POV-Ray : Newsgroups : povray.unix : Unix debugging expertise needed Server Time
15 Mar 2026 09:47:04 EDT (-0400)
  Unix debugging expertise needed (Message 1 to 7 of 7)
Subject: Unix debugging expertise needed
Date: 18 Nov 2016 08:44:24
Message: <582f05b8$1@news.povray.org>
Hi folks,
can someone with access to Ubuntu _12.04_ please have a look at this
POV-Ray branch (a pending pull request), see if the binaries crap out on
their machine as well (complaining about "pure virtual method called"
and some stuff about pthread, boost and mutex), and if so, figure out why:
https://github.com/eblanca/povray
Your help would be much appreciated.
Subject: Re: Unix debugging expertise needed
Date: 19 Nov 2016 06:11:29
Message: <58303361$1@news.povray.org>
Le 18/11/2016 à 14:44, clipka a écrit :
> Hi folks,
Can do, have to wait till Monday (guess where it is)
Date: 21 Nov 2016 04:02:05
Message: <5832b80d$1@news.povray.org>
>> Hi folks,
Sorry to disappoint you, but it's working, at least with -D option:
* ubuntu 12.04.5 LTS
* g++ 4.6(.3)
* 64 bits system (x86_64)
-D is due to my local setting (X11 remote display is not setup to allow
this machine to display on my screen)
With +D (or default), I got a core dumped. (but it seems unrelated to
that branch and might be a problem for all branches)
With DISPLAY not defined, it's strange: there is an ascii preview, then
statistic and the telnet/shell is frozen. (yet, probably still the same
for all branches)
unix/povray --benchmark : ok
unix/povray with small scene (3.7, 1 sphere) : ok
Date: 13 Dec 2016 01:35:00
Message: <web.584f9650b6f3f0b2194284cc0@news.povray.org>
> Hi folks,
No access to Ubuntu 12.04, but it does run just fine on Debian/testing and
FreeBSD.
Date: 13 Dec 2016 01:58:08
Message: <584f9c00@news.povray.org>
Am 13.12.2016 um 07:33 schrieb jhu:
> clipka <ano### [at] anonymousorg> wrote:
>> Hi folks,
> FreeBSD.
That's of little help to me. I already know that this thing runs fine on
/some/ systems.
I need someone to get this baby to cry in a controlled environment, to
figure out why it does so in our Travis CI automated build test
environemnt, and ideally find a way to soothe it there.
It might just be afraid of the dark (read: having no terminal
associated, or some such), but at the moment that's just a wild guess.
Date: 13 Dec 2016 20:00:06
Message: <web.5850998db6f3f0b2615a0e20@news.povray.org>
Someone else said it works fine on their Ubuntu 12.04 system. Perhaps it's
specific your particular hardware configuration?
Date: 14 Dec 2016 03:12:36
Message: <5850fef4$1@news.povray.org>
pure virtual called is usually a problem of code vs compiler vs linker.
(child class declared the method, but did not implement it)
It can also be a problem of a fool pointer being interpreted as a
pointer to a class that is not the expected one anymore. (such as to a
deleted instance) and then, it can depend a lot on the actual system
usage about what is found in the memory for that pointer. Memory
problems can be due to race or serialization between cores.
I tried it on 64 bits ubuntu 12.04, with g++ 4.6.3, and 4 cores.
It could also be tied to the subversion of g++ (I cannot update that
system, and maybe 12.04 did not stay at 4.6.3), or 32 vs 64.
