POV-Ray : Newsgroups : povray.unofficial.patches : Font Patch/Feature Request Server Time
8 Apr 2026 06:11:40 EDT (-0400)
  Font Patch/Feature Request (Message 1 to 10 of 15)
Subject: Font Patch/Feature Request
Date: 17 Dec 1999 02:13:06
Message: <3859E0AB.E4E35BB8@pacbell.net>
Greetings,
  There seems to be some talented patch warriors in the groups these
days and perhaps one of you would like to tackle a new challenge.
  How about a method of auto beveling and or rounding the face of
text objects ?
  Certainly there are methods to do this outside the text object by
using lots of CSG or it can be done by way of third party programs
but I have little doubt that it would make a lot of people happy to
have this ability as an internal function of the text object in
POV-Ray itself.
Any takers ?
Wishing you Seasons Greetings, A Merry Christmas, and A Happy New Year !
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Subject: Re: Font Patch/Feature Request
Date: 17 Dec 1999 06:26:17
Message: <385a1dd9@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
:   How about a method of auto beveling and or rounding the face of
: text objects ?
  It would be really cool if it was possible to specify the smoothness
of the surfaces of the text objects. This would be achieved by modifying
the normal of the (front and back) surface (now the surface is just flat).
Date: 17 Dec 1999 08:20:37
Message: <385a38a5@news.povray.org>
>text objects ?
For my contribution, I can dig up a paper I was reading the other
day on piecewise cubic approximation of parallels to cubic bezier
curves.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 17 Dec 1999 08:46:18
Message: <385A3EAE.30374125@pacbell.net>
> >text objects ?
> curves.
As you are one of those who would probably know how is the text object
represented internaly ?
Date: 17 Dec 1999 09:27:03
Message: <385a4837@news.povray.org>
>> >text objects ?
>> curves.
There's a good chance of it.
It's represented as a CSG union, with each glyph being a separate object.
A glyph is represented internally as a series of quadratic curves.
To test for insideness, POV first makes sure the point is between the front
and back planes of the glyph, then makes sure the projection of the point
into X,Y space falls inside the glyph representation by counting crossings.
To intersect a ray, POV first finds the intersection points of the ray
with the front and back planes.  Those points are projected onto the plane
and tested to make sure they're inside the glyph representation before
being pushed onto the intersection stack.  Finally, it projects the ray
itself into the plane (skipping the case where the ray is parallel to the
extrusion direction) and tests the projection of the ray against each curve
in the glyph representation.
Clear as mud, right?
Anyway, the result is that if you want to do bevels or rounds you need
an algorithm for finding the parallels to quadratic curves (not
cubics... guess that article won't help much.)  Ideally, the algorithm
would be fast and cheap, because it's likely to get called a lot for
testing insideness in the beveled region, and probably for doing
intersection testing as well.  I suspect rounded edges would have to
be approximated by multiple bevels with some normal modification to
conceal the facets, but if you manage to handle that you could
produce just about any sort of bevel you might desire (though the code
would be simplified if you limited the bevel profile to bijective
mappings from R to R.)
Date: 17 Dec 1999 10:43:24
Message: <385A59FA.65142460@pacbell.net>
Absotutely !
Thank you for your explaination. I think I got about 50% of it and that is
more than I expected after the first glance I took at your reply.
Date: 17 Dec 1999 10:59:02
Message: <385a5dc6@news.povray.org>
>curves.
I have no idea what you just said, but it sounds intelligent, so good luck
with this new project. =)
Date: 17 Dec 1999 11:10:02
Message: <385A602C.B99089BE@pacbell.net>
http://www.math.niu.edu/~rusin/papers/known-math/95/equiv.cls  ???
Date: 17 Dec 1999 13:16:06
Message: <36794A19.5F19F94A@enst.fr>
Ken wrote:
> Greetings,
> text objects ?
> POV-Ray itself.
> Any takers ?
	Wouldn't the object pattern used as an isosurface do that?
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 17 Dec 1999 13:20:04
Message: <385a7ed4@news.povray.org>
The proximity pattern would handle rounded edges.  The object pattern
wouldn't work very well as an isosurface, as it's discontinuous and
piecewise constant.
