POV-Ray : Newsgroups : povray.unofficial.patches : Photon and light Server Time
17 Aug 2025 12:57:24 EDT (-0400)
  Photon and light (Message 1 to 3 of 3)
Subject: Photon and light
Date: 8 May 2000 05:36:15
Message: <39168A83.A25A98A1@umh.ac.be>
A simple question:
when I use photons, I put the required lines into global settings
and into the object block and it work fine. Now I can also
add a photon block to the light source, but then, the photo map build
seems to be not the same : many more photon are stored.
So the question is: what about put or not a photon block inside
the light block
Last question: How work global photon: If I use global photon without
the photon block inside the light block, the photon map seems the same.
But If I use the photon block inside the light block (with global
written)
Megapov says "building photon map" but no number appear, what it does?
Thanks to help me.
Fabian.
Subject: Re: Photon and light
Date: 8 May 2000 12:03:39
Message: <3916e55b$1@news.povray.org>
Fabian BRAU <Fab### [at] umhacbe> wrote...
> the light block
You will usually not need to put the photon block inside a light source.
> written)
I'm not sure... that would depend on your scene.  In general, though, don't
use global photons.  They don't work correctly and you don't need them.
-Nathan
Date: 9 May 2000 04:12:47
Message: <3917C873.864B9FAB@umh.ac.be>
Thanks Nathan!
Fabian.
> > the light block
> > written)
> -Nathan
