POV-Ray : Newsgroups : povray.unofficial.patches : FINAL Cornell box rendering... Server Time
17 Aug 2025 05:18:36 EDT (-0400)
  FINAL Cornell box rendering... (Message 1 to 5 of 5)
Subject: FINAL Cornell box rendering...
Date: 1 Jun 2000 17:55:52
Message: <3936DB23.7140@wanadoo.fr>
As I proposed to you a few days ago, I've converted the original
"cornell box" scene to PoV. Both have exactly the same frame. However,
don't forget that the original rendering was done in spectral space so,
because of the loss of accuracy, we have a visible colorimetric
difference.
At the same time, I fixed a few bugs in my stochastic global
illumination patch and I made a small improvement. I updated all my ZIP
files (except the doc but including a patched MegaPoV 0.5) so you can
download the last release.
The page
http://perso.wanadoo.fr/albedo/cornell.html
contents a few test rendering samples (Original from cornell -> MegaPoV
(original) Radiosity -> MegaPoV (stochastic) Radiosity a.k.a my patch)
and the PoV source code.
They're only 256x256 & no AA because I didn't have time to do more
(sorry !).
Please feel free to use this PoV source to do your own tests. I'm sure
you will find better "radiosity { }" parameters than me !
Stephane Marty
Computer Graphics Software
Subject: Re: FINAL Cornell box rendering...
Date: 2 Jun 2000 04:58:06
Message: <3937771e@news.povray.org>
I think that the walls are not white altough the word "white" is mentioned
in the cornell box page.
Date: 2 Jun 2000 05:19:26
Message: <39377B5A.7FD0@wanadoo.fr>
As I said, the colors have been converted from spectral space to RGB
space. Their "white" is not a rgb<1,1,1>.
Have a look at the original file BOX.MDLA, all the specifications are
included.
Stephane
Date: 2 Jun 2000 10:20:51
Message: <TLs3OeQ+wPxuESXtwY=CbtOyl4wB@4ax.com>
On Thu, 01 Jun 2000 23:52:35 +0200, Stephane Marty <alb### [at] wanadoofr>
>difference.
I have a few comments about your adaptation of the Cornell Box. I
noticed that in your POV code, you scaled the box dimensions down by a
factor of 10. If we will be treating this as a standard, why not keep
the same box size as the original? (Some might say the scaling has no
effect, but then I want to know even more why it was changed, if it
makes no difference?)
I noticed that you are using Cornell's synthetic rendering as your
standard. It would be better to use the actual photo of the physical
Cornell Box for comparisons. (The goal is to reproduce reality with
POV-Ray, not to emulate another rendering.) It's unfortunate that
Cornell didn't provide a nice RGB image of the original box. The only
one I found was in a 7-channel IPLab format, instead of a typical RGB
image. They offer a Matlab function to work with the IPLab format, but
I have no idea how to use it.
Can anyone figure out how to accurately convert the 7 channel IPLab
reference image into an RGB image?
What sort of procedure did you use to convert their spectral data into
RGB values? I think it needs a bit of revision. Your "white" is a bit
too pure. The original looked a bit yellowish in comparison. Your
"red" looks too pure. The original is closer to red-orange than a
simple red. The green is also different, but I'm not sure the best way
to describe it.
Don't misunderstand, I do appreciate the effort you have put into this
so far. It would just be nice to improve things a bit. For a long
time, people have been judging the rendering quality of POV-Ray, as if
they lived in a total vacuum. I think it's time we started comparing
POV to actual samples of the real world, when we want to judge its
rendering quality. What looks more interesting is not always more
accurate. Reality and people's recollection of it, are almost always
significantly different.
As for the rendering comparison, I like your illumination model the
best. It's a shame it takes so long. Perhaps a way will be found to
increase the speed?
Thanks for sharing your results with us.
Later,
Glen Berry
( Remove the "7" from 7no### [at] ezwvcom to email me. )
Date: 2 Jun 2000 15:47:19
Message: <39380E82.5F30@wanadoo.fr>
Yes, it has no effect. I started with the same scale as the original and
then, for some test reasons, I scaled it down by a factor of 10.
But, here's the original :
//	Persistence of Vision Ray Tracer Scene Description File
//      The true Cornell box...
//      PoV transcription by Stephane Marty (05/31/2000)
#version unofficial MegaPov 0.5;
#declare pov_rad=no;
global_settings
  ambient_light 0.01
#if(pov_rad)
  ini_option "+QR"
  radiosity
  { pretrace_start 0.08
    pretrace_end   0.02
    count 100
    nearest_count 5
    error_bound 1
    recursion_limit 4
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1.3
    adc_bailout 0.01/2
#else
  stochastic_global_illumination { samples 400 distribution 2 }
camera{
   location  <278, 273,-800>
   direction <0, 0, 1>
   up        <0, 1, 0>
   right     <-1, 0, 0> // width and height must be equals !
   angle 39.5
 * colors converted from spectral space.
