POV-Ray : Newsgroups : povray.text.scene-files : foreach macro Server Time
17 Jun 2024 02:42:03 EDT (-0400)
  foreach macro (Message 21 to 30 of 30)
Subject: Re: foreach macro
Date: 27 Apr 2021 07:55:00
Message: <web.6087fa65d564bfd479819d986cde94f1@news.povray.org>
hi WFP + TOK
"jr" <cre### [at] gmailcom> wrote:
rename 'm_l10' to, say, 'mFoo', and it just works.  well, the parser's still "at
it".  :-)  something to do with the actual name!
regards, jr.
Date: 27 Apr 2021 10:00:00
Message: <web.6088185ed564bfd479819d986cde94f1@news.povray.org>
> hi WFP + TOK
was rushed, earlier.  just did another quick test just with names.  I thought
there might be a limit on the number of identifiers with some identical prefix,
but it isn't so straightforward; may try other stuff nearer weekend (if still
"aktuell").
regards, jr.
Script started on Tue 27 Apr 2021 14:46:10 BST
jr@swift:8:foreach$ c### [at] namebugpov
#version 3.8;
global_settings {assumed_gamma 1}
#include "foreach_d.inc"
#declare A = array [1] {1};
#macro mac_01(i_,n_)
  #debug concat("macro 01",".\n")
#macro mac_02(i_,n_)
  #debug concat("macro 02",".\n")
#macro mac_03(i_,n_)
  #debug concat("macro 03",".\n")
#macro mac_04(i_,n_)
  #debug concat("macro 04",".\n")
#macro mac_05(i_,n_)
  #debug concat("macro 05",".\n")
#macro mac_06(i_,n_)
  #debug concat("macro 06",".\n")
#macro mac_07(i_,n_)
  #debug concat("macro 07",".\n")
#macro mac_08(i_,n_)
  #debug concat("macro 08",".\n")
#macro mac_09(i_,n_)
  #debug concat("macro 09",".\n")
#macro mac_10(i_,n_)
  #debug concat("macro 10",".\n")
#macro mac_11(i_,n_)
  #debug concat("macro 11",".\n")
#macro mac_12(i_,n_)
  #debug concat("macro 12",".\n")
#for (i_, 1, 12)
  Foreach(A, dictionary {.Macro: concat("mac_",str(i_,-2,0))})
jr@swift:9:foreach$ povparse !$
==== [Parsing...] ==========================================================
macro 01.
macro 02.
macro 03.
macro 04.
macro 05.
macro 06.
macro 07.
macro 08.
macro 09.
macro 10.
macro 11.
macro 12.
File 'namebug.pov' line 48: Parse Warning: No objects in scene.
Date: 27 Apr 2021 19:56:24
Message: <6088a4a8$1@news.povray.org>
On 4/27/21 6:52 AM, jr wrote:
> hi,
Played a few minutes with this just now and you can get your original
code to run if you change the tail m_l10 macro to:
#macro m_l10(i_,n_)
   #debug concat("----------> level 10, n = ",str(n_,0,0),".\n")
   #fopen FID "parse_fore.tmp" write
   #write (FID,"#---\n")
   #fclose FID
Though by the time it finishes it's consumed 1.6G or more of memory
after maybe five minutes. My wild guess is all those Parse_String(s) end
up sitting in memory until parsing is finished. In other words I think
at the end we have unrolled more or less the whole recursion.
Parse_String is involved in what's happening, but it's not clear to me,
why - some scope issue maybe as it comes after the last "call" to m_l10.
Bill P.
Date: 28 Apr 2021 09:48:29
Message: <608967ad$1@news.povray.org>
>> hi,
> #macro m_l10(i_,n_)
> #end
OK.
Not 100% sure, in that I've not proven it by making all the
'parse_fore.tmp' names unique, but I believe we are reading (or I
suspect continuing to read) via a now back in scope #include to a common
file with updated, and longer contents written in the previous deeper
scope(1).
If in your include we add two lines to 'empty' the included file after
including / dynamically interpreting the intended string:
#macro fore_exec(s_)
   #local fn_ = "parse_fore.tmp";
   #fopen fp_ fn_ write
   #write (fp_,s_)
   #fclose fp_
   #include fn_
   #fopen fp_ fn_ write  // Making file empty here fixes issue too
   #fclose fp_
The code runs OK.
You ask, "So, this is an issue to which the strings.inc's
Parse_String() macro has always been exposed too?" Yes, I suspect so
though I've not gone back to older versions of POV-Ray to try and
reproduce the issue.
