POV-Ray : Newsgroups : povray.unofficial.patches : complicated functions Server Time
5 Jul 2026 18:37:05 EDT (-0400)
  complicated functions (Message 11 to 14 of 14)
Subject: Re: complicated functions
Date: 13 Nov 2000 01:35:29
Message: <3A0F8C00.5FC694EB@hotmail.com>
Chris Huff wrote:
> In article <3A0B61CC.86B37226@hotmail.com>, Pabs <pab### [at] hotmailcom>
> wrote:
> > Why not just use shaders to specify the isosurface funcs?
> I assume you mean replace functions with shaders...that would most
> likely be slower. Isosurface functions are designed to take a simple
> equation and return a float value, shaders take all sorts of
> instructions and calculate a color. It would also be harder to write the
> scene code...functions are a lot simpler than shaders.
> I think a syntax like this would be most useful:
> #declare Sphere =
> function(x, y, z, Px, Py, Pz, R)
>     r - sqrt((x-Px)^2 + (y-Py)^2 + (z-Pz)^2)
> The "x, y, z" variables would be the default, but you could specify your
> own variables to use instead.
I agree with all that but what if you need a pattern that cannot be
generated by a mathematical formula but by an algorithmn of some sort. -
s'pose you would just have to recompile the src with your pattern built in.
Bye
Pabs
Date: 13 Nov 2000 02:09:02
Message: <3a0f938e@news.povray.org>
Warp wrote in message <3a0bef9d@news.povray.org>...
>Mark Wagner <mar### [at] gtenet> wrote:
>: Guess what?  This works just fine in MegaPOV 0.5a!
>: #declare Fact = function{ 1 }
>: #declare Fact = function { x<1 ? 1 : x*Fact(x-1) }
>  Looks like a kludge (I suppose that the first line is to fool the parser
>to not to issue an error for the 'Fact()' call in the second line) :)
Yes, that's why it's there.
Date: 13 Nov 2000 02:54:37
Message: <3a0f9e3d@news.povray.org>
Pabs wrote in message <3A0F8C00.5FC694EB@hotmail.com>...
sort. -
built in.
you can still do this if you want, but ...
1. not everybody know C even if he know algorithm for such pattern
2. you can test your pattern before coding
3. you can make box as box{} as isosurface{} as csg{} and as own patch
imagine that you can write one function to create isosurface
for body of plant and to place flowers and leafs in while loop
ABX
Date: 13 Nov 2000 16:32:47
Message: <chrishuff-6D1DD2.16325813112000@news.povray.org>
In article <3A0F8C00.5FC694EB@hotmail.com>, Pabs <pab### [at] hotmailcom>
> in.
I think it would be a good idea to have things like loops, a "real" if
statement, etc. available in functions. I don't think it would
noticeably slow things down in functions that don't use these features,
but could expand the pattern possibilities even more. And if the ability
to use functions in the scene file is added, you could move some of the
math-intensive calculations into functions for a small parsing speed up.
This would only work for floating-point or integer numbers, no objects,
colors, or vectors...but it would still be useful.
Christopher James Huff
