POV-Ray : Newsgroups : povray.unofficial.patches : Persistent Variables - Help! Server Time
17 Aug 2025 05:23:02 EDT (-0400)
  Persistent Variables - Help! (Message 1 to 3 of 3)
Subject: Persistent Variables - Help!
Date: 9 Jun 2000 06:33:31
Message: <3940C7F4.BC324E5@reading.ac.uk>
Hi folks,
I'm trying to implement the falling cloth idea to do an animation. I
thought, to make things easier, I'd investigate persistent variables.
Unfortunately I must be missing something.
I've built a small test scene to show how I think I should do it, but
parsing the second frame I get a "Cannot assign uninitialized
identifier" error where I redefine the variable 'Centre' which should
persist but doen't appear to.
I'm using Megapov 0.5a.
Any help would be appreciated.
Bye for now,
	Mike Andrews.
// pv_test.pov start
#version unofficial MegaPov 0.5;
global_settings {
  max_trace_level 10
  assumed_gamma 1
background { color rgb 0.5/<15,sqrt(15),1> }
light_source {
	0*x
	colour rgb <1,.97,.95>
	translate vnormalize(<-2.5,2.1,-1>)*1.5e4
plane { y, 0 pigment { rgb 0.4 } }
#if (frame_number = 1)
  #declare Centre = <0,10,0>;
#else
  #declare Centre = Centre + 5*y;
sphere { Centre, 10 pigment { rgb y } }
	up y
	location  <-30, 10, -80>
	direction <0.0, 0.0, 1>
	angle     45
	look_at   0.5*Centre
// pv_test.pov end
; persist.ini start
Persistent_Animation=on
Final_Frame=10
Width=384
Height=512
Antialias=Off
; persist.ini end
Subject: Re: Persistent Variables - Help!
Date: 9 Jun 2000 13:51:17
Message: <1ebz4po.9q446i1elr5j4N%smellenbergh@skynet.be>
Michael Andrews <M.C### [at] readingacuk> wrote:
> Hi folks,
Look no further, it's a bug introduced in 0.5a.
If you have access to a compiler and the sources you can fix it by
moving this block of code at line 1695 in povray.c in function
init_frame_vars():
  /* NK persist - Nov 1999 */
  alreadyInitializedSymTables = 0;
to the function init_vars(), also in povray.c, doesn't matter where.
Best regards,
Smellenbergh
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
Date: 12 Jun 2000 13:37:46
Message: <39451FEA.303327D1@reading.ac.uk>
> > Hi folks,
Whew! That's a relief, I thought I was being even more stupid than
normal ...
> init_frame_vars():
Has anyone figured out all the necessaries for building the GUI Megapov
version using the Cygnus or Mingw32 compilers? I haven't heard anything
recently but I recall that a couple fo people were working on this a
while back. I was going to try myself, but others seemed to be further
along than me so I left them to it ...
> Best regards,
> Smellenbergh
Thanks for the reply,
	Mike Andrews.
