POV-Ray : Newsgroups : povray.unofficial.patches : Crackle pigment in functions Server Time
5 Jul 2026 18:58:04 EDT (-0400)
  Crackle pigment in functions (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Crackle pigment in functions
Date: 23 Nov 2000 09:09:19
Message: <3a1d250f@news.povray.org>
Gail Shaw <gsh### [at] monotixcoza> wrote:
:  eval
  That slows down a lot.
  Put a max_gradient by hand.
Date: 23 Nov 2000 11:31:09
Message: <3a1d464d@news.povray.org>
news:3a1d250f@news.povray.org...
> :  eval
    I've been meaning to ask, how does one calculate a max_gradient? I've
been just guessing and testing. But it seems that some folk have specific
values that they use.
    In other words, mine always end up as round numbers or simple divisions
(2.5, 10, 3.25) but I have seen other people who use things like 12.23937
which leads me to think that they did some sort of calculation.
Date: 23 Nov 2000 12:02:14
Message: <3a1d4d96$1@news.povray.org>
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:3a1d464d@news.povray.org...
Dunno what anyone else does - when I'm happy with the shape of my iso I set
a ridiculously high max_gradient, use eval, and then remove eval and replace
max_gradient with the value returned by eval. I tend to add 0.1 to the eval
"just in case".
Date: 23 Nov 2000 12:42:47
Message: <3a1d5717$1@news.povray.org>
set
replace
    Huh...? "returned"? I guess I need to pay more attention to the message
window...
Date: 23 Nov 2000 13:22:31
Message: <3a1d6067@news.povray.org>
Bill DeWitt <the### [at] earthlinknet> wrote:
:     Huh...? "returned"? I guess I need to pay more attention to the message
: window...
  When you use eval, the calculated max_gradient is output to the message
window when the rendering finishes. Somewhere there.
Date: 23 Nov 2000 13:50:39
Message: <3a1d66ff@news.povray.org>
BTW: If you have more Isos with "eval" in the scene - there is no output of
the max_gradient , is it?
Marc-Hendrik
Date: 23 Nov 2000 15:00:46
Message: <3A1D776B.7E98CAA9@schunter.etc.tu-bs.de>
There is (in my IsoWood demo, you get whole pages of max_gradients :-)
BTW, i had several situations when 'eval' was faster than a specified
max_gradient, don't know why though.
Date: 24 Nov 2000 02:27:25
Message: <3a1e185d@news.povray.org>
news:3A1D08D7.54E75832@enst.fr...
> Gail Shaw wrote:
> "crackle solid" has an infinite max_gradient, and the higher the
> max_gradient, the slower the render. If you really need it to be
> "solid", you might want to specify max_gradient manually, rather than
> using eval (but of course, if you lower it too much artifacts may
> appear).
Thanks, renders in 3 min without eval, looks terrible though.
I'm trying for a rough crystal look and normal crackle isn't quite
what I'm looking for.
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 24 Nov 2000 07:48:53
Message: <3A1E63B6.4AC415D9@enst.fr>
	The default max_gradient is 1. Try specifying it manually (around 40
should give acceptable results) to get a good balace between rendering
time and visual result.
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 24 Nov 2000 07:52:47
Message: <3A1E649B.7E81AF97@enst.fr>
	Either you gave a much too high value for max_gradient, or else it
varies greatly from point to point in your isosurface (I think eval
adjusts the max_gradient on a point by piont basis, whereas max_gradient
is necessarily global, therefore if there are only a couple of points
with a high gradient, eval should be faster than using this high value
for every point).
