POV-Ray : Newsgroups : povray.unix : ltiff.so can't be found on installed POV-Ray 3.5 Server Time
28 Sep 2024 22:18:01 EDT (-0400)
  ltiff.so can't be found on installed POV-Ray 3.5 (Message 1 to 10 of 11)
Subject: ltiff.so can't be found on installed POV-Ray 3.5
Date: 20 Apr 2003 22:30:04
Message: <web.3ea3568ff888b44f76b67fde0@news.povray.org>
I just finished compiling and installing POV-Ray 3.5c for Unix on a Solaris
8 box, and I get this error:
$ povray
ld.so.1: povray: fatal: libtiff.so: open failed: No such file or directory
Killed
I know I have libtiff.so in the /usr/lib directory. How can I tell POV-Ray
that?
MidnightLightning
Subject: Re: ltiff.so can't be found on installed POV-Ray 3.5
Date: 21 Apr 2003 10:53:45
Message: <3ea405f9@news.povray.org>
There's something odd with libtiff anyways, so you might want to link
libtiff.a statically into the povray binary (this is what I have to do
every time I compile POV-Ray for Solaris).
  That is, in the linking command replace "-ltiff" with
"/the/path/to/libtiff.a".
  By the way, if you write "echo $LD_LIBRARY_PATH" what does it say?
Date: 22 Apr 2003 00:20:04
Message: <web.3ea4c269ffae30776b67fde0@news.povray.org>
echo $LD_LIBRARY_PATH produces a blank line. I can add the -L switch to the
Makefile, but since the src directory has been 'make'd already, it won't
re-compile the packages with the new Makefile. Is there a flag to force the
make command to re-compile the packages?
Date: 22 Apr 2003 00:38:14
Message: <Pine.GSO.4.53.0304220036310.3641@blastwave>
No need to link statically :
ldd src/povray_64bit
        libtiff.so =>    /opt/csw/lib/sparcv9/libtiff.so
        libjpeg.so.62 =>         /opt/csw/lib/sparcv9/libjpeg.so.62
        libpng.so.3 =>   /opt/csw/lib/sparcv9/libpng.so.3
        libz.so.1 =>     /usr/lib/sparcv9/libz.so.1
ldd src/povray
        libtiff.so =>    /opt/csw/lib/libtiff.so
        libjpeg.so.62 =>         /opt/csw/lib/libjpeg.so.62
        libpng.so.3 =>   /opt/csw/lib/libpng.so.3
        libz.so.1 =>     /usr/lib/libz.so.1
Dennis
Date: 22 Apr 2003 05:43:37
Message: <3ea50ec9@news.povray.org>
  That's why ld can't find libtiff.so at runtime.
  You don't need to recompile, just to relink. Delete the povray binary
and run make.
Date: 23 Apr 2003 12:45:12
Message: <web.3ea6c1f4ffae307f3b9b4a70@news.povray.org>
>and run make.
I deleted the file 'povray' in the src directory, and ran 'make' for that
directory again, which created a new 'povray' file, but that one had the
same linking errors. Are you sure that's the correct procedure?
Date: 23 Apr 2003 15:21:18
Message: <3ea6e7ad@news.povray.org>
  Did you replace "-ltiff" with "/path/to/libtiff.a" as I said?
Date: 23 Apr 2003 22:05:10
Message: <web.3ea74582ffae30776b67fde0@news.povray.org>
Yes, here's the result. Here's it without a -l or -L switch in front of it.
With the -l switch, it gets a similar error.
$ make
c++  -Wno-multichar -O3 -finline-functions -ffast-math -fomit-frame-pointer
-funroll-loops -fexpensive-optimizations -foptimize-sibling-calls
-Wno-multichar  -o povray  atmosph.o bbox.o bcyl.o benchmark.o bezier.o
blob.o  boxes.o bsphere.o camera.o chi2.o colour.o colutils.o cones.o csg.o
 discs.o express.o file_pov.o fncode.o fnintern.o fnpovfpu.o fnsyntax.o
fpmetric.o fractal.o function.o gif.o gifdecod.o hcmplx.o hfield.o
histogra.o iff.o image.o interior.o isosurf.o jpeg_pov.o lathe.o  lbuffer.o
lightgrp.o lighting.o matrices.o media.o mesh.o normal.o  objects.o
octree.o optin.o optout.o parse.o parsestr.o parstxtr.o  pattern.o pgm.o
photons.o pigment.o planes.o png_pov.o point.o poly.o  polygon.o polysolv.o
pov_mem.o povms.o povmscpp.o povmsend.o povmsrec.o  povray.o pov_util.o
ppm.o prism.o quadrics.o quatern.o rad_data.o  radiosit.o ray.o render.o
renderio.o sor.o spheres.o sphsweep.o  splines.o statspov.o super.o targa.o
texture.o tiff_pov.o tokenize.o  torus.o triangle.o truetype.o txttest.o
userdisp.o userio.o vbuffer.o  vlbuffer.o warps.o unix.o povxlib.o
-L/home/boydb/downloads/jpeg-6b -L/usr/lib -L/usr/local/lib -ljpeg
/usr/local/lib/libtiff.a -lpng -lz -lm  -lX11
$ povray
Killed
with a -L switch it does:
 povxlib.o  -L/home/boydb/downloads/jpeg-6b -L/usr/lib -L/usr/local/lib
-ljpeg -L/usr/local/lib/libtiff.a -lpng -lz -lm  -lX11
Undefined                       first referenced
 symbol                             in file
TIFFGetField                        tiff_pov.o
TIFFGetFieldDefaulted               tiff_pov.o
TIFFOpen                            tiff_pov.o
TIFFSetErrorHandler                 tiff_pov.o
TIFFClose                           tiff_pov.o
TIFFComputeStrip                    tiff_pov.o
TIFFReadRGBAImage                   tiff_pov.o
TIFFReadEncodedStrip                tiff_pov.o
TIFFGetVersion                      optout.o
TIFFScanlineSize                    tiff_pov.o
TIFFStripSize                       tiff_pov.o
TIFFSetWarningHandler               tiff_pov.o
ld: fatal: Symbol referencing errors. No output written to povray
collect2: ld returned 1 exit status
*** Error code 1
make: Fatal error: Command failed for target `povray'
each time I remove the povray file and the povray.o file before running
'make' again
Date: 24 Apr 2003 06:40:10
Message: <3ea7bf0a@news.povray.org>
> $ povray
  Are you sure you are running the binary you just compiled?
  In unix it's always a good idea to run "./povray" when you want to run
the one in the current directory.
Date: 24 Apr 2003 14:42:41
Message: <pan.2003.04.24.18.41.58.864707@ntlworld.com>
shouldn't that be a small l, i.e.
-l/usr/local/lib/libtiff.a
Dave
