POV-Ray : Newsgroups : povray.programming : Interested in CMake support (build system, IDE integration) Server Time
4 Jul 2025 11:06:00 EDT (-0400)
  Interested in CMake support (build system, IDE integration) (Message 1 to 10 of 25)
Subject: Interested in CMake support (build system, IDE integration)
Date: 14 Nov 2013 02:50:01
Message: <web.52848047c0d651edc5155ae40@news.povray.org>
Hi, I read on the recent github page that supporting IDE's (not just MSVC) is
high priority for Povray.
I maintain CMake build-system for Blender and have found it excellent for
MSVC/Eclipse/QtCreator/Netbeans/KDevelop (XCode works well apparently though I
don't use OSX).
This also allows you to use Ninja (rather then gnu-make) which can give very
fast builds.
While the syntax of the CMake is a little strange, overall the build system
works very well in my experience, other projects such as LLVM/Clang, BRL-CAD,
OpenImageIO, OpenShadingLanguage - are using CMake too.
Is it worth me getting CMake setup for Povray? - if you guys are not interested
I would rather not spend time on it.
Subject: Re: Interested in CMake support (build system, IDE integration)
Date: 14 Nov 2013 03:36:51
Message: <52848ba3$1@news.povray.org>
> don't use OSX).
> fast builds.
My 0.02c:
 1. Is the gnu-make broken ? Do not fix unless it's broken.
 2. From experience with eclipse, povray is rather "simple": compile
everything that is relevant and link as a single binary (smart part is
excluding from hierarchy the porting part that are not relevant to the
target)
 3. Fast build: I do not care, I build 6 different version of povray on
my home system (3 compilers(gcc, clang and intel), official and personal
code) and that might happen only once per month or less (but I enjoy
"make -j 15" for the speedup... but that's my system). When I'm in a
loop of compilation, usually it's for a new extension, and make only
recompile what has been touched. (until it reachs my syntax error)
 4. The tricky part is mainly running configure when extracting the
tarball, nothing related to makefile.
Now, the previous points apply to a unix/linux system.
I do not know if the Windows part is happy with the MSVC projects (or
whatever they now named the IDE). But the official one has graphical
interface not available in unix, so factoring on makefile seems futile.
On my linux usage, there is basically a single target for make: generate
the binary. All others secondary target are, to me, mainly irrelevant
(make, make clean and make distclean is basically all I need. Sometime
make check, and make install)
I do not know for the Mac port either, which so far is kindly provided
by Yvo Smellenbergh.
Just because nobody complains does not mean all parachutes are perfect.
Date: 14 Nov 2013 04:55:50
Message: <52849e26@news.povray.org>
Am 14.11.2013 08:49, schrieb ideasman42:
> don't use OSX).
> fast builds.
A much more relevant question here is, are /you/ interested in a CMake
setup for POV-Ray? Would you use it yourself?
If you are, then chances are there's probably someone else out there who
would use it as well.
If you aren't, then chances are you'll lose motivation to maintain it in
the long run.
Setting up make files for a particular build system is just the smallest
part of the job; keeping them alive and kicking over the years for an
ever changing piece of software is the real challenge.
Date: 14 Nov 2013 05:05:02
Message: <web.52849f09dc6ec276c5155ae40@news.povray.org>
> > don't use OSX).
> > fast builds.
> My 0.02c:
gnu-make works fine.
> target)
Yep, CMake can do this, only include paths that are build in the projectfiles,
sometimes I just load in all source though since it can be better for
refactoring not to miss function calls on other platforms --- this may be a bit
personal preference too.
I think you missed my point, Its not that gnu-make is bad, rather using CMake
(which is a meta-buildsystem which generates build files for make/ninja/msvc)
means you're not tied to using one and can get the benefits of other
buildsystems, even though speed may not be an issue its still nice to use a fast
buildsystem in my experience.
Done well, CMake can be used to generate MSVC project files to save you the
hassle of maintaining them and committing them into your source.
Well, I wrote this because I read that IDE support was important but I get the
impression you personally dont think so?
Nevertheless - Just because you may not need all that CMake offers, if nothing
else it still saves you from having to maintain makefiles and msvc project files
(which can be a pain when you consider different versions of MSVC need their own
project files).
IDE support is an added bonus but you can ignore it too if its not interesting
to you.
I rather not try to convince povray devs too much, I just thought I could set
this up over a weekend if you guys are interested - and help maintain a little
until Povray devs get the hang of things.
Date: 14 Nov 2013 06:54:58
Message: <5284ba12$1@news.povray.org>
Am 14.11.2013 11:01, schrieb ideasman42:
While that may well be true, and is probably a big benefit for projects
that have their origins outside the Windows world, it may actually be
counter-productive in a project like POV-Ray where MSVC happens to be
the primary development environment, and where the primary developers
don't have much CMake experience themselves. I see a risk here that it
would create a dependency on external expertise, which in a hobbyist
project cannot be guaranteed to persist.
