POV-Ray : Newsgroups : povray.unix : 64-bit version of POV-Ray 3.50c is bigger, slower, and still not mt Server Time
28 Jul 2024 04:21:58 EDT (-0400)
  64-bit version of POV-Ray 3.50c is bigger, slower, and still not mt (Message 1 to 3 of 3)
Subject: 64-bit version of POV-Ray 3.50c is bigger, slower, and still not mt
Date: 15 Apr 2003 03:24:10
Message: <Pine.GSO.4.53.0304150320340.21927@blastwave>
The stats are in from www.blastwave.org on the initial build of a 64-bit ver
of POV-Ray 3.50c as a 64-bit binary with 64-bit libraries :
bash-2.03$ file povray_64bit
povray_64bit:   ELF 64-bit MSB executable SPARCV9 Version 1, UltraSPARC1
Extensions Required, dynamically linked, stripped
bash-2.03$ file povray_sun
povray_sun:     ELF 32-bit MSB executable SPARC32PLUS Version 1, V8+ Required,
UltraSPARC1 Extensions Required, dynamically linked, not stripped
Done Tracing
Statistics for
/export/home/dclarke/build/sparc/povray-3.50c_sparc_v9plusa/scenes/interior/crystal.pov,
Resolution 640 x 480
Pixels:          307200   Samples:          789970   Smpls/Pxl: 2.57
Rays:           3289254   Saved:            312403   Max Level: 5/5
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                           10910839         2399089     21.99
Sphere                        21821678        15917882     72.95
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:         23801964   Succeeded:              4526945
Reflected Rays:            1249642
Refracted Rays:            1249642
Smallest Alloc:                 10 bytes   Largest:          1228808
Peak memory used:          1626734 bytes
Time For Trace:    0 hours  3 minutes  54.0 seconds (233 seconds)
    Total Time:    0 hours  3 minutes  53.0 seconds (233 seconds)
real 233.83
user 219.51
sys 13.65
the 64-bit version was a little slower ...
Time For Parse:    0 hours  0 minutes   1.0 seconds (1 seconds)
Time For Trace:    0 hours  4 minutes   5.0 seconds (245 seconds)
    Total Time:    0 hours  4 minutes   6.0 seconds (246 seconds)
real 246.18
user 231.91
sys 13.65
Dennis Clarke
dcl### [at] blastwaveorg
Subject: Re: 64-bit version of POV-Ray 3.50c is bigger, slower, and still not mt
Date: 15 Apr 2003 11:16:51
Message: <3e9c2263@news.povray.org>
  As I explained in the other thread... :)
Date: 16 Apr 2003 19:21:04
Message: <Pine.GSO.4.53.0304161903360.23914@blastwave>
  yes .. but a 5% difference is no big deal in speed for the ability to use
more ram.  Sun servers, unlike the intel world, commonly have greater than 4Gb
of RAM and 16Gb to 32Gb of RAM is no big deal out of the box for a V880 with
eight CPUs.  I plan to test POV-Ray with a large render on such a machine.  At
the moment I am choked back to 8Gb of RAM in a 280R with dual 900MHz
processors.  What I need now is a scene file with a LOT of very simple
objects, like spheres and cubes, that will chew up all that RAM.  Should make
for a large test.
Dennis
