POV-Ray : Newsgroups : povray.text.scene-files : bounding box calculator Server Time
30 Mar 2026 10:51:31 EDT (-0400)
  bounding box calculator (Message 14 to 23 of 43)
Subject: Re: bounding box calculator
Date: 3 Nov 2019 13:00:01
Message: <web.5dbf14f934d8ef064eec112d0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> as I wrote, I'm game for collaboration.  if you can express the spherical
> bounding you're thinking off as "pseudo code" at least, I'm sure we could work
> on something.
So the issues I'm running into currently, are that SDL doesn't have the syntax
needed to replicate statements in python or c++, or POV-Ray simply doesn't have
the ability to perform certain of the operations.
So I need to interpret certain statements to first even understand what they do,
http://news.povray.org/povray.programming/thread/%3Cweb.5db79f027e60be924eec112d0%40news.povray.org%3E/
and then rewrite those parts in a way that can be performed in SDL.
for (std::uint32_t row = 0; row < m_size && (index % 100) == 0; row++)
m[row].resize(m[row].size() + 100);
etc.
That's why I figured using the existing, working, tested libraries in c++,
python, Fortran, Ruby, R, Matlab, etc. would be fastest and most reliable.
I mean I could be wrong, but I think it would pay dividends.
And I still can't understand why the value of the FFT isn't understood.  ALL of
the major graphics packages use FFT for myriad effects, edge detection, etc...
Date: 3 Nov 2019 13:35:00
Message: <web.5dbf1ce734d8ef06feeb22ff0@news.povray.org>
hi,
> > on something.
unfortunately I'll not be much help there, I do not speak c++ nor python.
however, the SDL is Turing complete aiui.  (though too cumbersome for all sorts
of stuff)
> etc.
what is it you're doing that requires a row to grow?
back to the subject on hand.  the problem would be having to scan points on the
surface of a sphere, with some precision/resolution, followed by consecutively
smaller spheres, until "contact".  what did I miss?
regards, jr.
Date: 4 Nov 2019 03:09:16
Message: <5dbfdcac$1@news.povray.org>
Op 03/11/2019 om 16:40 schreef jr:
> hi,
> "Bald Eagle" <cre### [at] netscapenet> wrote:
>>>>> ... I wrote a macro which "scans" an object's BB ...
>>>> find attached an updated version of 'Bounder'.
>> So - those are pretty impressive differences between what POV-Ray does and what
>> you trim it down to!  :O
> agree.  for the Boy's Surface which got me going, the BB went from 11^3 units to
> 8.2^3, a reduction of well over 50%.
>> The methods I suggested are probably too complex to see any implementation any
>> time soon, but maybe if someone who reads and translates c++ or other languages
>> into SDL faster (and more accurately) than I can, converts a script or two -
>> then it would be a powerful tool for this as well as point clouds and other
>> tasks.
>> I doubt they'd be included into source - but I can dream a little.
> on something.
>> I'm curious about how your BB compares to the native one aside from just size.
>> Does it shift?
>> Does the center move?  Is the space on either side equal for all 3 axes?
>> Presumably your bounding box is TIGHT - if you difference away an inverse box,
>> do you get points of overlap / coincident surfaces?
>> I'm just wondering if you ought to include a tiny buffer of 2x10E-6 or whatever
>> the safe distance is on either side, depending on usage.
> the algorithm goes something like this, for each axis:
>    - using the resolution, work out the required axis scan increments.
>    - work along the scan axis until you hit the object:
>      - scan the "face" looking +axis.  if no inside() test succeeded, remember
>        that face as outside.
>      - scan the "face" looking -axis.  as above.
> the advantage is that the last stored coords are always outside of the object.
> the art, I guess, will be finding the lowest resolution "good" for the object.
> (low res like for the Boy's Surface wouldn't work for, say, a model of a sea
> urchin, where one would presumably miss many of the spikes)
>> Maybe have a switch in the macro call to omit or include that buffer space.
> the 'Bounder' is only meant to give you (the user) guide figures, by up to which
> you can tighten the BB if useful.
>> Perhaps an interesting addition would be to add an animation .ini file that
>> rotates the CSG object around an axis by some fraction of 45 degrees and then
>> does the analysis - to see if the _AA_BB gets any smaller.
> that's an interesting thought, re-orienting the object.  need to think about
> that.
>> Pretty nice work, and a striking demonstration of how much empty space an
>> automatically generated bounding box can have.
>> I knew there was some, but:   WOW.
> yeah, Thomas's "reference"-style image did that for me too.  :-)
>> I can see this being really useful for BB dependent operations like scanning
>> with trace (), and probably a few others that I can't clearly envision at the
>> moment.  Basically anywhere that a lot of ray-object intersections need to be
>> tested.
> gut feeling: scenes with a number of CSG shapes with "difficult" materials, like
> glass, will benefit.  also, after a first glance, 'blob' shapes too look like
> good candidates.