#declare white_cornell = texture {
    finish{ diffuse 1 }
    pigment { color rgb<0.740063,0.742313,0.733934> }
#declare green_cornell = texture {
    finish{ diffuse 1 }
    pigment { color rgb<0.162928,0.408903,0.0833759> }
#declare red_cornell = texture {
    finish{ diffuse 1 }
    pigment { color rgb<0.366046,0.0371827,0.0416385> }
#declare light_color = color rgb<0.780131,0.780409,0.775833>
union {
 * floor
  triangle {
    <552.8, 0.0, 0.0>,
    <0.0, 0.0, 0.0>,
    <0.0, 0.0, 559.2>
  triangle {
    <552.8, 0.0, 0.0>,
    <0.0, 0.0, 559.2>,
    <549.6, 0.0, 559.2>
 * ceiling
  triangle {
    <556.0, 548.8, 0.0>,
    <556.0, 548.8, 559.2>,
    <0.0, 548.8, 559.2>
  triangle {
    <0.0, 548.8, 559.2>,
    <0.0, 548.8, 0.0>
 * back wall
  triangle {
    <549.6, 0.0, 559.2>
  triangle {
    <549.6, 0.0, 559.2>,
    <0.0, 0.0, 559.2>
  texture { white_cornell }
union {
 * right wall
  triangle {
    <0.0, 548.8, 0.0>,
    <0.0, 0.0, 559.2>
  triangle {
    <0.0, 548.8, 0.0>,
    <0.0, 0.0, 559.2>,
    <0.0, 0.0, 0.0>
  texture { green_cornell }
union {
 * left wall
  triangle {
    <552.8, 0.0, 0.0>,
  triangle {
    <552.8, 0.0, 0.0>,
    <556.0, 548.8, 0.0>
  texture { red_cornell }
union {
 * short block
  triangle {
    <130.0, 165.0, 65.0>,
    <82.0, 165.0, 225.0>,
    <240.0, 165.0, 272.0>
  triangle {
    <240.0, 165.0, 272.0>,
    <290.0, 165.0, 114.0>
  triangle {
    <290.0, 0.0, 114.0>,
    <290.0, 165.0, 114.0>,
  triangle {
    <240.0, 0.0, 272.0>
  triangle {
    <130.0, 0.0, 65.0>,
  triangle {
    <130.0, 0.0, 65.0>,
    <290.0, 0.0, 114.0>
  triangle {
    <82.0, 0.0, 225.0>,
  triangle {
    <82.0, 0.0, 225.0>,
    <130.0, 0.0, 65.0>
  triangle {
    <240.0, 0.0, 272.0>,
  triangle {
    <82.0, 0.0, 225.0>
union {
 * tall block
  triangle {
    <423.0, 330.0, 247.0>,
    <265.0, 330.0, 296.0>,
    <314.0, 330.0, 456.0>
  triangle {
    <314.0, 330.0, 456.0>,
    <472.0 330.0 406.0>
  triangle {
    <423.0, 0.0, 247.0>,
    <472.0, 330.0, 406.0>
  triangle {
    <472.0, 330.0, 406.0>,
    <472.0, 0.0, 406.0>
  triangle {
    <472.0, 0.0, 406.0>,
  triangle {
    <314.0, 0.0 456.0>
  triangle {
    <314.0, 0.0, 456.0>,
  triangle {
    <265.0, 0.0, 296.0>
  triangle {
    <265.0, 0.0, 296.0>,
  triangle {
    <423.0, 0.0, 247.0>
union {
 * light patch
  light_source {
    <278,548.8,279.5>
    light_color
    area_light <130, 0, 0>, <0, 0, 105>, 5, 5
    adaptive 1
    jitter
  box { <213,548.7,332><343,548.8,227> no_shadow pigment { light_color }
finish { ambient light_color*1000 } }
I don't know either, that's why I used their synthetic rendering because
it is so close to the reality.
> to describe it.
Well, I'm pretty sure the values are correct. I used my spectral space
ray-tracer. And you know, there's only very few ways to do it, it's just
that there's a HUGE difference between spectral and RGB accuracy.
In addition, there's another reason to the fact that the white walls are
not white. The light patch they used has a slight yellow tendancy in the
colour spectrum. A true radiosity preprocessor is able to compute the
global ambient light with a high level of precision. That's the case
here. And in spectral space, this accuracy is maintained all during the
entire process because the RGB conversion is only done at the end of the
process.
An image rendered in a spectral space is incredibly different than the
same ome rendered in a RGB space.
> increase the speed?
Thank you, I hope so. But maybe I won't be the guy who find it...
Stephane Marty
