POV-Ray : Newsgroups : povray.unix : Compiling with icc 12.1 Server Time
1 Sep 2024 07:24:11 EDT (-0400)
  Compiling with icc 12.1 (Message 1 to 10 of 26)
Subject: Compiling with icc 12.1
Date: 15 Dec 2011 03:35:00
Message: <web.4ee9affcb974ef0dd19b0ec40@news.povray.org>
Running Debian 7. I can get Povray 3.7 to compile with gcc 4.6. I'm having
issues with icc 12.1 however.
Libraries
checking whether to link with cygwin DLL... no
checking whether to enable static linking... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for boostlib >= 1.37... yes
checking whether the Boost::Thread library is available... no
configure: error: cannot find a suitable boost thread library
Probably some configure option I'm missing. Halp!
Subject: Re: Compiling with icc 12.1
Date: 15 Dec 2011 05:46:56
Message: <4ee9d020$1@news.povray.org>
Am 15.12.2011 09:29, schrieb jhu:
> Libraries
> checking for boostlib>= 1.37... yes
Did you add the path to the boost library to the linker path (LD_PATH or
whatever it's caled)?
IRC there are also some issues with icpc regarding the header files &
runtime libraries it is compatible with.
I guess you did remember to "source" the proper script file to set the
icpc environment stuff, so I won't mention that. (Uh, I just did - sorry
BTW, I'd like to ask two favors of you:
- Can you please take notes of all build problems you encounter, and
possibly how you solved them (either yourself or with the aid of
others)? That would help us improve the INSTALL docs.
- Once you get it to compile, can you please run some extensive testing
with photons scenes (for example the "balcony" and "optics" advanced
sample scenes)? On my Linux system I still get some very obscure
sporadic segfaults with icpc-compiled POV-Ray when rendering photons scenes.
Date: 15 Dec 2011 07:50:03
Message: <4ee9ecfb$1@news.povray.org>
>> having
>> Libraries
From my personal play with icpc, you need to compile a dedicated version
of boost libraries for it (you cannot reuse the one installed for gcc in
/usr/lib : the headers are fine, but the libraries are not)
Then it's only a matter of setting the environment with the icc script
to compile. And it run benchmark in very good time (~130 s vs ~155 s)
More technical details if still needed tonight (about 6 hours away),
once I'm back on the actual system with icc. (but I'm not sure it was in
the 12 serie or not)
Date: 15 Dec 2011 12:38:06
Message: <4eea307e$1@news.povray.org>
Le 15/12/2011 13:50, Le_Forgeron nous fit lire :
Yep, 12.0.5
Had to install in /opt/intel a version of boost (from tar ball, compiled
& installed with icc/icpc)
  $ source /opt/intel/bin/compilervars.sh intel64
  $ ./configure COMPILED_BY="the name which matter"
--disable-io-restrictions --with-boost-libdir=/opt/intel/lib
--with-boost-thread=boost_thread --with-boost=/opt/intel CC=icc CXX=icpc
--disable-debug
--disable-io-restrictions  : just my personal taste.
Date: 15 Dec 2011 13:30:01
Message: <web.4eea3c56dc656ac1d19b0ec40@news.povray.org>
Ok, started compiling boost using icc. There are a bunch of libs that won't
compile, one of which is the thread lib:
[jhu@PhenomIIx6:~/temp/boost_1_47_0/libs/thread/build]$ ~/temp/bo*/bjam
--toolset=intel-linux
....patience...
....found 513 targets...
....updating 6 targets...
common.mkdir ../../../bin.v2/libs/thread/build/intel-linux-linux/debug
common.mkdir
.../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi
common.mkdir
.../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi/pthread
intel-linux.compile.c++
.../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi/pthread/thread.o
.../../../boost/smart_ptr/detail/shared_count.hpp(321): error: copy constructor
for class "boost::detail::shared_count" may not have a parameter of type
      shared_count(shared_count && r): pi_(r.pi_) // nothrow
.../../../boost/smart_ptr/detail/shared_count.hpp(321): error: expected a ")"
....etc, etc.
If I use the gcc toolset, it compiles just fine. Halp!
Date: 15 Dec 2011 13:36:52
Message: <4eea3e44$1@news.povray.org>
Am 15.12.2011 19:28, schrieb jhu:
> .....patience...
> .....found 513 targets...
> .....updating 6 targets...
> common.mkdir
> ..../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi
> common.mkdir
> ..../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi/pthread
..../../../bin.v2/libs/thread/build/intel-linux-linux/debug/threading-multi/pthread/thread.o
> ..../../../boost/smart_ptr/detail/shared_count.hpp(321): error: copy constructor
>        shared_count(shared_count&&  r): pi_(r.pi_) // nothrow
> ..../../../boost/smart_ptr/detail/shared_count.hpp(321): error: expected a ")"
> .....etc, etc.
Try an earlier version of boost (1.45 is recommended).
Date: 15 Dec 2011 14:04:58
Message: <4eea44da$1@news.povray.org>
Le 15/12/2011 11:46, clipka nous fit lire :
> scenes.
Done more than one hundred renders of optics.pov, with icpc 12.0.5, no
problem. (ulimit -c unlimited, no core dumped.)
