POV-Ray : Newsgroups : povray.programming : C++ version Server Time
11 Oct 2025 05:09:59 EDT (-0400)
  C++ version (Message 1 to 3 of 3)
Subject: C++ version
Date: 17 Dec 2021 13:31:15
Message: <61bcd773$1@news.povray.org>
Hello, what C++ version does the POV-Ray community want to target for
the future? I see POV_CPP11_SUPPORTED that as far as I were able to
understand is only used to define POVMS_NULLPTR, but older compilers are
supported too anyway.
Is there any reason to continue to support compilers older than C++11?
If we could just assume C++11 (or better, C++17) several sections of the
code could be rewritten to take advantage of new features of the
anguage. For example, I'd start with using constexpr instead of #define
in a lot of cases; kinda of a low hanging fruit, but type checking for
constants is in my opinion worth having in the 2020's.
Subject: Re: C++ version
Date: 23 Dec 2021 23:37:35
Message: <61c54e8f$1@news.povray.org>
This is a question best answered by Christoph Lipka, however I'll add my
(informal) opinion, and that is with 4.0 we're quite open to changes
like this. The main constraint (if it is even a constraint) is the
availability of free, quality compilers that meet the C++11 or C++17
standards on all the platforms that we target.
-- Chris
Date: 6 Mar 2025 02:10:06
Message: <91a97f4e-48bc-4bf2-91a7-8064476043db@daylongraphics.com>
For what it's worth...
Visual Studio 2022 (or VS 17.x if you prefer) works fine, you only have
to do this:
- Modify the BUILT_BY macro and comment out the related #error line in
base/build.h like usual (if you haven't already).
- Comment out the inheritance of std::binary_function for the
NameCompare struct in libraries/openexr/lmImf/mfAttribute.cpp
since std::binary_function is deprecated. Should be near line 65.
- In syspovconfig_msvc.h, add something like this to its list of MSVC
toolchain definitions:
   #elif _MSC_VER >= 1940 && _MSC_VER < 1950
     #define POV_COMPILER_VER                  "msvc143"
     #define METADATA_COMPILER_STRING          "msvc 14.31"
     #define POV_CPP11_SUPPORTED               1
Ray Gardener
