POV-Ray : Newsgroups : povray.unofficial.patches : ANNOUNCE: Acceleration of box' normal Server Time
7 Apr 2026 22:01:34 EDT (-0400)
  ANNOUNCE: Acceleration of box' normal (Message 1 to 10 of 10)
Subject: ANNOUNCE: Acceleration of box' normal
Date: 9 Apr 2000 08:42:48
Message: <38f07ac8@news.povray.org>
Old code:
static void Box_Normal(VECTOR Result, OBJECT *Object, INTERSECTION *Inter)
  switch (Inter->i1)
    case SIDE_X_0: Make_Vector(Result, -1.0,  0.0,  0.0); break;
    case SIDE_X_1: Make_Vector(Result,  1.0,  0.0,  0.0); break;
    case SIDE_Y_0: Make_Vector(Result,  0.0, -1.0,  0.0); break;
    case SIDE_Y_1: Make_Vector(Result,  0.0,  1.0,  0.0); break;
    case SIDE_Z_0: Make_Vector(Result,  0.0,  0.0, -1.0); break;
    case SIDE_Z_1: Make_Vector(Result,  0.0,  0.0,  1.0); break;
    default: Error("Unknown box side in Box_Normal().\n");
  /* Transform the point into the boxes space. */
  if (((BOX *)Object)->Trans != NULL)
    MTransNormal(Result, Result, ((BOX *)Object)->Trans);
    VNormalize(Result, Result);
New code:
 if (((BOX *)Object)->Trans == NULL )
  switch (Inter->i1)
 else
  switch (Inter->i1)
     case SIDE_X_0: Assign_Vector(Result, ((BOX *)Object)->N_X_0); break;
     case SIDE_X_1: Assign_Vector(Result, ((BOX *)Object)->N_X_1); break;
     case SIDE_Y_0: Assign_Vector(Result, ((BOX *)Object)->N_Y_0); break;
     case SIDE_Y_1: Assign_Vector(Result, ((BOX *)Object)->N_Y_1); break;
     case SIDE_Z_0: Assign_Vector(Result, ((BOX *)Object)->N_Z_0); break;
     case SIDE_Z_1: Assign_Vector(Result, ((BOX *)Object)->N_Z_1); break;
Complete source at  page -- Box' patch -- via
http://members.xoom.com/dmilos/pov/mypovpage.htm
Subject: Re: ANNOUNCE: Acceleration of box' normal
Date: 9 Apr 2000 08:50:59
Message: <38f07cb3$1@news.povray.org>
WRONG > http://members.xoom.com/dmilos/pov/mypovpage.htm
RIGHT:  http://members.xoom.com/dmilos/prg/pov/mypovpage.htm
Sorry. I and my fingers.
Date: 10 Apr 2000 03:58:02
Message: <38f1898a@news.povray.org>
../boxes.c: In function `Box_Normal':
../boxes.c:634: structure has no member named `N_X_0'
../boxes.c:635: structure has no member named `N_X_1'
../boxes.c:636: structure has no member named `N_Y_0'
../boxes.c:637: structure has no member named `N_Y_1'
../boxes.c:638: structure has no member named `N_Z_0'
../boxes.c:639: structure has no member named `N_Z_1'
Date: 10 Apr 2000 08:41:18
Message: <38f1cbee@news.povray.org>
One part from file BOXES.H
typedef struct Box_Struct BOX;
struct Box_Struct
  OBJECT_FIELDS
  TRANSFORM *Trans;
  VECTOR bounds[2];
  VECTOR N_X_0, N_X_1, N_Y_0, N_Y_1, N_Z_0, N_Z_1; /* [DDMM] */
Entire source at: http://members.xoom.com/dmilos/prg/pov/box/boxsrc.zip
And apologize to Warp. Because I sent answer to <war### [at] tagpovrayorg>.
Replay to sender and Replay to Group are to close.
Warp <war### [at] tagpovrayorg> wrote in message news:38f1898a@news.povray.org...
Date: 11 Apr 2000 07:41:16
Message: <38f30f5c@news.povray.org>
I used the following scene to test this patch:
camera { location -z*30 look_at 0 }
light_source { <100,200,-300> 1 }
light_source { <-100,100,0> <.5,.25,0> }
light_source { <0,-300,-200> <0,.25,.5> }
#declare R=seed(0);
#declare ind=0;
#while(ind<1000)
  box
  { -.1, 1 pigment { rgb 1 }
    rotate <rand(R)*180, rand(R)*180, rand(R)*180>
    scale <.1+rand(R)*1.9, .1+rand(R)*1.9, .1+rand(R)*1.9>
    translate <-10+rand(R)*20, -10+rand(R)*20, -10+rand(R)*20>
  #declare ind=ind+1;
  It has 1000 boxes rotated, scaled and translated randomly. I rendered
it at 640x480 with aa 0.1 in this Ultra 5 with the official povray and
this patched version.
  The times were:
  Official:
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Trace:    0 hours  1 minutes   6.0 seconds (66 seconds)
    Total Time:    0 hours  1 minutes   7.0 seconds (67 seconds)
  Patched:
Time For Trace:    0 hours  1 minutes   4.0 seconds (64 seconds)
    Total Time:    0 hours  1 minutes   5.0 seconds (65 seconds)
Date: 11 Apr 2000 07:44:23
Message: <38F3102B.4A794F05@pacbell.net>
So what do you conclude from your tests ?
Date: 11 Apr 2000 10:48:59
Message: <38f33b5a@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: So what do you conclude from your tests ?
  There definitely is a speedup, but it's so small that I'm not sure if
it's worth the extra amount of memory needed for it (the box struct is
bigger now).
Date: 12 Apr 2000 03:02:44
Message: <38f41f94@news.povray.org>
** Many a little makes a mickle. **
Faster rendering or memory usage? That is the question!
Warp <war### [at] tagpovrayorg> wrote in message news:38f30f5c@news.povray.org...
> #declare R=seed(0);
> #declare ind=0;
> #while(ind<1000)
>   box
>   #declare ind=ind+1;
> #end
>   The times were:
>   Official:
>   Patched:
Date: 12 Apr 2000 07:04:39
Message: <38f45847@news.povray.org>
Dejan D. M. Milosavljevic <dmi### [at] pttyu> wrote:
: Faster rendering or memory usage? That is the question!
  The memory usage doesn't matter very much until it runs out of it. Then
less memory usage means considerable increase in speed.
  (Btw: Less memory usage _might_ mean a bit performance boost since the
cache memory misses may be rarer...)
Date: 13 Apr 2000 02:45:23
Message: <38f56d03@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:38f45847@news.povray.org...
Absolutely right.
Not always.  Hash table can be large in some cases.