 (i=0;  while [ $i -le 100 ]; do povrayicpc optics.pov -w800 -h600
+a0.3; i=$i+1; done )
Date: 15 Dec 2011 14:35:01
Message: <web.4eea4b6cdc656ac1d19b0ec40@news.povray.org>
> Yep, 12.0.5
> --disable-debug
Aarrrgh!
Ok, just downloaded boost 1.45, compiled with icc, installed into /opt/intel.
I run the command you gave (copy and paste) and...
Libraries
??? I don't understand why it can't find the libraries when I've explicitly
stated where they are?
Date: 15 Dec 2011 16:22:33
Message: <4eea6519@news.povray.org>
Le 15/12/2011 20:33, jhu nous fit lire :
>> Yep, 12.0.5
>> --disable-debug
> Aarrrgh!
> Libraries
IIRC, the build of boost might not build everything by default.
my listing of /opt/intel/lib:
ia32                           libboost_prg_exec_monitor.so
intel64                        libboost_prg_exec_monitor.so.1.47.0
libboost_chrono.a              libboost_program_options.a
libboost_chrono.so             libboost_program_options.so
libboost_chrono.so.1.47.0      libboost_program_options.so.1.47.0
libboost_date_time.a           libboost_python.a
libboost_date_time.so          libboost_python.so
libboost_date_time.so.1.47.0   libboost_python.so.1.47.0
libboost_exception.a           libboost_random.a
libboost_filesystem.a          libboost_random.so
libboost_filesystem.so         libboost_random.so.1.47.0
libboost_filesystem.so.1.47.0  libboost_regex.a
libboost_graph.a               libboost_regex.so
libboost_graph.so              libboost_regex.so.1.47.0
libboost_graph.so.1.47.0       libboost_serialization.a
libboost_iostreams.a           libboost_serialization.so
libboost_iostreams.so          libboost_serialization.so.1.47.0
libboost_iostreams.so.1.47.0   libboost_signals.a
libboost_math_c99.a            libboost_signals.so
libboost_math_c99f.a           libboost_signals.so.1.47.0
libboost_math_c99f.so          libboost_system.a
libboost_math_c99f.so.1.47.0   libboost_system.so
libboost_math_c99l.a           libboost_system.so.1.47.0
libboost_math_c99l.so          libboost_test_exec_monitor.a
libboost_math_c99l.so.1.47.0   libboost_thread.a
libboost_math_c99.so           libboost_thread.so
libboost_math_c99.so.1.47.0    libboost_thread.so.1.47.0
libboost_math_tr1.a            libboost_unit_test_framework.a
libboost_math_tr1f.a           libboost_unit_test_framework.so
libboost_math_tr1f.so          libboost_unit_test_framework.so.1.47.0
libboost_math_tr1f.so.1.47.0   libboost_wave.a
libboost_math_tr1l.a           libboost_wave.so
libboost_math_tr1l.so          libboost_wave.so.1.47.0
libboost_math_tr1l.so.1.47.0   libboost_wserialization.a
libboost_math_tr1.so           libboost_wserialization.so
libboost_math_tr1.so.1.47.0    libboost_wserialization.so.1.47.0
libboost_prg_exec_monitor.a
Date: 15 Dec 2011 16:40:00
Message: <web.4eea682ddc656ac1d19b0ec40@news.povray.org>
But it's all there...
[jhu@PhenomIIx6:/opt/intel/lib]$ ls
intel64         libboost_program_options.so
libboost_date_time.a       libboost_program_options.so.1.45.0
libboost_date_time.so       libboost_random.a
libboost_date_time.so.1.45.0      libboost_random.so
libboost_exception.a       libboost_random.so.1.45.0
libboost_filesystem.a       libboost_random.so.1.47.0
libboost_filesystem.so       libboost_regex.a
libboost_filesystem.so.1.45.0      libboost_regex.so
libboost_graph.a       libboost_regex.so.1.45.0
libboost_graph.so       libboost_serialization.a
libboost_graph.so.1.45.0      libboost_serialization.so
libboost_math_c99.a       libboost_serialization.so.1.45.0
libboost_math_c99.so       libboost_signals.a
libboost_math_c99.so.1.45.0      libboost_signals.so
libboost_math_c99f.a       libboost_signals.so.1.45.0
libboost_math_c99f.so.1.45.0      libboost_system.so
libboost_math_c99l.a       libboost_system.so.1.45.0
libboost_math_c99l.so       libboost_system.so.1.47.0
libboost_math_c99l.so.1.45.0      libboost_test_exec_monitor.a
libboost_math_tr1.a       libboost_thread.a
libboost_math_tr1.so       libboost_thread.so
libboost_math_tr1.so.1.45.0      libboost_thread.so.1.45.0
libboost_math_tr1f.a       libboost_unit_test_framework.a
libboost_math_tr1f.so.1.45.0      libboost_unit_test_framework.so.1.45.0
libboost_math_tr1l.a       libboost_wave.a
libboost_math_tr1l.so.1.45.0      libboost_wave.so.1.45.0
libboost_prg_exec_monitor.a      libboost_wserialization.a
libboost_prg_exec_monitor.so      libboost_wserialization.so
libboost_prg_exec_monitor.so.1.45.0  libboost_wserialization.so.1.45.0
