POV-Ray : Newsgroups : povray.unofficial.patches : Warp transform crash. Server Time
15 Aug 2025 13:29:57 EDT (-0400)
  Warp transform crash. (Message 1 to 3 of 3)
Subject: Warp transform crash.
Date: 13 Mar 2001 10:35:27
Message: <3AAE3DB0.F0D1EA00@skynet.be>
This little scene make WinMegaPOV 0.7 crash at the end of the
rendering.  Any other transform within warp causes the crash also.
#version unofficial MegaPov 0.7;
camera {location <10,10,8> direction z*6 look_at <0,1,0>}
light_source {<50,40,30> White*2}
#declare Pig_Wood = pigment {
  wood
  color_map {[0 Black][1 White]}
  warp {turbulence .1 scale 5}
sphere {<0,1,0>,1.7 pigment {Pig_Wood}}
Subject: Re: Warp transform crash.
Date: 14 Mar 2001 06:35:39
Message: <3AAF57AF.A8063E99@aetec.ee>
>   wood
Crash is caused by attempt to release warp's transformation structure
memory twice. And memory is released twice due to incorrect warp copy
implementation:
transformation matrix is copied in the beginning of Copy_Warps function,
but thereafter warp structure is copied with memcpy, so this pointer to
its own transformation matrix is overwritten and will point to
transformation matrix from source and memory, which is allocated for new
copy transformation, is lost.
In order to correct this, transformation copy should be performed after
warp copy, i.e. lines
#ifdef TransformableWarpsPatch
    New->Warp_Transform = Copy_Transform(Old->Warp_Transform);
#endif
should be after switch block in Copy_Warps.
Date: 14 Mar 2001 08:34:52
Message: <3AAF72EB.3C9DDCEA@skynet.be>
> implementation:
Nice !  One more squashed bug !  Thanks.
Mael, if you read this, I'll be immensely grateful if you included
that correction into your next MLPOV release :-)
Fabien.