A few thoughts derived from this.
- rotating the object changes the 'tightness' of the standard BB. I did
that with a simple cylinder: when properly aligned along one of the
axis, the BB test is always optimal; rotate the cylinder (e.g.
<45,45,45>) and do the test, and the standard BB becomes too wide.
- the test is also useful with hyperboloid, superellipsoid, and
isosurface objects. Quartic and parametric objects do no comply,
probably they are not 'solid'? I did not test this thoroughly.
- I include the test scene file for you to play with.
Download 'utf-8' (9 KB)
Date: 4 Nov 2019 07:30:00
Message: <web.5dc018f534d8ef06feeb22ff0@news.povray.org>
hi,
need to let this info .. stew :-) for a while.  looks like BE's idea of an ini
driven animation to explore the possible orientations and post-process results
is a way to go.
great news.  I'd initially assumed the macro would be a .. single trick pony,
only good for CSG.
thank you v much for this.  not only do I get those natty presentation settings
:-), but looking at the code I surmise you replaced the 'local's of the
difference vectors with 'declare's?  that's given me another idea for an
improvement: create two variables, 'Bounder_{min,max}_diff' and export
('declare') them for in-scene use.  thoughts?
regards, jr.
Date: 4 Nov 2019 07:30:01
Message: <web.5dc018fe34d8ef06feeb22ff0@news.povray.org>
hi,
> > on something.
> > that.
> (*)  Well that's what I was getting at with the ellipsoid and the rotating
> calipers.
> Right now, you can imagine the the bounding box is determined in a very
> hands-off kinda way.   If you took a book that was not axis-aligned, and
> squeezed it with axis-aligned calipers, it would "straighten out" until it was
> aligned with the minimal width parallel to the axis of measurement.
> It has to do with analyzing the orientation of the vectors - the trace ()
> results that you get from your "scan".
off the top of my head, write out the points/vectors to a CSV format file, then
either use your spreadsheet-fu or describe the the necessary actions in kinda
pseudo code so we can discuss whether/how to implement as a script/compiled
utility.
> This goes by many names, but I found Singular Value Decomposition (SVD)
> but I guess there's Principal Component Analysis (PCA), Eigen Value
> Decomposition, etc.  Which can be different but are more or less equivalent and
> are often used interchangeably.
> Over here (1/4 to 1/3 of the way down):
> https://blog.statsbot.co/singular-value-decomposition-tutorial-52c695315254
> he says, "Suppose we have two, two-dimensional vectors, x₁=(x₁,
> y₁), and x₂=(x₂, y₂). We can fit an ellipse with major
> axis, a, and minor axis, b, to these two vectors as shown in the figure."
> And then look here at the 7:00 mark:
> https://www.youtube.com/watch?v=_4jaLZCoLPI
https://www.youtube.com/watch?v=PFDu9oVAE-g&list=PLZHQObOWTQDPD3MizzM2xVFitgF8hE_ab&index=14
quick viewed the vids.  agree with 3Blue1Brown that "confusion" arises from
having a "shaky" understanding of the basics.  :-)  (although a frown would be
more appropriate)
so, anything .. matrix you'd have to work through with me -- bite size.
> "This is crazy, Bill."
> (No it's not, Thomas - the dried frog pills are _working_!!!)
chorus: "Oh no, they're not."  :-)
> Well, yes - and no.  Because I can already see an application to your sphere
> slicing troubles in POV-Ray, the existing root-finding problems that Bill
> Pokorny is grappling with, and SVD.
> If the problem with your sphere slicing arises from root-finding troubles that
> POV-Ray experiences when trying to solve for rays that are parallel, or nearly
> so, to the object surface, then maybe if you added a "wiggle" to the object,
> solved for the root, and then unwiggled the intersection before rendering the
> result - then you'd get better renders with less holes.
I can "see" the concept, and like it.  potential problem: registration, to get
exact re-alignment.
> So if we implemented it in source - them maybe it could be applied to solve a
> lot of long-standing, underlying problems.  Or something like it.
I'm working myself up to trying Bill P's custom POV-Ray soon.  but yes, support
in the program source sounds like the way forward.
regards, jr.
Date: 4 Nov 2019 09:10:00
Message: <web.5dc0308d34d8ef06feeb22ff0@news.povray.org>
d'oh!  finally got the "why".  :-)  with yr permission will add the calculator,
also will adopt the "proper" labelling in existing output.  thanks.
regards, jr.
Date: 4 Nov 2019 14:05:00
Message: <web.5dc0759f34d8ef064eec112d0@news.povray.org>
> is a way to go.
The ini was just to showcase what you've got and point out that the initial
object orientation might not yield the tightest bounding box possible.
As a tool, I'd probably do some sort of iteration with loops, first fixing one
axis, then another, then another, and then checking to see if there's any
improvement on a second go-'round.  If there is, repeat, if not, all done.
> only good for CSG.
Great job Thomas - those results are surprising, given the absolute mathematical
nature of those shapes.