Now if a CMake setup would be started by someone with enough personal
motivation to carry it through its infancy and push it to a high level
of quality, switching over to CMake as the primary build system might at
some time become a viable and productive option; it's not like
maintaining native MSVC project files is a perfect solution. But if this
would be your only reason to set up a CMake system, then don't do it.
Date: 14 Nov 2013 07:55:01
Message: <web.5284c74bdc6ec276c5155ae40@news.povray.org>
Point taken, I cant argue with this - on the other hand there is no need to drop
MSVC project files instantly either until you are OK with the CMake generated
ones (or never if you prefer not to use them).
The advantage with them is you can easily support many MSVC versions at once,
which IIRC isnt totally simple otherwise, but I dont use msvc.
Yep gradual migration is fine, for blender at one point we have ~5 or so
buildsystems, it was horrible.
- scons
- hand written makefiles
- cmake
- msvc (2 versions)
- autoconf/automake (not sure it ever worked well)
We managed to remove hand written makefiles and MSVC project files and replace
with CMake.
As for weather I would maintain this - well yes, but once its written (and some
developers use it) I expect it wouldnt be the only person having to maintain
anyway-  others notice if it breaks and fix things too, unless you start adding
code new generators and new languages - I expect maintaining would be very
little effort.
Date: 14 Nov 2013 09:14:51
Message: <5284dadb$1@news.povray.org>
Am 14.11.2013 13:51, schrieb ideasman42:
As a matter of fact this happens to be the reason why we dropped support
for VS 2005 and 2008: Nobody of us used those environments as primary
development environment anymore, and the change in project file
structure from 2008 to 2010 was too severe to easily back-port
modifications to the VS2010 project files.
Another thing that's less than perfect is that when changing the
settings for one of the multiple build targets (Win32, Win32-SSE, x64,
Win32-Debug and x64-Debug) or one of the sub-projects (frontend,
backend, gui, etc.) it's easy to forget to update the others along.
> little effort.
Sounds like a fair deal to me.
To go ahead, I would suggest you pull the Git repository, set up the
CMake thing for one particular build environment to start with
(preferably one we're not currently supporting yet, so we have some
benefit right from the start), and once you manage to compile & run
POV-Ray with it, contact Chris on details how to submit it to the
POV-Ray repository. (Using Git for public access to the repository is
brand new to us, so we may need to get used to the workflow.)
Make sure to place everything you add into a separate directory, such as
"./cmake". Inside there, I guess everything is fair game, except that
generated and temporary files should go into (sub-)directories of their
own, to simplify both revision control and finding the output. Maybe one
output directory per build environment would be best.
In case you have questions about the source tree structure or other
project peculiarities, don't hesitate to shout.
Date: 14 Nov 2013 10:35:01
Message: <web.5284ecb0dc6ec276c5155ae40@news.povray.org>
I would guess at some point you go to move to MSVC2012... 2014...  and have the
option to use CMake's project files or to create your own, at that point it may
be easy just to use the generated ones.
> > little effort.
Is there a list of build environments you support? or do you just mean IDE/OS
configuration?
Sounds good.
Ill check on this when I get some free time (weekends probably).
As for output, its common for cmake projects not to do (or allow) in-source
builds, so developers create their own build dir and that references the source
path. makes it very convenient to debug/release intel/clang/gcc... etc compilers
all pointing to the same build.
At first this seemed annoying to me but now I much prefer it since you dont mix
up build files in your source dir.
If others have a strong opinion in-source builds can be supported, but this
isn't really that big of a deal and can be changed later.
Only curious if there is anything thats nonstandard going on or any code
generation.
Date: 14 Nov 2013 11:19:44
Message: <5284f820$1@news.povray.org>
Am 14.11.2013 16:30, schrieb ideasman42:
>>> little effort.
> configuration?
When I say "build environment", I mean the tools available for compiling
and linking.
On Windows we currently provide full support only for MS Visual Studio
2010 with the native VS2010 toolset.
On GNU/Linux we currently provide support primarily for gcc, though icpc
can also be used. clang hasn't been tested yet as far as I know.
An interesting project might be to implement support for some Windows
build environment other than MS Visual Studio, preferably a free one,
with the goal that users can compile their own version of POV-Ray
without having to acquire a license for Microsoft's proprietary software.
In-source builds suck anyway :-P
> generation.
Currently there's no code generation from POV-Ray itself, but some
libraries generate config files as part of their build process (IIRC
this is the case for libtiff and libpng), or even build & run small
software tools to generate code (this is the case for OpenEXR).
For POV-Ray's Windows UI there are two separate DLL projects, one of
which isn't part of the official 3.7.0 release due to licensing issues.
Aside from that it's just compile, link & run.
Ah, and there's a deliberate compile error you will bump into if you
forget to set some preprocessor macros intended to identify the
individual responsible for the (presumably unofficial) build.
Date: 14 Nov 2013 11:50:56
Message: <5284ff70$1@news.povray.org>
On 11/14/2013 07:51 AM, ideasman42 wrote:
<snip>
well I'll watch you efforts with interest ... I'd like to see the
unix/linux build process cleaned up. I tired several times but was never
able to spend enough time with it to make any headway.
