POV-Ray : Newsgroups : povray.unix : A question about X Server Time
31 Oct 2024 14:09:30 EDT (-0400)
  A question about X (Message 1 to 5 of 5)
Subject: A question about X
Date: 17 Jul 2001 07:39:20
Message: <2m88lt4mnm78ndsvmmah46g3mjlpaq5pcg@4ax.com>
Anyone here working under X? If so, can you tell me how to change the
screen physical resolution (DPI)? Right now I am working at 1024x768
on a 14" monitor. X supposes a resolution of 75x75 DPI (screen size of
35x26 cm, approx.), while it is in fact 100 DPI (26x19 cm). How do I
change it? man xrdb mentions the X_RESOLUTION and Y+RESOLUTION
properties of the root window, but how do I access those?
Peter Popov ICQ : 15002700
Subject: Re: A question about X
Date: 17 Jul 2001 08:15:16
Message: <3B542C4B.8F2559D3@sycomore.fr>
I've done that. For the exact same reasons.
Using XFree 3.x, I had to put it as a command-line argument
to the X Server (-dpi 100). I had a lot of trouble to find
in which file to put this (the X startup procedure make use
of several nested scripts), and in fact, I don't remember!
Hope's not lost, however, since I've kept a backup of
*that* file before upgrading to Slackware 8. So, you'll
have to wait until I get back home and check.
Meanwhile, you can use it manually. Try:
	startx -- -dpi 100
Using XFree 4.x and a recent monitor, everything is
automatic! The monitor is able to tell the X server
its physical dimensions, and the server computes
the value. That's cool.  :-)
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Date: 17 Jul 2001 14:56:16
Message: <3B54A7A4.8000903@home.nl>
> 	startx -- -dpi 100
But try first if it works, becuase I've a new videocard a new monitor
and XFree 4, but my XFree 4 refuses to get any information from my
monitor. There are tools to get those information by hand. Try them if
it works try to install X4
Remco
Date: 17 Jul 2001 18:08:52
Message: <m366crdx7l.fsf@bach.composers>
Indeed. However adding the line
        DisplaySize  365        274
where the two numbers are the horizontal and vertical screen size (in
mm), respectively, to the Monitor section should also do the trick. If
the monitor won't tell the size automatically, X defaults to these
values instead (the dpi is calculated automatically).
Of course, with this method you need to measure the view area, but a
soft ruler will easily do the trick. :-)
Ole Laursen
http://sunsite.dk/olau/
Date: 18 Jul 2001 05:05:53
Message: <3B555168.98858321@sycomore.fr>
Found it. Edit <x11r6>/lib/xdm/Xservers (where <x11r6> is
a directory that holds configuration about XFree -- it's
not standard at all) and do the following.
There should be a single line like
	:0 local /usr/X11R6/bin/X
Simply add the switch after it, like in
	:0 local /usr/X11R6/bin/X -dpi 102
> automatic!
Or you can use DisplaySize in your XF86Config,
like Ole said.
