![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
/* It's possible to create a twisted torus as a parametric isosurface.
What I've done here is to work out a set of parametric equations for
a torus, and then apply a cyclic displacement factor.
The size of the major and minor radii, the number of twists and the
amplitude of the twist displacement are all configurable.
#version unofficial MegaPov 0.5;
camera { location <1, 2, -4> look_at <0, 0, 0> angle 24}
sky_sphere { pigment {
gradient y
color_map { [0.0 color blue 0.6] [1.0 color rgb 1] }
light_source {<100,200,-100> colour rgb 1}
light_source {<-100,-200,-100> colour rgb 0.5}
#declare R1 = 0.6; // major radius
#declare R2 = 0.2; // minor radius
#declare N=6; // Number of twists
#declare A=0.1; // Amplitude of twist
// The parametric description of a twisted torus
// It's just the parameters of an ordinaty torus with an extra term
// tagged on the end of each line that describes the twisty displacement
#declare Fx = function { R2*cos(v)*cos(u) + R1*cos(u)*(1+A*cos(N*u))}
#declare Fy = function { R2*sin(v) + A*sin(N*u) }
#declare Fz = function { R2*cos(v)*sin(u) + R1*sin(u)*(1+A*cos(N*u))}
// Calculate size of the contained_by box
// (adding a slight fudge factor, which needs to be at least 2*accuracy)
#declare Rx = R1 + R2 + A + 0.02;
#declare Ry = R2 + A + 0.02;
#declare Rz = R1 + R2 + A + 0.02;
parametric {
function
Fx(u,v,0), Fy(u,v,0), Fz(u,v,0) // The parametric functions
<0,0>,<2*pi,2*pi> // u and v bopth in the range 0 to 2*pi
<-Rx,-Ry,-Rz>,<Rx,Ry,Rx> // the contained_by box
accuracy 0.0001
precompute 18, [x,y,z]
pigment {rgb 0.9}
finish {phong 0.5 phong_size 10}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <B9h### [at] econym demon co uk>, Mike Williams
It can also be done as a non-parametric equation, like this:
#declare Angle = function {atan2(x, y)*z}
// Angle(CoordinateA, CoordinateB, Frequency)
#declare R0 = 2;//Major radius
#declare R1 = 0.5;//Minor radius
#declare A = 0.2;//Ridge amplitude
#declare NT = 8;//Number of twists
#declare NR = 3;//Number of ridges
#declare twistTorFunc =
function {
sqrt(sqr(sqrt(sqr(x)+sqr(z)) - R0)+sqr(y))
-R1+cos(Angle(x,z,NT)+Angle(sqrt(sqr(x)+sqr(z)) - R0,y,NR))*A
isosurface {
function {twistTorFunc(x,y,z)}
threshold 0
eval
max_gradient 2
contained_by {box {<-3,-1, 0>, < 3, 1, 3>}}
pigment {color rgb <1,1,0.35>}
It's a lot shorter, too. :-)
Christopher James Huff - Personal e-mail: chr### [at] mac com
TAG(Technical Assistance Group) e-mail: chr### [at] tag povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Number of twists are actually NT/NR, which gives you one twist for NT=
X, NR = X
But I found that NT = X, NR = X+1 give you a nice mobius type surface.
Great fun for all concerned, thanks Chris. Now if you would just make us
a nice branching tree IsoSurface...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
