POV-Ray : Newsgroups : povray.unix : povray-3.50c Redhat 9 RPMs Server Time
28 Sep 2024 22:13:02 EDT (-0400)
  povray-3.50c Redhat 9 RPMs (Message 1 to 5 of 5)
Subject: povray-3.50c Redhat 9 RPMs
Date: 4 Dec 2003 06:57:29
Message: <pan.2003.12.04.11.57.29.569776@lionsanctuary.net>
I've created a src.rpm and an i386.rpm for Povray 3.50c that works under
Redhat 9 (with X; if there's some demand I'll make a -nox version too).
However, due to liscensing concerns (concern: it's 4 am, I'm not reading
the bloody liscence right now!) I'm not keen on posting the povray team's
IP publicly.
(a) Would posting links to the two RPMs be permissible?
(b) Is there some way I can submit the files to the povray team so they
can distribute them themselves?
Cheers,
Owen
Subject: Re: povray-3.50c Redhat 9 RPMs
Date: 4 Dec 2003 12:16:24
Message: <1l64a1-b1s.ln1@triton.imagico.de>
> IP publicly.
This would not be different from any other unofficial version, you are
free to do so but have to make sure it qualifies as a full package
(including docs and sample scenes) and clearly indicate the unofficial
nature.
You can be sure the POV-Team recognizes when you post a link but you
should note that there will not be support for an unofficial version by
the Team.  I also think most current linux distributions already include
POV-Ray 3.5.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 4 Dec 2003 14:47:25
Message: <pan.2003.12.04.19.19.07.691341@lionsanctuary.net>
> nature.
The RPM contains everything from the povuni_s.tgz file, including docs and
sample scenes; rebuilding it to explicitly add "unofficial" to the .spec
should take a whole ten minutes. . . done.
> the Team.
Obviously.
> I also think most current linux distributions already include POV-Ray 3.5.
I thought so too; the only RPMs I could find on rpmfind for 3.5 were for
SuSE, though, which may or may not work with any other distribution.
The RPMs are available at:
 <http://machinae.lionsanctuary.net/2003/12/povray-3.50c-1.src.rpm>
 <http://machinae.lionsanctuary.net/2003/12/povray-3.50c-1.i386.rpm>
Date: 5 Dec 2003 04:48:41
Message: <n1l0tvg9th7fi67m0k8cljmkq35orq7oon@4ax.com>
On Thu, 04 Dec 2003 11:47:25 -0800, Owen Jacobson
Maybe post this in povray.news-submissions, this way it might go in
the news secton on www.povray.org
Peter Popov ICQ : 15002700
Date: 5 Dec 2003 23:19:29
Message: <pan.2003.12.06.04.19.28.835106@lionsanctuary.net>
> <old urls snipped>
The release number has gone up one and the new RPMs are signed with my GPG
key (available off of pgp.mit.edu) in light of the recent rash of
repository breakins.
Redhat 9 RPMs for Povray 3.50c:
 <http://machinae.lionsanctuary.net/2003/12/povray-3.50c-2.src.rpm>
 <http://machinae.lionsanctuary.net/2003/12/povray-3.50c-2.i386.rpm>
If someone could verify whether these work on recent SuSE/Mandrake/other
distributions, I would be much obliged.
