![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was trying out the isosurface in the SuperPatch, when I added a torus to a
long series of formulas. What happened, to my surprise was something I never
expected. I got this error message:
error: Too long function - parser is bored
There must be some of Ken's AI resident within it... I knew it!
So people, can this be solved, or will I just have to live with shorter
functions? BTW, here's the one I used:
{(x^4 + z^4 + y^4 + 2*x^2*z^2 + 2*x^2*y^2 + 2*z^2*y^2 - 2*(r0^2+r1^2)*x^2 +
2*(r0^2-r1^2)*z^2 - 2*(r0^2+r1^2)*y^2 + (r0^2-r1^2)^2)
(sqrt(x^2+z^2)-.6)
(sqrt(y^2+z^2)-.6)
((x-x1)*(x-x2) & (z-z1)*(z-z2) & (y-y1)*(y-y2) + (sqrt(x^2+(y-3)^2+z^2)-1))
((x-i1)*(x-i2) & (z-k1)*(z-k2) & (y-j1)*(y-j2) + (sqrt((x-3)^2+y^2+z^2)-1))
((x-l1)*(x-l2) & (z-n1)*(z-n2) & (y-m1)*(y-m2) + (sqrt((x+3)^2+y^2+z^2)-1))
((x-u1)*(x-u2) & (z-w1)*(z-w2) & (y-v1)*(y-v2) + (sqrt(x^2+(y+3)^2+z^2)-1))}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 4 Oct 1999 17:50:59 -0400, TonyB <ben### [at] panama phoenix net> wrote:
You might be able to break it up like this, though I haven't tested it.
#declare torus=function {(x^4 + z^4 + y^4 + 2*x^2*z^2 + 2*x^2*y^2 + 2*z^2*y^2 -
2*(r0^2+r1^2)*x^2 + 2*(r0^2-r1^2)*z^2 - 2*(r0^2+r1^2)*y^2 + (r0^2-r1^2)^2)}
#declare box1=function{((x-x1)*(x-x2) & (z-z1)*(z-z2) & (y-y1)*(y-y2) +
(sqrt(x^2+(y-3)^2+z^2)-1))}
#declare box2=function{((x-i1)*(x-i2) & (z-k1)*(z-k2) & (y-j1)*(y-j2) +
(sqrt((x-3)^2+y^2+z^2)-1))}
#declare box3=function{((x-l1)*(x-l2) & (z-n1)*(z-n2) & (y-m1)*(y-m2) +
(sqrt((x+3)^2+y^2+z^2)-1))}
#declare box4=function{((x-u1)*(x-u2) & (z-w1)*(z-w2) & (y-v1)*(y-v2) +
function {torus(x,y,z)*box1(x,y,z)*box2(x,y,z)*box3(x,y,z)*box4(x,y,z)*
(sqrt(x^2+z^2)-.6) * (sqrt(y^2+z^2)-.6)}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron, you moron, you can't use the word torus. It's reserved.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <37f930ce@news.povray.org> , "TonyB"
I was wondering when someone would find this limit. In isofunct.c change the
define of FUNCT_MAX_STACK_LEN 256 at the top to some larger value, but be
aware that it may never have been tested with a higher limit - 256
instructions on the function stack is not that much for a default.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You mean you knew and didn't say anything?! :O
It must have been set at that size for a reason. Perhaps to save memory?
>256 instructions on the function stack is not that much for a default.
You mean that they used a low number and that regular programmers would have
used a larger number to begin with? Bastards! >%O
Oh, well, thanks for the suggestion on recompiling, but I don't have
anything but DJGPP and I don't want to run POV in DOS. :|
PS: Please take all smileys/emoticons as ;)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, that doesn't work. I've tried it before. It refuses to render correctly.
It has to be expressed as one continous formula. Might be another bug. If
so, then I have 2 notches on my gun. =)
Thanks anyway for your help, Ron.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 4 Oct 1999 20:55:21 -0400, TonyB <ben### [at] panama phoenix net> wrote:
I knew about it too. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 4 Oct 1999 21:00:14 -0400, TonyB <ben### [at] panama phoenix net> wrote:
I've seen a bug with functions inside macros, but I haven't seen this one.
I'd be interested in any small examples you might have.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Lol! I forgot about that error message. I ran into it when I was experimenting
with making pigments out of functions. I know of no fix to the problem, however.
> functions? BTW, here's the one I used: <snip!>
Samuel Benge
E-Mail: STB### [at] aol com
Website: http://members.aol.com/stbenge
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It looks pretty boring to me :)
Can you not pre-solve some of the equations yourself to reduce the size
of the string ? Calculators are pretty handy devices.
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
