POV-Ray : Newsgroups : povray.unofficial.patches : No more motion blur on MegaPov 1.0 ? Server Time
6 Apr 2026 22:04:45 EDT (-0400)
  No more motion blur on MegaPov 1.0 ? (Message 1 to 10 of 21)
Subject: No more motion blur on MegaPov 1.0 ?
Date: 4 Feb 2003 03:42:26
Message: <3E3F7CFD.4020700@domain.invalid>
Well, here is a piece of my scene :
#version unofficial MegaPov 1.0;
#declare rad=off;
#declare radquality=0;
#declare r1 = seed(33);
#declare testcamera=on;
#declare odavid=off;
#declare dotrees=off;
#declare ocoureur=on;
#declare ovicki=off;
global_settings {
         motion_blur 10,10
         #if (rad)
                 #switch (radquality)
                 #case (1)
                     radiosity{
                       pretrace_start 0.08
                       pretrace_end   0.01
                       count 130
                       nearest_count 5
                       error_bound 0.3
                       recursion_limit 1
                       low_error_factor 0.5
                       gray_threshold 0.0
                       minimum_reuse 0.015
                       brightness 1.0
                       adc_bailout 0.01/2
                       normal on
                #break
                #case(0)
                 #warning "rad quality 0"
                     radiosity{
                       pretrace_start 0.08
                       pretrace_end   0.01
                       /*count 50
                       error_bound 0.5
                       recursion_limit 1*/
                #break
MegaPov give me a error message on "motion_blur 10,10" saying that
motion_blur is an undeclared identifier. And I didn't found any
motion_blur section in megapov's documentation.
So ?
Subject: Re: No more motion blur on MegaPov 1.0 ?
Date: 4 Feb 2003 03:56:56
Message: <9hvu3vgoairvsgtsvd8trkbgt6b9i8h9be@4ax.com>
MegaPOV 1.0 is a rewrite. Some features has to be ported again or has to be
rewritten using features introduced in POV-Ray 3.5 and considering notes from
previous (below 1.0) MegaPOV existence. Whole old MegaPOV took about 3 years.
MegaPOV rewrite was about 2 monts mostly concerned on setting up environment
for further development + collecting 3.5 compatible patches + manual. Next 1.1
version will surely have extended set of patches. But I'm not sure about
motion_blur patch.
ABX
Date: 4 Feb 2003 04:45:59
Message: <3E3F8BE1.9040600@domain.invalid>
> motion_blur patch.
> ABX
It's a shame .....
Date: 4 Feb 2003 04:55:27
Message: <3E3F8E0F.2A818F15@gmx.de>
> It's a shame .....
You are free to add it yourself - both the old and the new megapov sources
are freely available.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 4 Feb 2003 05:12:35
Message: <b64v3vg1aqf29umijfd29gdl9rsj4ornm1@4ax.com>
On Tue, 04 Feb 2003 10:46:09 +0100, use### [at] domaininvalid wrote:
> It's a shame .....
Yes, it's a shame that volounteers have limited time becouse of real life.<g>
ABX
Date: 4 Feb 2003 07:34:23
Message: <3E3FB35A.8090307@nospam.free.fr>
>>It's a shame .....
> ABX
I understand why some features are unimplemented in megapov 1.0. But I
think it's a shame that there is no documents about features removed
from Megapov 1.0
BTW, i'm currently adding projects support on megapov
Date: 4 Feb 2003 07:43:25
Message: <18dv3vc20o06438hrs1c0qhniic0gq1183@4ax.com>
On Tue, 04 Feb 2003 13:34:34 +0100, Benoit SERRA <ben### [at] nospamfreefr>
> from Megapov 1.0
what's wrong with http://megapov.inetart.net/manual/news.html ?
what you mean ?
ABX
Date: 4 Feb 2003 09:01:47
Message: <3E3FC7D6.4010708@domain.invalid>
>>from Megapov 1.0
There is not the lists of features on standby.
> what you mean ?
When you are editing a included file, render this file launch the render
of the main file. That is for the first release. The goal of this
project is to add a VC6 like project support on megapov.
> ABX
Date: 4 Feb 2003 10:37:19
Message: <gjlv3v86lvbsnr4o4bdtmj0cvqmeamjrak@4ax.com>
But You have asked for document about "features removed from Megapov 1.0". All
notes about MegaPOV 1.0 stays clear it is a rewrite from clean 3.5 sources
which means _all_ features are removed (except those implemented in 3.5).
Nothing particular is 'on standby' list. Feature requests (like your), free
time, available 3.5 compatible patches and bugfixes - that's what defines such
list. You are free to help in your favorite way.
ABX
Date: 4 Feb 2003 12:23:11
Message: <3E3FF6FE.CC36F1AA@gmx.de>
> from Megapov 1.0
As ABX said there is nothing removed from MegaPOV.  If you are interested
in features from MegaPOV 0.x that are not in MegaPOV 1.0 for whatever
reason you should get the old MegaPOV source and documentation:
http://nathan.kopp.com/patched.htm
