POV-Ray : Newsgroups : povray.unix : s-povray missing from Debian package? Server Time
31 Oct 2024 12:18:36 EDT (-0400)
  s-povray missing from Debian package? (Message 1 to 7 of 7)
Subject: s-povray missing from Debian package?
Date: 3 Dec 2001 14:24:56
Message: <3C0BD1D1.5DDAD6AB@ncsl.dcr.state.nc.us>
Maybe it's just the particular Linux distribution I use (Libranet, built
from Debian) but I don't find the command s-povray anywhere on my
system.   I _can_ run POVray by typing:
povray ... (w/arguments) in either an xterm or at console, but I can't
use the +D option unless I'm in an xterm (or Eterm or rxvt, whatever...)
Does anyone know if it's normal for the deb-packaged POVRay to exclude
the s-povray that can be run with the +D option at a console?  Should I
just purge the Deb package and reinstall from the official povlinux.tgz
--Mark
Subject: Re: s-povray missing from Debian package?
Date: 3 Dec 2001 14:35:03
Message: <3C0BD3FF.7090302@ignorancia.org>
   The s-povray binary is for svga display, I think. Perhaps it is not
bundled on your distro, as it is not much used. If you are using X, the
most common choice is x-povray, which must be surely installed on your
system.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 3 Dec 2001 15:48:08
Message: <3C0BE550.FEC29BDD@ncsl.dcr.state.nc.us>
Yes, I know.  That's what I'm seeking ( I'm trying to run X as little as
possible these days, as there may be something wrong with my ATI Rage
card -- rapid mouse clicking&dragging or intense bursts of keyboarding
can cause EVERYTHING to crash. -- long story, still sussing that problem
out...)
> Perhaps it is not bundled on your distro, as it is not much used. If you are using
X, the
> system.
Yes, but I believe if I explicitly typed "x-povray (+args)"  it would
come back with "command not found" or something to that effect.  The
command 'povray' by itself performs that function, and displays the
image as it renders IF the +D is chosen.
 -- Mark
> La Persistencia de la Ignorancia
Date: 3 Dec 2001 16:20:52
Message: <slrna0nr5m.8pu.ron.parker@fwi.com>
It's possible that they chose not to include it because it has to be
setuid root to work.  As such, it's a security hole big enough to drive a
fleet of aircraft carriers through.
I'm pretty sure s-povray is dead as of 3.5.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 3 Dec 2001 16:29:10
Message: <3C0BEEED.C44BB53@ncsl.dcr.state.nc.us>
Not an issue for a standalone, single-user box that doesn't live on the
'net. ;-)
I guess I just don't understand much about (SVGA) graphics:  why is
there this apparent connection?  There are quite a few apps out there,
if I'm not mistaken, that require 1) SVGA and 2) to be run setuid root.
Yet I can use a console-based graphic file viewer called zgv that can be
run as regular joe-user.
--Mark
Date: 3 Dec 2001 18:10:10
Message: <slrna0o1ik.8r8.ron.parker@fwi.com>
It might use the framebuffer device instead; that's a little newer
and can be used more securely.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 4 Dec 2001 11:47:12
Message: <3C0CFE47.83BA718C@ncsl.dcr.state.nc.us>
I have no idea what that even means (no implicit request for
explanation, unless it's simpler than I realize...)
--Mark
