POV-Ray : Newsgroups : povray.unofficial.patches : Noisy thoughts Server Time
7 Apr 2026 12:05:36 EDT (-0400)
  Noisy thoughts (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Noisy thoughts
Date: 27 Sep 2000 07:14:25
Message: <39d1d67f@news.povray.org>
: 	I guess it's because it requires computing three modulus on doubles
: which is very slow (a division + a floor + a difference)*3
  Why not just:
if(val>1) val=1;
else if(val<0) val=0;
Date: 27 Sep 2000 07:22:52
Message: <chrishuff-CF0353.06250427092000@news.povray.org>
In article <39d1d67f@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
>   Why not just:
> if(val>1) val=1;
That makes the plateaus, which are what started this whole thing.
Christopher James Huff
Date: 27 Sep 2000 07:27:03
Message: <39d1d986@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: That makes the plateaus, which are what started this whole thing.
  I was responding to someone who explained why clamping is so slow (or
at least I think so).
Date: 27 Sep 2000 08:53:43
Message: <39D1EDD5.C4C6E5D2@enst.fr>
	No, but I think I see where the confusion comes from. You were thinking
of the values returned by the Noise function (which are something like
-0.01 to 1.01 and are truncated in the way you said) and the values
where Noise can be computed (must be bigger than -10000, and I don't
know the upper limit but there's one). In this case the only solution is
to take advantage of the periodicity of Noise and to bring the values
inside the acceptable range using a modulus (or something similar).
Date: 27 Sep 2000 19:34:55
Message: <39d2841f@news.povray.org>
Actually, the plateaus were much worse than that.  Clamping (as Warp
described) still happens, but it used to be something like [-0.5, 1.5]
clamped down to [0,1].
> and the values
Could this be done using shift operators (is the period a multiple of 2)?
-Nathan
Date: 28 Sep 2000 04:29:55
Message: <39D30181.27F490CF@enst.fr>
	That only works once the double has been changed into a long, but there
might be something I can do there... I'll have to look at it in more
detail.
Date: 29 Sep 2000 06:19:14
Message: <39D46C9D.907A461A@enst.fr>
> detail.
	That did it! The time (with the range fix) is now at 461.67 :) I don't
know why I had decided that it wouldn't work with negative numbers when
I first looked at it. Of course the range is still limited to what a
"long" can contain, but that's pretty big...
	Now I've got an interresting puzzle: knowing that "x_ix" and "x_jx" are
both doubles, why is this:
x_jx = 1 - x_ix;
faster than this:
x_jx = 1.0 - x_ix;
	I would understand slower (since there is a conversion to do) or same
speed (if the compiler is smart enough to do the conversion at compile
time), faster??
Date: 29 Sep 2000 07:25:17
Message: <39d47c1d@news.povray.org>
news:39D46C9D.907A461A@enst.fr...
> x_jx = 1 - x_ix;
> faster than this:
> x_jx = 1.0 - x_ix;
Can I guess? (I know practically nothing about C, and absolutely nothing
about it's internals). Assuming that there is nothing different about the
output of the calculation, could it be that, when x_ix is an integer value,
the first example will perform an integer calculation, whereas the second
example will always perform a floating point calculation?
My second guess would be that with the first example the compiler "knows"
that the result will have no more decimal places than are held by x_ix,
since 1 is an unequiviqual integer. With the second example, it does not
view 1.0 as an integer and therefore makes no assumption about the degree of
precision required in the answer. Am I close? Not even warm? Freezing cold?
An idiot?
Third guess (and this would imply some idiocy on the part of the compiler).
When it sees 1.0, it realises that it is an integer and first translates it
to 1 and then translates it back to a float for the purpose of the
calculation. With the first example, it is able to skip the first part of
this process.
BTW Sorry for the anthromorphisism.
Date: 29 Sep 2000 09:43:36
Message: <39D49C7F.7CCBBAAC@enst.fr>
	No no no. x_ix and x_jx are floating point numbers in both examples so
both cases require a floating point computation...
> An idiot?
	Might be... (that this is the explanation, not that you're an idiot :)
> this process.
	No, I get similar result if I use a variable instead of the constant
"1" or "1.0" and there is no possible doubt on the type of a variable...
Date: 29 Sep 2000 10:13:42
Message: <39d4a396$1@news.povray.org>
news:39D49C7F.7CCBBAAC@enst.fr...
the
value,
second
So C will never use integer math on a variable declared as float, even when
the value of the float is an integer?
