POV-Ray : Newsgroups : povray.unofficial.patches : POV+for() Server Time
4 Jul 2026 04:35:23 EDT (-0400)
  POV+for() (Message 21 to 24 of 24)
Subject: Re: POV+for()
Date: 10 May 1999 09:43:10
Message: <3736d45e.0@news.povray.org>
Phil Clute <pcl### [at] tiacnet> wrote:
: I have to admit my experience with C programming is extremely
: limited. I guess I am confused as to what a "macro" is then.
: I assumed that constants were macros. What makes #define a
: macro and #declare not a macro? They seem to serve the same
: purpose.
  A macro identifier is completely replaced by its value. For example:
#define PrintStatus printf("This is the status\n")
  Now you can type something like:
void Function(void)
{ PrintStatus;
  When parsing, the compiler substitutes the macro, so it converts it to:
void Function(void)
{ printf("This is the status\n");
  Povray #declared identifiers do _not_ work this way. For example, you can't
make this:
#declare MyTexture=texture { pigment { rgb 1 } }
sphere { 0,1 MyTexture }
  Povray does _not_ substitute the identifier "MyTexture" with its value, ie.
the result is _not_ this:
sphere { 0,1 texture { pigment { rgb 1 } } }
  Instead, povray will issue an error:
error: No matching } in sphere, texture identifier found instead.
  However, #macros work in povray exactly like #defines in C. You can make
this:
#macro MyTexture() texture { pigment { rgb 1 } } #end
sphere { 0,1 MyTexture() }
and it will work.
  You can make this same thing in C:
#define MyTexture() texture(whatever)
and when you type "MyTexture()" it will be substituted with
"texture(whatever)" (of course the parenthesis are obsolete here). You can
also give arguments the the #defined macro, just like to the povray
#macro.
  A better naming for the commands would be, for example, #let instead
of #declare and #define instead of #macro (although #macro is ok). Of
course it's too late now.
Date: 10 May 1999 17:14:35
Message: <37373FA1.9685D7BD@tiac.net>
Oh so that's why! I've tried to do exactly that, and that's the
error message I got.
Thanks
Phil
Date: 10 May 1999 17:27:21
Message: <3737429F.876797E8@tiac.net>
I was just looking through textures.inc and I found this:
#declare Shadow_Clouds =
texture {                          // The blue sky background for the
clouds
    pigment { rgb <0.196078, 0.6, 0.8> }
    finish { ambient 0.7 diffuse 0 }
texture {                          // The upper part of the clouds
    pigment { FBM_Clouds }
    finish { ambient 1.0 diffuse 0 }
texture {                          // The darker underside of the clouds
    pigment { FBM_Clouds  translate -0.15*y }
    finish { ambient 0.6 diffuse 0 }
This gives the error message you said it would, so I wonder why it's in
there?
Date: 11 May 1999 04:31:17
Message: <3737dcc5.0@news.povray.org>
You have to use texture identifiers this way:
sphere { 0,1 texture { MyTexture } }
