Thorsten Froehlich <tho### [at] trf de> wrote:
: The return is missing...
The standard says that the return is optional (don't ask me why).
: Total: O(n * log(n) + n * log(n))
This is equal to O(n * log(n))
: I can get:
: Total: O(2 * n + n * log(n))
This is also equal to O(n * log(n))
So in terms of O both ways are equally fast.
: How? That is simple: I read in the words. Then sort them and then just
: count when retrieving.
But it uses more memory (specially if there are many repetitions).
: Of course I can do this using the STL (see below)! But your example shows
: something dangerous you forgot: the STL can trick you into thinking you
: have found a good algorithm, but in fact yours is nearly log(n) times slower
: than mine for most cases (for log(n) > 2)!
The O-notation doesn't know the term "log(n) times slower" if the speed
is already at least O(log(n)).
My version and your version have both the same O value and there's a good
reason for this in this case: Your version can be a lot slower when the
input is very big and there's a lot of repetition (imagine that the input
is "word1 word2 word1 word2..." millions of times). The speed is still
O(n*log(n)) in relation with the size of the input, but the speed factor can
vary a lot.
: Hmm, lets see, you need (runtimes from the C++ Prog. Lang 3rd Ed. page
: 464)...
: For inserting: O(n * log(n))
: For retrieval: O(n * log(n))
By the way, you are wrong here.
It's true that retrieval is O(n*log(n)), but an operator++() of the
iterator is O(1), so the retrieval of the whole tree is O(n) in my case.
: No, it is a clear which one is faster, just my notation for the total was
: incorrect: See my later posts explaining it in more detail.
You had another mistake (which I mentioned in another response).
The total retrieval time in my case is O(n), not O(n*log(n)).
In article <39baafd0@news.povray.org>, Warp <war### [at] tag povray org>
wrote:
> Do you use the string class? Do you use streams? Do you use any
> standard function?
I actually use strings so rarely that I haven't bothered to learn more
than the very basics of the string class...I do plan on learning it
though.
I do use streams, and other standard functions.
> Do you know exactly what does each one of them do?
Not all of them, but I try to find out if I can. And none of them have
the learning curve the STL does, and some(streams and/or some of the
standard functions) are almost completely necessary for writing useful
platform-independant programs...the STL isn't. I don't think this is a
valid comparison.
And why such a strong reaction to my wanting to know the data structures
and algorithms behind the STL before learning the STL itself? The STL
can make life easier *for those who already know it*, and for those who
plan on programming only in C++, but it is definitely not necessary. I
do plan on learning it eventually, I never said it wasn't useful, I just
don't need to use it right now.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
Chris Huff <chr### [at] mac com> wrote:
: And why such a strong reaction to my wanting to know the data structures
: and algorithms behind the STL before learning the STL itself?
I'm sorry.
My strong reaction was not to that. Of course it's important to know how
does a class work before using it. For example, I myself didn't use the
deque class in my programs until someone told me exactly how does it work,
although people had recommended me to use it for a specific task. After
I was aware of how it works I realized that it really is perfect for that
specific task and I started using it.
My strong reaction was to the negative attitude against the STL which you
showed (or at least I got that impression). Nothing personal :)
Btw, the good think about the STL classes is that they are all very
similar. Once you learn how to use one of them you'll probably be able to
immediately use almost any of the others as well.
And iterators are just brilliant.
In article <39bab3c5@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> : 464)...
OK, so Stroustrup is wrong? Maybe you found try finding out that he is
right for yourself. Just change your loop to:
for(wlist_t::iterator i=words.begin();
i!=words.end();)
cout << i->first << ": " << i->second << endl;
i++;
Now set a breakpoint at i++ and step into the function. Go down until you
find a loop. If you can't find a loop, I would really like to know which
data structure your library uses to store maps (I assume it is a tree
structure).
Thorsten
e-mail: tho### [at] trf de
In article <39bab424@news.povray.org> , Warp <war### [at] tag povray org> wrote:
No, it is O(log(n)) for each ++ operator, see my other post!
Thorsten
In article <39bab334@news.povray.org> , Warp <war### [at] tag povray org> wrote:
Yes, it uses more memory, but in case you overlooked it, in one of my posts
I prove (using limits) that the worst case of your method will be slower for
a big enough n.
In case you start mentioning memory allocation time is not constant,
consider that I know the size of memory needed in advance, so I just need
one allocation for loading everything into memory!
