POV-Ray : Newsgroups : povray.unix : jpeg_pov.o Server Time
23 Dec 2024 09:24:13 EST (-0500)
  jpeg_pov.o (Message 1 to 10 of 19)
Subject: jpeg_pov.o
Date: 15 Apr 2003 12:30:07
Message: <web.3e9c3265e2cf3f11894657c10@news.povray.org>
I'm in the process of compiling POV-Ray 3.50c to run on a Solaris 8 SPARC
station, and I've gotten through several errors, but this one's stumping
me:
From the /povray/src/ directory:
$ make
roll-loops -fexpensive-optimizations -foptimize-sibling-calls -Wno-multichar
 -opovray  atmosph.o bbox.o bcyl.o benchmark.o bezier.o blob.o  boxes.o
bsphere.o camera.o chi2.o colour.o colutils.o cones.o csg.o  discs.o
express.o file_pov.o fncode.o fnintern.o fnpovfpu.o fnsyntax.o  fpmetric.o
fractal.o
function.o gif.o  gifdecod.o hcmplx.o hfield.o  histogra.o iff.o image.o
interior.o
isosurf.o jpeg_pov.o lathe.o  lbuffer.o lightgrp.o lighting.o matrices.o
media.o
mesh.o normal.o  objects.o octree.o optin.o optout.o parse.o parsestr.o
parstxtr.o
pattern.o pgm.o photons.o pigment.o planes.o png_pov.o point.o poly.o
polygon.o polysolv.o pov_mem.o povms.o povmscpp.o povmsend.o povmsrec.o
povray.o
pov_util.o ppm.o prism.o quadrics.o quatern.o rad_data.o  radiosit.o ray.o
render.o
renderio.o sor.o spheres.o sphsweep.o  splines.o statspov.o super.o targa.o
texture.o tiff_pov.o tokenize.o  torus.o triangle.o truetype.o txttest.o
userdisp.o
userio.o vbuffer.o  vlbuffer.o warps.o unix.o povxlib.o  -ltiff -lpng -lz
-lm  -lX11
Undefined                       first referenced
 symbol                             in file
jpeg_set_quality                    jpeg_pov.o
jpeg_write_scanlines                jpeg_pov.o
jpeg_destroy_decompress             jpeg_pov.o
jpeg_start_compress                 jpeg_pov.o
jpeg_read_scanlines                 jpeg_pov.o
jpeg_finish_decompress              jpeg_pov.o
jpeg_start_decompress               jpeg_pov.o
jpeg_destroy_compress               jpeg_pov.o
jpeg_resync_to_restart              jpeg_pov.o
jpeg_std_error                      jpeg_pov.o
jpeg_CreateDecompress               jpeg_pov.o
jpeg_set_defaults                   jpeg_pov.o
jpeg_CreateCompress                 jpeg_pov.o
jpeg_read_header                    jpeg_pov.o
jpeg_finish_compress                jpeg_pov.o
ld: fatal: Symbol referencing errors. No output written to povray
collect2: ld returned 1 exit status
*** Error code 1
make: Fatal error: Command failed for target `povray'
I have installed jpegsrc.v6b, so I don't know where else to find the various
jpeg libraries it seems to be looking for. Additionally, why is it 'povray'
that's erroring out, not the jpeg_pov.o file?
Any suggestions would be appreciated!
MidnightLightning
Subject: Re: jpeg_pov.o
Date: 15 Apr 2003 14:48:15
Message: <pan.2003.04.15.18.47.33.970592@ntlworld.com>
On Tue, 15 Apr 2003 13:27:23 -0400, MidnightLightning wrote:
> -ltiff -lpng -lz -lm  -lX11
For a guess no -ljpeg ??
Date: 16 Apr 2003 10:15:08
Message: <web.3e9d649c7dc5196ff3b9b4a70@news.povray.org>
Hmm, don't know if this is a better or worse error message:
$ make
c++  -Wno-multichar -O3 -finline-functions -ffast-math -fomit-frame-pointer
-funroll-loops -fexpensive-optimizations -foptimize-sibling-calls
-Wno-multichar  -o povray  atmosph.o bbox.o bcyl.o benchmark.o bezier.o
blob.o  boxes.o bsphere.o camera.o chi2.o colour.o colutils.o cones.o csg.o
 discs.o express.o file_pov.o fncode.o fnintern.o fnpovfpu.o fnsyntax.o
fpmetric.o fractal.o function.o gif.o gifdecod.o hcmplx.o hfield.o
histogra.o iff.o image.o interior.o isosurf.o jpeg_pov.o lathe.o  lbuffer.o
lightgrp.o lighting.o matrices.o media.o mesh.o normal.o  objects.o
octree.o optin.o optout.o parse.o parsestr.o parstxtr.o  pattern.o pgm.o
photons.o pigment.o planes.o png_pov.o point.o poly.o  polygon.o polysolv.o
pov_mem.o povms.o povmscpp.o povmsend.o povmsrec.o  povray.o pov_util.o
ppm.o prism.o quadrics.o quatern.o rad_data.o  radiosit.o ray.o render.o
userdisp.o userio.o vbuffer.o  vlbuffer.o warps.o unix.o povxlib.o  -ltiff
-lpng -ljpeg -lz -lm  -lX11
ld: fatal: library -ljpeg: not found
ld: fatal: File processing errors. No output written to povray
*** Error code 1
It seems in the first one it was able to find a JPEG library, but it wasn't
complete, but in this one, there is no such thing as a -ljpeg library.
