here...try using < 0, 18.001, 0>
in the second cylinder.
Christopher James Huff
Date: 14 Mar 2001 20:28:39
Message: <chrishuff-D2DFC9.20241514032001@news.povray.org>
In article <3ab01033$1@news.povray.org>, "John M. Dlugosz"
> source a tad, nothing I can use with strum.  I posted the code in a
> reply to Ken.
You have a quartic object! This seems to be the source of the
problem...using "sturm" in it eliminates the line in my tests.
There are several other problems as well..."refraction" and "caustics"
are no longer used in a finish{} statement, "refraction" is now "ior",
and both are in interior{}. You have several coincident surfaces
problems...mainly with cylinders and differences. You are missing a
semicolon at the end of the declaration for "ft". However, the scene
seems to render fine...but these should be fixed.
Date: 15 Mar 2001 19:51:18
Message: <3ab16386$1@news.povray.org>
That's not a coincident surface -- that's the top and bottom of cyl's with
different radii.  I agree that would be a problem if the top edge were in
the frame, but we're looking at the inside curve of the smaller one.
I tried it anyway, and it makes no difference.
--John
news:chrishuff-C04E3E.20015214032001@news.povray.org...
> > difference {
> >    intersection {
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 15 Mar 2001 20:00:14
Message: <3ab1659e$1@news.povray.org>
That was it!  It never occured to me that the problem would be in a
different object than the one the scratches seemed to be on.  The glass lamp
base is the one that needed "sturm", not the back wall.
Thanks for the pointers.  I've updated some of the old syntax already, but
pointed you to a copy I made earlier, without all my current mess in it from
playing around.
The warning "Refraction value unnecessary to turn on refraction" is hard to
understand.  Does that mean that if ior is present in the interior, then
refraction is indeed ON and this statement is unnecessary?
--John
news:chrishuff-D2DFC9.20241514032001@news.povray.org...
> > reply to Ken.
Date: 15 Mar 2001 20:53:29
Message: <chrishuff-441B1A.20480915032001@news.povray.org>
In article <3ab1659e$1@news.povray.org>, "John M. Dlugosz"
> hard to understand.  Does that mean that if ior is present in the
> interior, then refraction is indeed ON and this statement is
> unnecessary?
Yes. You do not need any refraction stuff in the finish, just give an
ior value in the interior and refraction will be turned on.
Date: 15 Mar 2001 21:03:11
Message: <chrishuff-DDDCE0.20575015032001@news.povray.org>
In article <3ab16386$1@news.povray.org>, "John M. Dlugosz"
> different radii.
There *are* coincident surfaces...the cylinders have different radii,
but that doesn't make any difference, the surfaces of the ends of the
cylinders coincide. Take another look...the end caps of the 11.5 unit
radius cylinder are completely within the end caps of the 12 unit radius
one. The difference in radius (and the plane in the intersection object)
just changes the amount of area that is coincident.
I figured out it wasn't a problem when I looked at the complete scene
file and saw the quartic.
Date: 17 Mar 2001 00:50:29
Message: <3ab2fb25$1@news.povray.org>
Is that a problem if that isn't in the scene?
--John
Date: 17 Mar 2001 10:27:01
Message: <chrishuff-9E1A21.10212917032001@news.povray.org>
In article <3ab2fb25$1@news.povray.org>, "John M. Dlugosz"
It could be if the objects are transparent or partly transparent, or if
there are reflections in the scene. It doesn't seem to bother this one,
but avoiding coincident surfaces is a good habit to get into.
Date: 18 Mar 2001 21:53:55
Message: <3ab574c3@news.povray.org>
I thought about that later, too.  I'll keep that in mind, thanks.