Did I use big-O notation here? I can't see it. To repeat my other post
(also mentioned above):
lim 2n lg n > lim 2n + n lg n
n->oo n->oo
lim n lg n > lim 2n
n->oo n->oo
I agree that my language is not very good at explaining the speed
difference, but I think "nearly log(n) times slower" describes the above
very well!
> vary a lot.
Yes, but as I mentioned before, my only mistake was adding them up in the
total and leaving the big-O around it. I never said "O(n * log(n) + n *
log(n)) < O(2 * n + n * log(n))" or even "O(n * log(n)) < O(n * log(n))".
Just remove the big-O around the totals, and everything is correct!
I really should have cared more and we wouldn't have this argument about the
total big-O which has nothing to do with your implementation being slower
for a big enough n, which is all I wanted to show!!!
In fact you are falling in the same trap I fell at first when replying to
Ron: Trying to compare these two functions based on big-O notation! But
you simply cannot compare two functions with the same big-O with each other
using big-O. Other methods are needed, i.e. limits will solve the problem
for the worst case very well.
Thorsten
In article <39bab87c@news.povray.org> , Warp <war### [at] tag povray org> wrote:
It is easy to make the wrong assumptions about them, i.e. how fast they
really are for some data structures. Nevertheless, they are really useful!
Thorsten
In article <39baaf56@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> Believe me, the error messages of gcc are MYSTICAL! :)
> For example, can you say what causes this error message?
> request for member `clear' in `x', which is of non-aggregate type
> `string ()()'
Hmm, this is a funny error message. What is the cause? I am curious!
Thorsten
In article <39bab071@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> : Is this by any chance the only example you have? ;-)
> Yes. And why not? I could write more similar examples, but what would
> be the point? I think one is enough.
I think this example is very abstract in what it does is a typical "demo
application", and the map data type is rather hard to understand without any
explanation. Some example showing a more "common" known data type like a
list and some string operations would probably be more impressive.
Thorsten
In article <39bab7db@news.povray.org>, Warp <war### [at] tag povray org>
> you showed (or at least I got that impression). Nothing personal :)
You mean what I was saying about using other languages? Sorry that it
wasn't clear what I meant...at least I know not to take up writing as a
profession. :-)
> > `string ()()'
My bet is: forgotten parenthesis (ie: "x.clear;" instead of
"x.clear();")
Jérôme
******************************* Jérôme M. BERGER
* Doctor Jekyll had something * mailto:ber### [at] iname com
* to Hyde... * http://www.enst.fr/~jberger
> n->oo n->oo
> lim n lg n > lim 2n
> n->oo n->oo
This doesn't make any mathematical sense since all four limits are
infinity and therefore can't be compared. What can be said is that for a
big enough n, you have:
2n lg(n) > 2n + n lg(n)
and
n lg(n) > 2n
Moreover your implication goes the wrong way (ie the second inequation
implies the first, not the other way round).
Limits won't solve the problem at all since they can't be compared.
OTOH you can probably get away with saying "for a big enough n..."
I'm not trying to say that one is better than the other, I haven't
computed it and I don't intend to. I'm just pointing out that this
particular argument doesn't work (at least in the way it is presented).
Jérôme
> > : 464)...
I don't know what Stroustrup said, but according to the STL
documentation here: http://www.sgi.com/Technology/STL/trivial.html
> The complexity of operations on trivial iterators is guaranteed to be amortized
constant time.
Jérôme
:> request for member `clear' in `x', which is of non-aggregate type
:> `string ()()'
: Hmm, this is a funny error message. What is the cause? I am curious!
This code causes it. Can you see what is the mistake?
#include <string>
using namespace std;
int main()
string x();
x.clear();
:> And iterators are just brilliant.
: It is easy to make the wrong assumptions about them, i.e. how fast they
: really are for some data structures. Nevertheless, they are really useful!
It's the idea behind the iterators that make them so brilliant.
They work like pointers (but are of course much safer). This means that
you can read the same data container from different places using different
iterators without them interfering each other.
A mistake made often by people is to create a data container and then
add some methods like "getFirst()" and "getNext()". This has the serious
problem that you can't read the container from different places without
each of them interfering the others. But as iterators work like pointers,
they can be used independently.
Also iterators are very independent of the data container they are
associated to. This means that you don't have worry how to get to the next
item; you just make a ++ and you are in the next item, no matter if the
container is a list, a vector, a tree or whatever.