MidnightLightning
Date: 16 Apr 2003 10:29:31
Message: <3e9d68cb@news.povray.org>
  You either don't have libjpeg.so (or libjpeg.a) installed on your system,
or it's not in the search path of the compiler.
  If it's the latter case, you need to add a -L/path/to/the/directory
where libjpeg.* is located to the linking command.
Date: 16 Apr 2003 10:30:26
Message: <3E9D6902.6090006@free.fr>
> *** Error code 1
	Since you said you installed yourself the libjpeg library,
I assume you did so in a directory you can write to (for instance
somewhere in your home directory). In order to let the linker find
this library, setup the LD_LIBRARY_PATH environment variable, e.g.:
(csh-like)
setenv LD_LIBRARY_PATH /home/you/path/to/libjpeg
or
(sh-like)
export LD_LIBRARY_PATH=/home/you/path/to/libjpeg
	Then try linking again.
	This environment variable should also be set for running the
program if you linked it with dynamic libraries.
	Hope this helps,
	- NC
Date: 16 Apr 2003 10:33:18
Message: <3e9d69ae@news.povray.org>
"MidnightLightning" <nomail@nomail> wrote in message
news:web.3e9d649c7dc5196ff3b9b4a70@news.povray.org...
> $ make
csg.o
lbuffer.o
polysolv.o
targa.o
> *** Error code 1
wasn't
> MidnightLightning
I've had problems similar to this when compiling on linux.  It looks as if
you either have no libjpg files or the libjpg-devel files are not in place.
I realize you are not compiling for linux, but as both systems are unix
vaariants, maybe this will give you some place to start.
-->Jeff
Version: 6.0.471 / Virus Database: 269 - Release Date: 4/10/2003
Date: 17 Apr 2003 21:50:05
Message: <web.3e9f599b7dc5196f76b67fde0@news.povray.org>
>(sh-like)
> Hope this helps,
> - NC
I'm using sh shell; should that command run in command line or from the
Makefile? I tried it on command line and got:
$ export LD_LIBRARY_PATH=/home/boydb/downloads/jpeg-6b/
LD_LIBRARY_PATH=/home/boydb/downloads/jpeg-6b/: is not an identifier
That folder has libjpeg.a in it. Should that line be added to the Makefile?
If so, I'm not familiar enough with the language it's written in to figure
that one out.
Date: 17 Apr 2003 21:55:14
Message: <web.3e9f5a2f7dc5196f76b67fde0@news.povray.org>
It is installed, I found it in one of my directories, and tried adding the
-L switch to the command, but got:
# make
-lpng -lz -lm  -lX11 -L/home/boydb/downloads/jpeg-6b/libjpeg.a
etc, etc, etc, same errors as before.
Did I put that in the correct place, or can you better explain where to put
it in the Makefile?
Date: 18 Apr 2003 06:46:15
Message: <Pine.GSO.4.53.0304180640070.11053@blastwave>
You're doing this for Sun Solaris right?
  You should not need to do anything fancy with LD_LIBRARY_PATH.  That will
  only help you during runtime if your libraries are in strange non-standard
  places.  The simple thing to do is :
  1 ) go get the source code for the latest jpeg libs, and get png and zlib
      and tiff while you're at it.  Compile them all in a directory called
      povray-3.50c/src/lib/png povray-3.50c/src/lib/jpeg etc etc.  Then ensure
      that the linker knows where these guys are with the correct linker
      option like -R~foo/povray-3.50c/src/lib/bar
  2 ) Go to http://www.blastwave.org and get the complete package for Solaris.
      Unless you have the Forte 6 Update 2 compiler set and all the slick
      development tools then your home-built version of POV-Ray will never be
      particularly fast.  It has been well demonstrated in the past that gcc
      just simply can not create binaries that are as effectively optimized
      as the Sun/Forte compilers.
  Dennis Clarke
  dcl### [at] blastwaveorg
Date: 18 Apr 2003 09:49:44
Message: <pan.2003.04.18.13.49.03.221452@ntlworld.com>
> it in the Makefile?
You're no quite there, you need -L/home/boydb/downloads/jpeg-6b and
-ljpeg
Note that the -L/home... needs to be before the -ltiff -png etc and it
is a path to the directory the library is in, not the library, and it may
or may not require a trailing /, but more than likely not.
Dave