Is it worth further chasing and changing, if this is how v3.8 works
today? I vote NO.
I'm thinking the practical fix is our 'Parse_String()'s should always
empty the file just included.
We should remember too the Parse_String() method is a hack; It's bad
practice to be writing and reading the same file name from multiple
scene 'scopes' or invocations of POV-Ray.
(1) - POV-Ray re-reads files by file positions while working with macros
and includes. What I think you hit on in changing the tail macro name
and finding the code working, was changing to a macro name with the same
(or shorter) length as (all) the earlier ones in the recursion. Meaning
the file position markers didn't change (with respect to the file
contents) in a way causing additional characters to be read from the
'common' parse_fore.tmp file name. This theory can be tested by, say,
changing the m_l10 name to say ml10 - should run?
Bill P.
Date: 28 Apr 2021 10:25:00
Message: <web.60896fa7d564bfd479819d986cde94f1@news.povray.org>
hi,
> #macro m_l10(i_,n_)
>    #fclose FID
> #end
all v strange.  my hunch is that Parse_String is involved indirectly only.  the
exact naming seems to matter, so I wonder what happens when 'm_l10' gets
inserted in the symbol table (cf TOK's error message).  the level of nesting --
thinking of calling it "voluntary recursion" :-) -- is not the problem I think,
attached a scene that nests/recurses to 19 levels, no problems (except time +
memory consumption ;-))  will try and find a little time in next days to play
with different naming "schemes".
regards, jr.
Download 'n19tst.pov.txt' (3 KB)
Date: 28 Apr 2021 10:30:00
Message: <web.608970ccd564bfd479819d986cde94f1@news.povray.org>
hi,
> today? I vote NO.
(sorry, forgot)
agree it's no real problem, will make note in foreach docs that a handful of
levels (ie sane usage) is ok, beyond you take chances.
regards, jr.
Date: 28 Apr 2021 11:25:00
Message: <web.60897df1d564bfd479819d986cde94f1@news.povray.org>
> exact naming seems to matter, ...
took same code as the original 'nesting.pov', changed all macro names to _not_
include numeric digits, and - fine.  hth.
regards, jr.
Date: 8 May 2021 22:55:00
Message: <web.60974e5ed564bfd479819d986cde94f1@news.povray.org>
> posting #4 of 'Foreach()', probably final.
posting a new version, #5.
some of the code has been refactored and tidied up.  many changes were
"cosmetic", there are now no comments within any macro, for instance, and the
layout of the '.Verbose' output has been adjusted.  all this has resulted in a
small, but measurable, improvement in "performance"; the 'n19tst.pov' posted
earlier in this thread went from ~4m7s to ~3m59s, and a "monkeyed" version, with
all comments and blank lines etc removed, saves another 6 seconds or so.
the optional '.Arg' has been .. de-coupled from its dependence on the '.Extra'
flag, providing additional flexibility from here on.
the html "man" page has been updated to reflect all changes, and another
(complete) demo scene has been added.  the 'fore_demo.pov' scene is now
accompanied by the (long) overdue 'fore_demo.ini' file.
feedback on how to make 'Foreach()' better will be appreciated.
enjoy, jr.
Download 'foreach5.zip' (14 KB)
Date: 11 May 2021 17:10:00
Message: <web.609af1dfd564bfd479819d986cde94f1@news.povray.org>
> the html "man" page has been updated to reflect all changes, ...
due to faulty thinking and .. laziness </sigh> I had assumed that the underlying
array is not affected when the current element is modified (in the payload).
wrong.  worse, I wrote in the man page that it's safe to do.  then I ran into
trouble with a trashed array in some scene code + realised.  v sorry.  the
corrected man page is attached.
regards, jr.
Download 'foreach.html.htm' (24 KB)
Date: 13 May 2021 13:25:00
Message: <web.609d5fc6d564bfd479819d986cde94f1@news.povray.org>
a discussion in another thread made me look at various files in the '/scenes/'
directories, with view of updating code to "modern" v 3.8 SDL.
I have attached a zip with a few files, crudely adapted for 'Foreach()' use[*].
 (ideally they'd be re-written such as not to have a new "dependency")
[*] that is existing code surrounded with '#if (0) ... #end', followed by a
functionally equivalent foreach, and '#version' set where needed.
regards, jr.
Download 'foreaches.zip' (19 KB)