This means that general algorithms that work for most STL containers can
be made (and they have been made in the <algorithm> include file).
For example if you want to sort your items you just call:
sort(myCont.begin(), myCont.end());
It doesn't matter if myCont is a vector, a list, a deque or whatever (for
binary trees it makes no sense since they are already sorted; also the STL
list has an inner sort which is more efficient since it only changes
pointers and doesn't need to copy the items, but the above command should
work for lists as well).
If you want to sort your container in reverse order, it's easy:
sort(myCont.rbegin(), myCont.rend());
(Btw, the fact that rbegin() returns an iterator to the same item as end()
and that rend() returns an iterator to the same item as begin() is very
confusing until you understand how they really work.)
Also copying data from one container to other is very easy. For example:
vector<int> myVector(myCont.begin(), myCont.end());
It doesn't matter what myCont is, as long as its iterator supports
operator++().
This last thing is specially useful in this case:
int main(int argc, char* argv[])
{ vector<string> CommandLine(argv, argv+argc);
This is so because regular pointers work as iterators as well (not a
big surprise).
: Now set a breakpoint at i++ and step into the function. Go down until you
: find a loop. If you can't find a loop, I would really like to know which
: data structure your library uses to store maps (I assume it is a tree
: structure).
It's true that the operator++ has to make several steps in some cases but
only when it has to go backwards in the tree. When going forward it has to
make just one step. It has to make log(n) steps backwards only once (when
going from the largest item which is smaller than the root item to the
root item). It has to make log(n)/2 steps two times. And so on.
What is the amortized O()-time for ++ then?
Btw, using some extra memory it could be possible to avoid all extra steps:
By putting a pointer to the next item in the walk in each item.
> #include <string>
> int main()
> string x();
This line doesn't define a variable of type string but a function with
no arguments that return a string and whose code is assumed to be given
elsewhere (except that I'm surprised that this works inside another
function, I would have understood better if "string x();" was before
"int main()").
> x.clear();
But this should work: "x().clear();" (assuming you've got the function
x defined elsewhere). Hey, I wasn't that far off! :))
Jérôme
In article <39BCACF2.FEB14C46@enst.fr> , Jérôme Berger
Hmm, maybe you are forgetting some fundamental things here...
2n lg n > 2n + n lg n | : n lg n
n lg n > lim 2n
because n lg n can never be 0 in this case (so the division is legal). Of
course I am just silently dropping the + 1 here and some other changes to
the function because of the division.
> and
> n lg(n) > 2n
Nope, you can do the following (as what I am up to is not a result, but only
a relative comparison of the growth rate):
n->oo n->oo
lim 2n lg n - 2n + n lg n > 0
n->oo
lim n lg n - 2n > 0
n->oo
Thorsten
In article <39bcdb54$1@news.povray.org> , Warp <war### [at] tag povray org> wrote:
> #include <string>
> int main()
> string x();
> x.clear();
Oh yes, that is one of the classics that don't give any useful compiler
error message. At least now I know what it looks like in gcc, neither
Visual C++ nor CodeWarrior give a better error message <sigh>
Thorsten
> n lg n > lim 2n
All right, then how do you justify the first inequation? The valid
demonstration is:
lg(n) > 2 (for n > 3) | * n
n lg(n) > 2n | + n lg(n)
> > and
> > n lg(n) > 2n
> n->oo n->oo
I wasn't really speaking about the reasoning. My point is that you
can't compare two infinite limits. The valid reasoning is to say that
for n big enough (in this case "big enough" means greater than 3) you
have those equations (without the limits). Or else redefine clearly what
you mean by:
lim ...
n->oo
since you're not using the standard definition.
Again it's more a complaint about the form of your reasoning (which is
wrong) than with the content (which for this part is right, I haven't
looked into the rest so I can't speak about the whole)
Jérôme
This depends on implementation. My favorite map (the one I use here) is
O(1) for each ++ operator, at the expense of a bit more bookkeeping at
insertion and deletion time. The bookkeeping is also O(1), though, so
it's dwarfed by the O(log n) the insert or delete already takes.
Whether implementation is prescribed by STL is something I don't know; I
haven't bothered to learn about STL yet as the compiler I'm forced to use
doesn't implement it (MSVC 1.52, the last 16-bit compiler MS made. Low-level
programming on Win9x is pretty much required to be 16-bit.)
