POV-Ray : Newsgroups : povray.programming : render differences in github/head and 3.7 Server Time
24 Mar 2026 10:43:43 EDT (-0400)
  render differences in github/head and 3.7 (Message 1 to 9 of 9)
Subject: render differences in github/head and 3.7
Date: 9 Dec 2015 17:40:49
Message: <MPG.30d277ee641692fa989689@news.povray.org>
So I'm using my custom built povdos on one Windows box and (5) povray-
3.7 on linux.
I notice that
      texture {pigment { Apocalypse} scale 1*inch}
renders differently on povdos.
Should that be the case?  Is github/master/head different than the
release version? This is the question before I decide how to proceed.
I can either build a linux version from head, or switch to a different
texture :) Or maybe you (clipka) want to know more about this.
dik
Subject: Re: render differences in github/head and 3.7
Date: 9 Dec 2015 19:13:59
Message: <5668c3c7$1@news.povray.org>
Am 09.12.2015 um 23:40 schrieb Dick Balaska:
> 3.7 on linux.
> I notice that
The "master" branch on GitHub is indeed different from the latest
release version (that would be the "stable" branch, or the v3.7.0.0
tag), and includes plenty of improvements and bugfixes over the latest
official rlease, so some differences may be intentional, though I'd
indeed need to know more details in order to give you a more specific reply.
If you're worried about the quality of your build, you may want to
compare it to the latest semi-official development build of the master
branch, which can be found at https://github.com/c-lipka/povray/releases.
Also, Linux builds frequently use different mathematical precision than
Windows builds (and there may also be differences between the Windows
plain 32 bit builds on one hand, and the 32 bit SSE2 and 64 bit builds
on the other hand), which in some rare cases might produce noticeable
differences in the output.
That said, there is also a possibility that you've found a bug, and
therefore I do indeed want to know more about this.
Date: 10 Dec 2015 01:04:26
Message: <MPG.30d2dfe8fa9e8fa698968a@news.povray.org>
In article <5668c3c7$1@news.povray.org>, ano### [at] anonymousorg says...
Qu'est-ce que c'est "quality of the build"?
Ah poo.
That Apocolypse pigment was a tiny background object and I wasn't
*really* concerned [1], but I just noticed one of my foreground objects
		pigment {Jade}
		finish {
			ambient 0.3
			reflection 0.05
			diffuse 0.7
			roughness 0.3
		scale 5*inches
looks completely different.  It smells like the povdos version is
ignoring the scale 5*inches.  I definitely have to RCA this.
linux http://www.buckosoft.com/~dick/t/tteo2021.png
vs.
povdos http://www.buckosoft.com/~dick/t/tteo2033.png
[1] you can't even really tell in the video. But I use an ancient ACDSee
to flip lossless png files at 18 fps during development, and there it
was noticable.
Date: 10 Dec 2015 06:20:37
Message: <56696005$1@news.povray.org>
Am 10.12.2015 um 07:04 schrieb Dick Balaska:
What is "Qu'est-ce que c'est"?
(just kidding ;))
What I mean is, apparently you've built that "povdos" version yourself,
so there is a (slim) chance that the reason for the differences you're
seeing are not actually due to differences in the code, but due to
differences in the build settings or the build process itself; in other
words, you might have messed up the build somehow.
> 	texture {
> 		pigment {Jade}
> 		finish {
> 			ambient 0.3
> 			reflection 0.05
> 			diffuse 0.7
> 			roughness 0.3
> 		scale 5*inches
> vs.
Just a hunch, but it might be related to the noise generator.
One thing you could try is to set
    global_settings {
        noise_generator 1 // or 2 or 3
and see if that makes the scene look the same with both versions.
Also, some builds of POV-Ray provide a special optimized implementation
of the noise generator on CPUs that support certain AMD instruction set
extensions. Maybe that optimized noise generator doesn't give the same
results as the canonical one.
Date: 10 Dec 2015 13:25:50
Message: <MPG.30d38d6e326a1d6698968b@news.povray.org>
In article <56696005$1@news.povray.org>, ano### [at] anonymousorg says...
> in other
How dare you sir!
(Open povray.sln. 'F8'  -- How can I mess that up? ;)  You did a fine
job putting that together)
>     global_settings {
Hey that's cool.  I can see it changing the output, but it doesn't help.
I grabbed
povray-3.7.1-alpha.8358383-av65-Win64.7z
and it does generate the same output as my homebrew
       3.7.1-alpha.8353331.unofficial.msvc
So, my path to success is to now build that version of source code for
Linux (groan).
Thanks for your help!
dik
Date: 10 Dec 2015 14:24:11
Message: <5669d15b$1@news.povray.org>
Am 10.12.2015 um 19:25 schrieb Dick Balaska:
>> in other
> How dare you sir!
Glad to hear that :)
>>     global_settings {
> I grabbed
> Linux (groan).
Bu... wha... hey, wait!
Mind giving me the exact details of the texture you're having problems
with? Still want to get down to the heart of the matter.
Date: 10 Dec 2015 16:21:57
Message: <MPG.30d3b6f183db6b0a98968c@news.povray.org>
In article <5669d15b$1@news.povray.org>, ano### [at] anonymousorg says...
I was a little hasty with the 'send' button before because I wanted to
mention I didn't think you'd want such variance between 3.7.0 and 3.7.1
It's the Jade pigment in textures.inc.  I also noticed it with
Apocolypse.
Oddly, I also use Blood_Marble and Blue_Sky3 and those seem fine.
I'm gonna go out on a limb and say this scene gives different results
for all versions of 3.7.0 vs. 3.7.1.
// PoVRay 3.7 Scene File " ... .pov"
// author:  ...
// date:    ...
#version 3.7;
global_settings{ assumed_gamma 1.0 }
global_settings {
#include "textures.inc"
// camera
#declare Camera_0 = camera {perspective angle 75        // front view
                            location  <0.0 , 1.0 ,-3.0>
                            look_at   <0.0 , 1.0 , 0.0>}
camera{Camera_0}
// sun
light_source{< 3000,3000,-3000> color White}
// sky
sky_sphere { pigment { gradient <0,1,0>
                       color_map { [0.00 rgb <0.6,0.7,1.0>]
                                   [0.35 rgb <0.1,0.0,0.8>]
                                   [0.65 rgb <0.1,0.0,0.8>]
                                   [1.00 rgb <0.6,0.7,1.0>]
                       scale 2
// ground
plane{ <0,1,0>, 0
       texture{ pigment{ checker color rgb<1,1,1>*1.2 color rgb
<0.25,0.15,0.1>*0}
                finish { phong 0.1}
//---------------------------- objects in scene ------------------------
// sample sphere
sphere { <0,1.5,0>, 1.00
		pigment {Jade}
Date: 11 Dec 2015 09:06:35
Message: <566ad86b$1@news.povray.org>
Am 10.12.2015 um 22:22 schrieb Dick Balaska:
> Apocolypse.
Not here: Blood_Marble is just as broken. Haven't tested Blue_Sky3 yet,
but I suspect it won't be any good either.
Date: 11 Dec 2015 10:41:40
Message: <MPG.30d4a8d174c2db7698968d@news.povray.org>
In article <566ad86b$1@news.povray.org>, ano### [at] anonymousorg says...
> > Apocolypse.
Yes, I was mistaken. They are both broken as well.
