![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi
(Pov-Ray for Windows 3.1a)
I'm trying to pass a pigment (or texture, etc) to a Macro, but I can't get
it to work. The manual seems to indicate that it should be possible. Can
anyone tell me why the first example (below) works, but the second doesn't.
I know that neither do anything very interesting, but that's not the point
Thanks very much
Rob
(rob### [at] manleys freeserve co uk)
// Example 1
#declare MyBox = box {<-5,0,0>,<5,0.25,4>}
#macro StackBoxes ()
#declare Count = 0;
#while (Count < 5)
object { MyBox
pigment {colour rgb <1,0,0>}
translate y*0.25*Count
#declare Count = Count + 1;
#end //while
#end //macro
light_source
0*x
color rgb <1,1,1>
translate <-20, 40, -20>
camera
location <0.0 , 5.0 ,-10.0>
look_at <0.0 , 0.0 , 0.0>
background { color red 0.1 green 0.3 blue 0.8 }
StackBoxes ()
//Example 2
#declare MyColour = pigment {colour rgb<1,0,0>}
#macro StackBoxes (Appearance)
#declare Count = 0;
#while (Count < 5)
object { MyBox
Appearance
#end //while
#end //macro
light_source
0*x
color rgb <1,1,1>
camera
StackBoxes (MyColour)
//END
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 2 Mar 1999 21:58:41 -0000, "Rob Manley"
<rob### [at] manleys freeserve co uk> wrote:
>Hi
>Thanks very much
>Rob
>// Example 1
> #declare Count = 0;
> #while (Count < 5)
> object { MyBox
> #end //while
>#end //macro
>light_source
> 0*x
> color rgb <1,1,1>
>camera
>StackBoxes ()
>//Example 2
> #declare Count = 0;
> #while (Count < 5)
> object { MyBox
> Appearance
> #end //while
>#end //macro
>light_source
> 0*x
> color rgb <1,1,1>
>camera
>//END
In the second example you are passing a pigment identifier without
stating it is a pigment. The POV-Ray diagnostic says it all. This
works;
object { MyBox
pigment { Appearance }
David
dav### [at] cwcom net
http://www.hamiltonite.mcmail.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David Wilkinson wrote in message :
>works;
> object { MyBox
>David
Thanks David, I had it in my head that by declaring the actual parameter as
a full pigment statement, the pigment keyword was not required again in the
macro body.
Rob
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