I would have imagined that with something like a parametric, you'd be able to
cycle through u and v real quick, and get a min and max value for each axis to
use for the AABB dimensions.   I'm also still completely mystified as to why the
parametric is such a slow-to-render object, and why the triangle approximation
isn't a source-coded native primitive.
Date: 4 Nov 2019 14:50:06
Message: <web.5dc07fe634d8ef064eec112d0@news.povray.org>
> utility.
From what I can gather, there are several approaches to this, and most of them
are iterative - which makes the spreadsheet thing difficult.
It's been a loooong time since I've written macros for spreadsheets, and the
last mammoth spreadsheet I wrote used _zero_ macros - for "security" (you can't
complain about having to enable macros, can you?) and as a sort of little
challenge.  ;)
> more appropriate)
Yeah, I've been watching Grant's videos for a while, and working through the
matrix stuff and linear algebra bit by bit for a while now.  I think there's
like 14 episodes in the linear algebra series, and if you just pop them on while
you're chilling out for a while, you'll get the gist and figure out which ones
focus on specific parts that make everything clear.   I usually cycle through 2
or 3 at a time and rewatch them so I can start to put it all together.
But like I said - all of the code exists already, so it's mostly a matter of
choosing whether to call it for use as an outside routine where the results are
then used by POV-Ray, finding a way insert the relevant code to perform the SVD
into a POV-Ray fork, or converting the code to SDL where anyone can play with
it.
But since the code is complicated, I'd rather have a reliable library that we
just implement to get the right results, so that if we decide we want to do the
work of converting it, then we can compare the output to what we know is right.
Otherwise debugging will be an unimaginable nightmare.
So I think it's less "understanding what SVD does and how it works" and just
blindly getting the code that does it to work for us.  Once it reliably spits
out the right numbers, then it's a toy/tool to use to learn what and how it does
it - if you want.
I'm envisioning a test scene where we take a unit sphere and scale it by 1/2
along one axis, by 1/3 along another, and then give it a < 45deg rotation around
all three axes.
When we "Undo" the rotations with SVD (which I think is what the eigenvectors
allow us to do), we already know exactly what we should end up with - the axis
aligned, scaled sphere (ellipsoid).
Using the
VRand_On_Sphere(Stream): Returns a random vector on the surface of a unit-radius
sphere located at the origin.
from rand.inc
and applying the scaling and rotations to those points (vectors), we can run the
SVD on that data and see what it does.
No really - TRY SOME.   :D
"Like, dude - if you thought that sRGB with radiosity was good, wait 'till you
see THESE colors...!"   B)
> exact re-alignment.
Well, I wasn't so much worried about that, as with how to integrate such a thing
with the ray-object root solver code.
Take any object, matrix transform it, and then just apply the inverse, and you
get exactly what you started with.
transform { Whatever }
followed by
transform { Whatever inverse }
is the same as doing nothing.
So the idea is sorta like trying to render the side of a cube that juuuuuust
slightly rotated so that you can just barely get a glimpse of the side that
rotated toward you.   Instead of trying to squint or zoom in to get a better
look, just rotate the cube the full 90 deg, get a solid unambiguous view of that
face, and then rotate it back once you KNOW what's there.
Eventually you can push things to the point where you run into rounding and
floating point precision, and propagated error - but that's true with everything
we do now.
Well if you get it installed, give me some tips on how to shoe-horn it onto my
system.  I'm still not so good with the github and compile-it-yourself approach
to software installation.  For most things, I cross my fingers and hope that
there's a package.
Date: 4 Nov 2019 15:45:02
Message: <web.5dc08cf734d8ef06feeb22ff0@news.povray.org>
hi,
> So right now, I'm working off of this:
> and this:
https://www.codeproject.com/Articles/1268576/Singular-Values-Decomposition-SVD-In-Cplusplus11-B
had a quick look, the page appears to give you the lot.
thinking you ought to have a look at the GSL (GNU Scientific Library); I just
found an index entry for singular value decomp.
<https://www.gnu.org/software/gsl/>
regards, jr.
Date: 4 Nov 2019 19:15:00
Message: <web.5dc0be6b34d8ef064eec112d0@news.povray.org>
Right, it looked solid enough to pursue, though it will require a lot of
fiddling to adapt to SDL.
I got that set up, and now need to learn how to use such things.
It appears that I have to write a c++ program and compile it, and then run it.
Looks like this guy has a short program written, where we could just delete or
comment out the Eigen stuff:
https://stackoverflow.com/questions/36959506/eigen-library-svd-is-slow-compared-to-gsl
If you can work something out that runs - tell me what format we need for the
data input - CSV would be nice ;) and then we can see what this thing _does_.
Can we run POV-Ray to #write trace() results to disk, and then call the c++ to
write the SVD data to a file?  Can that c++ program then restart POV-Ray to use
the SVD data? (have an if file exists block to switch between write data and
read data)?
