POV-Ray : Newsgroups : povray.unix : linux video encoder Server Time
28 Oct 2024 14:20:12 EDT (-0400)
  linux video encoder (Message 1 to 10 of 19)
Subject: linux video encoder
Date: 16 Jun 2005 18:15:35
Message: <42b1fa07@news.povray.org>
Any recs for apps to turn a stack-o-bitmaps into an MPG?
Apparently TMPGENc requires Win
Subject: Re: linux video encoder
Date: 16 Jun 2005 19:08:16
Message: <42b20660$1@news.povray.org>
"Greg M. Johnson" <gregj;-)565### [at] aolcom> wrote in message
news:42b1fa07@news.povray.org...
mencoder which is a part of mplayer works. It's a little complex, but there
are some examples.
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-enc-images.html
with some success, i was using:
mencoder mf://*.png -mf w=400:h=300:fps=25:type=png -ovc copy  -o output.avi
but i'm not sure what players that would work on. works with mplayer anyway
here's another helpfull site:
http://gentoo-wiki.com/HOWTO_Mencoder_Introduction_Guide
but i had problems with mencoder giving a segmentation fault with anything
other than "-ovc copy". for instance, "-ovc lavc" plus lavc options caused
seg faults.
good luck!
-r
Date: 17 Jun 2005 01:53:06
Message: <42b26541@news.povray.org>
Ross spake:
> there are some examples.
> output.avi
> anyway
> seg faults.
Hmm - I had better luck with .JPEG's:
mencoder \*.jpg -mf on:fps=35 -o output.avi -ovc lavc -lavcopts
vcodec=mpeg4:vhq:v4mv #polar_divx_35_fps_libav.avi
and to add sound (if you have transcode):
transcode -i output.avi -p song.mp3 -P1 -o output_s.avi -y raw
Didn't crash and worked fine.
Stefan Viljoen
Polar Design Solutions
Date: 17 Jun 2005 22:47:52
Message: <42b38b58$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> wrote in message
news:42b20660$1@news.povray.org...
> there
> are some examples.
Screw it.  It's hopelessly confusing as to how to acquire the app-  I have
to compile a bunch of stuff, and it has an inefficient interface-- lots of
typing. So 1990ish.  I'll try TMPGENc and WINE
Date: 18 Jun 2005 00:55:32
Message: <pan.2005.06.18.04.55.31.393233@nospam.com>
You're confusing an "inefficient interface" with a different way of doing
things.  I type about 90 WPM on average, so I find the interface *highly*
efficient, even if I have to --help to get the options I need.  I
personally find *anything* that requires the mouse to be extremely
*inefficient* because I have to take my hands off the keyboard, and that
just slows me down.  (IOW, insert arguement #327 here for CLI vs. GUI -
it's all been said before)
Taking the time to learn *is worth it*.
Depending on which Linux distro you're using, there are precompiled
binaries available.  I don't recall which distro you're using, but I know
with SuSE, I go to http://packman.links2linux.org.  For RedHat, I've used
rpmfind.net a lot to find precompiled packages.
Running something under WINE is likely going to take something of a
performance hit (though that's not always the case, I've run Windows games
under Linux with WINE and actually seen performance *improvements* on the
exact same hardware).
Jim
Date: 20 Jun 2005 11:51:21
Message: <42b6e5f9$1@news.povray.org>
news:42b38b58$1@news.povray.org...
> > there
> > are some examples.
what distribution of linux are you using? like Jim said, lots of precompiled
packages out there. I recently switch to Ubuntu for kicks, a debian based
distribution, and it has packages available. mencoder is a little cryptic at
first and second looks. on my third look at it, I started to understand (not
a surprise because i didn't even try reading the man page for it the first
two attempts).
-r
Date: 20 Jun 2005 23:23:06
Message: <42b7881a$1@news.povray.org>
okay sorry guys.
I'm using kanotix.
I can type reeeallly fast too, but when I'm in a creative stretch, I also do
a whooooole lot of povving.  I end up with hundreds of similarly-sounding
files with long, cryptic file names. Often I only know the filename by
process of elimination among the 10 most recent files.   This
type-things-out just is not an efficient workflow for me.  I apologize if I
took my frustrations out on a forum of people attempting to help me.
news:42b6e5f9$1@news.povray.org...
>> > there
>> > are some examples.
>> have
>> of
> precompiled
> at
> (not
> two attempts).
> -r
Date: 21 Jun 2005 10:58:41
Message: <42b82b21$1@news.povray.org>
news:42b7881a$1@news.povray.org...
> okay sorry guys.
> I'm using kanotix.
do
I
*cringes at the thought of your directories*
you might want to check freshmeat.net or sourceforge.net to see if there are
any GUI front-ends to mencoder.
Date: 21 Jun 2005 12:44:30
Message: <pan.2005.06.21.16.38.20.100019@nospam.com>
Ross' suggestion is a great one - http://www.freshmeat.net is a great
resource.  I also usually search sourceforge (http://www.sf.net), though I
find its search is a bit more difficult to use.
Jim
Date: 21 Jun 2005 12:55:01
Message: <web.42b845f12f8f4c6040d56c170@news.povray.org>
Aside from the GUI issue, I also have to compile what I d/l'ed, correct?
Was stumped there too.
> Jim
