POV-Ray : Newsgroups : povray.unix : Can't build 3.5 on Solaris Server Time
31 Oct 2024 08:15:38 EDT (-0400)
  Can't build 3.5 on Solaris (Message 1 to 7 of 7)
Subject: Can't build 3.5 on Solaris
Date: 27 Aug 2002 12:35:06
Message: <web.3d6ba9c6214dff84c6303c790@news.povray.org>
Hi folks,
I am having problems compiling the povray 3.5 executable from source on
Solaris8
It barfs with the following messages;
g++  `if [ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -static
-I/usr/include -o povray  atmosph.o bbox.o bcyl.o benchmark.o bezier.o
blob.o boxes.o bsphere.o camera.o chi2.o colour.o colutils.o cones.o csg.o
discs.o express.o file_pov.o fncode.o fnintern.o fnpovfpu.o fnsyntax.o
fpmetric.o fractal.o function.o gif.o gifdecod.o hcmplx.o hfield.o
histogra.o iff.o image.o interior.o isosurf.o jpeg_pov.o lathe.o lbuffer.o
lightgrp.o lighting.o matrices.o media.o mesh.o normal.o objects.o octree.o
optin.o optout.o parse.o parsestr.o parstxtr.o pattern.o pgm.o photons.o
pigment.o planes.o png_pov.o point.o poly.o polygon.o polysolv.o pov_mem.o
povms.o povmscpp.o povmsend.o povmsrec.o povray.o pov_util.o ppm.o prism.o
quadrics.o quatern.o rad_data.o radiosit.o ray.o render.o renderio.o sor.o
spheres.o sphsweep.o splines.o statspov.o super.o targa.o texture.o
tiff_pov.o tokenize.o torus.o triangle.o truetype.o txttest.o userdisp.o
userio.o vbuffer.o vlbuffer.o warps.o unix.o povxlib.o -L/usr/lib/sparcv9
-R/usr/lib/sparcv9 -ltiff -ljpeg -lpng -lz -lm  -lX11
Undefined                       first referenced
 symbol                             in file
socket                              /usr/openwin/lib/libX11.a(x11trans.o)
getpeername                         /usr/openwin/lib/libX11.a(x11trans.o)
xdrmem_create                       /usr/openwin/lib/libX11.a(ConnDis.o)
dlclose                             /usr/openwin/lib/libX11.a(x11trans.o)
gethostbyname                       /usr/openwin/lib/libX11.a(x11trans.o)
setsockopt                          /usr/openwin/lib/libX11.a(x11trans.o)
getservbyname                       /usr/openwin/lib/libX11.a(x11trans.o)
XSolarisIASetProcessInfo            /usr/openwin/lib/libX11.a(OpenDis.o)
authdes_create                      /usr/openwin/lib/libX11.a(ConnDis.o)
inet_addr                           /usr/openwin/lib/libX11.a(x11trans.o)
shutdown                            /usr/openwin/lib/libX11.a(x11trans.o)
getsockname                         /usr/openwin/lib/libX11.a(x11trans.o)
dlsym                               /usr/openwin/lib/libX11.a(x11trans.o)
dlopen                              /usr/openwin/lib/libX11.a(x11trans.o)
connect                             /usr/openwin/lib/libX11.a(x11trans.o)
ld: fatal: Symbol referencing errors. No output written to povray
collect2: ld returned 1 exit status
make[1]: *** [povray] Error 1
make[1]: Leaving directory `/home/ks122413/src/povray-3.50a/src'
make: *** [all-recursive] Error 1
Any clues would be appreciated!
Thanks
Subject: Re: Can't build 3.5 on Solaris
Date: 27 Aug 2002 14:34:30
Message: <3d6bc636@news.povray.org>
First of all: I know bugger all about solaris, so don't come crying to
me when this makes you machine explode ;-)
Seems like the linker can't find a library: try including
'-L/usr/openwin/lib/' (or whereever libX11 is located) and maybe add
some other needed library paths for png peg and tiss libraries in the
same way.
If it is having problems finding the libs at runtime after this (do ldd
on the binary ) add -static to the lastcommand and try again.
Good luck,
Rob
Date: 27 Aug 2002 16:41:13
Message: <3d6be3e9@news.povray.org>
  No. That's exactly the flag he should remove in order to get povray
compiled. It won't compile with it.
Date: 27 Aug 2002 16:41:28
Message: <3d6be3f8@news.povray.org>
Remove -static
Date: 27 Aug 2002 20:43:39
Message: <3d6c1cbb$1@news.povray.org>
In article <3d6be3e9@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Excuse the stupid question, but why?
    Thorsten
e-mail: tho### [at] trfde
    Thorsten
Date: 27 Aug 2002 22:28:01
Message: <3d6c3531@news.povray.org>
  The standard Solaris distribution doesn't have static X-libraries
(ie. the .a-files), only dynamic ones (ie. the .so-files). The linking
error is produced because the linker can't find the static libraries,
even though it was ordered to use them.
Date: 28 Aug 2002 05:40:03
Message: <web.3d6c9a3f95bcdc39c6303c790@news.povray.org>
Thanks, that makes sense.
I'll give it a try later on tonight and let you know what happens.
Cheers,
Sek