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
>: structure).
amortized time is still O(log(n)) in that case, unless I missed something.
This is precisely what my implementation does. The only thing I find lacking
in my implementation is the interface; the iterator is not separate and the
usage is confusing at best. Neither of those two flaws are my doing, however;
I was writing a more robust and efficient implementation of a class that was
designed by a drooling moron on crack (spelled consultant) before I started
here. The exact depth of the consultant's stupidity is unplumbed, but suffice
to say that they thought the best implementation was an unsorted array, with
O(1) insertion, O(n) deletion, and O(n) lookup per element. When this proved
to be too slow for the purpose, they "fixed" the problem by adding a cache to
keep the five (no, the cache size was not configurable) most recent results.
You are missing something: The iterator doesn't have to start at the
root of the tree (assuming the map is implemented as a tree)
to find the next item, so the the search time is generally much
faster than log(n).
In fact, for a splay tree, it only has to follow one pointer.
For a binary tree where each node has a pointer to its parent, it is
a bit more complicated: In 50% of the cases, the current node will be
the left leaf, so two pointer operations (up, right down) are needed.
In 25 % it is the right leaf of a node on the left of its parent, so 4
operations (up, up, right, left) are needed, etc:
1/2 *2 + 1/4 * 4 + 1/8 * 6 + 1/16 * 8 ...
works out to exactly 4, which is also O(1).
Oops, I just noticed that only my leave nodes have data, but I'm too
lazy to calculate this now for a normal binary tree, and it should even
be better, anyway.
Note that a binary tree without "up" pointers doesn't have any way
to get from one node to the next, so the iterator will have to do
additional bookkeeping in this case.
hp
_ | Peter J. Holzer | Nicht an Tueren mangelt es,
|_|_) | Sysadmin WSR | sondern an der Einrichtung (aka Content).
| | | hjp### [at] wsr ac at | -- Ale### [at] univie ac at
__/ | http://www.hjp.at/ | zum Thema Portale in at.linux
Jérôme Berger <Jer### [at] enst fr> wrote:
: (except that I'm surprised that this works inside another
: function
The C standard says that a function definition can be done inside another
function. If done so, the scope of that function definition is only inside
that other function (it has a clear modular reason).
Thus, the C++ standard supports it as well.
> : function
One of the big differences between C and Pascal is precisely that the
Pascal standard allows definitions of function inside another while the
C standard doesn't (or so I always thought). Something to do with the
ability to return a function as the result of a function call. I don't
know the exact position of C++ in this respect but I assumed it followed
the C standard.
Jérôme
>: function
>that other function
No, only function *declarations* inside other functions are permitted,
but not function *definitions*.
Thus:
int main(void) {
extern void foo(void);
void();
return 0;
is allowed, but:
int main(void) {
void foo(void) {
printf("hello\n");
void();
return 0;
is not.
There is a good technical reason why it is not allowed. It makes
function pointers very difficult to implement and unintuitive to use.
Nevertheless, gcc implements it as an extension.
hp
Peter J. Holzer <hjp### [at] sikitu wsr ac at> wrote:
: No, only function *declarations* inside other functions are permitted,
: but not function *definitions*.
I meant what you are saying, ie. declaration. I know that you can't put
the body of the function inside another function.
I really don't know the difference between the words "declaration" and
"definition".
Usually when I have to refer to the body of the function I use
the word "implementation". It may be wrong, though.
> "definition".
In C, a declaration tells the compiler what a "thing" (an object[1] or a
function) looks like, while a definition creates it. Every definition
is also a declaration, but not vice versa.
No it isn't wrong. It just isn't the word used when one talks about the
C programming language. Modula-2 for example has "definition modules"
and "implementation modules". Obviously when someone talks about a
"definition" in a modula program, he means something else than someone
talking about a "definition" in a C program.
Unfortunately, often a single word is used for different concepts, and
different words are used for the same concepts. What is meant has to be
guessed from context.
hp
[1] Just as another example: An "object" in C is just a place to store
values (either a variable or a malloced area). It has nothing to do with
object-oriented programming.
_ | Peter J. Holzer | access ist als datenbankserver fraglos noch
|_|_) | Sysadmin WSR | ungeeigneter als beispielsweise EDIT.COM,
| | | hjp### [at] wsr ac at | und das primaer aufgrund der erzeugung
__/ | http://www.hjp.at/ | falscher erwartungshaltungen. frank paulsen
