POV-Ray : Newsgroups : povray.unix : PNG and segmentation faults Server Time
27 Jul 2024 18:32:18 EDT (-0400)
  PNG and segmentation faults (Message 1 to 7 of 7)
Subject: PNG and segmentation faults
Date: 27 Nov 2005 09:06:40
Message: <4389bd70$1@news.povray.org>
I've been using POV-Ray under Linux for just a couple of days. I always
save my images as png files. Never encountered a single problem.
Now, just a few minutes ago, after 3 hours of rendering, POV-Ray crashed
with a segmentation fault. Every attempt to render again the scene as a
png image resulted in another segmentation fault. It seems to work fine
with tga.
Any clue what this might be due to?
Jonathan.
Subject: Re: PNG and segmentation faults
Date: 27 Nov 2005 09:18:50
Message: <dmcf4e$m2c$1@chho.imagico.de>
> with tga.
Do you use the official binary or a self compiled version?
If you use a self built version you should try building with the libpng
version coming with POV-Ray and not the one installed on the system.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 27 Nov 2005 09:32:23
Message: <4389c377$1@news.povray.org>
Christoph Hormann wrote:
>> always save my images as png files. Never encountered a single problem.
>> crashed with a segmentation fault. Every attempt to render again the
>> scene as a png image resulted in another segmentation fault. It seems
>> to work fine with tga.
> Christoph
Hmm, I have the feeling it's not something POV-Ray related... Kopete
just keeps on crashing... and here's a snip of the backtrace log I get:
[KCrash handler]
#4  0x41908fdf in __deregister_frame () from /lib/libgcc_s.so.1
#5  0x418e9328 in deflateParams () from /lib/libz.so.1
#6  0x418e83b9 in deflate () from /lib/libz.so.1
#7  0x419f1b00 in png_write_filtered_row () from /usr/lib/libpng.so.3
#8  0x000007f2 in ?? ()
#9  0x41a1c66c in ?? () from /usr/lib/libpng.so.3
#10 0x00000092 in ?? ()
#11 0x0836a390 in ?? ()
#12 0x419f2026 in png_write_find_filter () from /usr/lib/libpng.so.3
Anyway, I'm using a pre-compiled version coming with the SUSE 10
distribution.
Jonathan.
Date: 27 Nov 2005 09:53:45
Message: <4389c879$1@news.povray.org>
> distribution.
What version of POV-Ray is included with Suse 10?
	Thorsten
Date: 27 Nov 2005 09:55:58
Message: <4389c8fe$1@news.povray.org>
Thorsten Froehlich wrote:
>> distribution.
>     Thorsten
"Persistence of Vision(tm) Ray Tracer Version 3.6.1 (g++ 4.0.2 @
  i686-pc-linux-gnu)
This is an unofficial version compiled by:
  SUSE LINUX Products GmbH, Nuernberg, Germany
  The POV-Ray Team(tm) is not responsible for supporting this version.
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins
Copyright 1991-2003 Persistence of Vision Team
Copyright 2003-2004 Persistence of Vision Raytracer Pty. Ltd."
Jonathan.
Date: 27 Nov 2005 10:48:49
Message: <dmcka1$ne1$1@chho.imagico.de>
JRG wrote:
> [KCrash handler]
If two programs have trouble with libpng/zlib things seem quit clear to me.
> distribution.
Which surely is dynamically linked against the system libpng.  Fix your
libs or build your own using the libraries coming with POV-Ray and you
will be fine.
If your system libpng is broken it is astonishing though that you don't
experience a lot of other problems.
Date: 27 Nov 2005 11:07:48
Message: <4389d9d4$1@news.povray.org>
Yep...
> will be fine.
"Support libraries used by POV-Ray:
   ZLib 1.2.3, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
   LibPNG 1.2.8, Copyright 1998-2002 Glenn Randers-Pehrson
   LibJPEG 6b, Copyright 1998 Thomas G. Lane
   LibTIFF 3.7.3, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI"
(Don't you find I'm the laziest person on earth?)
Hmm... never experienced a single crash in a month. Until now that is...
maybe I'll just try and reboot first...
Jonathan.
