POV-Ray : Newsgroups : povray.unofficial.patches : Noisy thoughts Server Time
7 Apr 2026 11:34:27 EDT (-0400)
  Noisy thoughts (Message 17 to 26 of 26)
Subject: Re: Noisy thoughts
Date: 29 Sep 2000 06:19:14
Message: <39D46C9D.907A461A@enst.fr>
> Nathan Kopp wrote:
> > Could this be done using shift operators (is the period a multiple of 2)?
>         That only works once the double has been changed into a long, but there
> might be something I can do there... I'll have to look at it in more
> detail.
	That did it! The time (with the range fix) is now at 461.67 :) I don't
know why I had decided that it wouldn't work with negative numbers when
I first looked at it. Of course the range is still limited to what a
"long" can contain, but that's pretty big...
	Now I've got an interresting puzzle: knowing that "x_ix" and "x_jx" are
both doubles, why is this:
x_jx = 1 - x_ix;
faster than this:
x_jx = 1.0 - x_ix;
	I would understand slower (since there is a conversion to do) or same
speed (if the compiler is smart enough to do the conversion at compile
time), faster??
Date: 29 Sep 2000 07:25:17
Message: <39d47c1d@news.povray.org>
news:39D46C9D.907A461A@enst.fr...
> x_jx = 1 - x_ix;
> faster than this:
> x_jx = 1.0 - x_ix;
Can I guess? (I know practically nothing about C, and absolutely nothing
about it's internals). Assuming that there is nothing different about the
output of the calculation, could it be that, when x_ix is an integer value,
the first example will perform an integer calculation, whereas the second
example will always perform a floating point calculation?
My second guess would be that with the first example the compiler "knows"
that the result will have no more decimal places than are held by x_ix,
since 1 is an unequiviqual integer. With the second example, it does not
view 1.0 as an integer and therefore makes no assumption about the degree of
precision required in the answer. Am I close? Not even warm? Freezing cold?
An idiot?
Third guess (and this would imply some idiocy on the part of the compiler).
When it sees 1.0, it realises that it is an integer and first translates it
to 1 and then translates it back to a float for the purpose of the
calculation. With the first example, it is able to skip the first part of
this process.
BTW Sorry for the anthromorphisism.
Date: 29 Sep 2000 09:43:36
Message: <39D49C7F.7CCBBAAC@enst.fr>
	No no no. x_ix and x_jx are floating point numbers in both examples so
both cases require a floating point computation...
> An idiot?
	Might be... (that this is the explanation, not that you're an idiot :)
> this process.
	No, I get similar result if I use a variable instead of the constant
"1" or "1.0" and there is no possible doubt on the type of a variable...
Date: 29 Sep 2000 10:13:42
Message: <39d4a396$1@news.povray.org>
news:39D49C7F.7CCBBAAC@enst.fr...
the
value,
second
So C will never use integer math on a variable declared as float, even when
the value of the float is an integer?
Date: 29 Sep 2000 10:48:29
Message: <39D4ABB9.43F155FB@enst.fr>
	I don't think it will, but anyway in this case, the values were not
integers...
Date: 29 Sep 2000 11:06:39
Message: <39d4afff$1@news.povray.org>
news:39D4ABB9.43F155FB@enst.fr...
when
> integers...
Never? - I was slightly assuming that the value of x_ix changed. What I
meant was that if x_ix went through the series 0.5, 0.6, 0.7, 0.8, 0.9, 1.0,
1.1, etc. then the calculation when x_ix = 1.0 could be quicker. Of course,
it wouldn't be much of an optimisation since it would only (in the above
example) speed up one calculation out of every 10.
Actually, in the language I most commonly code in (a proprietry db lang.
based on pascal I think), the speed difference you noticed would be exactly
what I'd expect. Although a side effect would be that the result would alway
be an integer (the language does not require pre-declaration of data-types).
So: 1 + 1.5 = 2, but 1.0 + 1.5 = 2.5 since the result is data-typed to match
the data type of the first input. (therefore 1.5 + 1 = 2.5)
Date: 29 Sep 2000 12:27:33
Message: <39D4C343.D0AB9AC@aetec.ee>
> > detail.
Instead of shifting bit masking with & could be considered as well...
> x_jx = 1 - x_ix;
> faster than this:
> x_jx = 1.0 - x_ix;
> time), faster??
Generate assembler code and look at it, this might give hint. I tried it
with IBM compiler and only difference is the fact, that in first case
double value 1.0 (yes, compiler converted it to double) is put into same
segment as code, on second case it was put into constant segment. This
might be one reason (loading constant segment page into memory or
something like this).
But I won't count very much on this speed-up obtaining, as different
compilers on different platforms might give different results. More
clear would be using 1.0.
Date: 2 Oct 2000 10:40:15
Message: <39D89E4E.2B200959@enst.fr>
	Well of course, shifting for divisions and bit masking for modulus...
	Good point, I'll try and see what gcc does...
Date: 6 Oct 2000 06:41:32
Message: <39DDAB0F.7C1182B2@my-dejanews.com>
Nathan Kopp wrote:
> Actually, the plateaus were much worse than that.  Clamping (as Warp
> described) still happens, but it used to be something like [-0.5, 1.5]
> clamped down to [0,1].
Is there a way we could have two functions,
    1)  one "[-0.5, 1.5] clamped down to [0,1].",  for all the folks
complaining about their old sky textures,
    2)  one  based on this raw [-0.5, 1.5] noise,  but
newnoise=(computersrawnoisefunction +0.5) /2
Date: 6 Oct 2000 11:34:17
Message: <chrishuff-C0BFAB.10364406102000@news.povray.org>
In article <39DDAB0F.7C1182B2@my-dejanews.com>,
That is what is done now, though it is controlled with the #version
directive.
Anyway, two noise functions are not necessary, since you can get the old
one from the new version(but you can't go the other way, and get
plateau-less noise from the old kind). Just put a space of solid
material(color, texture, pigment, etc) at each end of the blend map, and
squash the existing colors into the middle. I think this is the cleanest
and best solution, even though it does require changing some older
scenes.
But if you really want separate noise types, it could be done by
internally duplicating every feature that uses noise, and using a
"#noise_type" keyword to tell the parser which one to choose. This would
be very time-consuming to do, and messy(since it would need two versions
of bozo, wrinkles, turbulence, etc, etc...), but it would allow you to
use both types of noise in one scene, and would be the cleanest from the
user's point of view.
A much simpler way would be a global_settings keyword, but that would
force everything in the scene to use the same noise type. This could be
a problem if you are using include files which depend on a different
noise type.
Christopher James Huff
