POV-Ray : Newsgroups : povray.programming : z buffer output Server Time
8 Nov 2026 09:29:43 EST (-0500)
  z buffer output (Message 1 to 12 of 12)
Subject: z buffer output
Date: 16 Feb 1999 08:59:34
Message: <36c979c6.0@news.povray.org>
Hi all,
    Does anyone know of a way to output z buffer information along with
rendered images? It needs to be fairly accurate since another program is
going to superimpose realtime 3d shapes which need to interact properly with
the background. Thanks in advance
Subject: Re: z buffer output
Date: 16 Feb 1999 12:00:50
Message: <36c9a442.0@news.povray.org>
Joan Lavoipierre <xdz### [at] dialpipexcom> wrote:
:     Does anyone know of a way to output z buffer information along with
: rendered images? It needs to be fairly accurate since another program is
: going to superimpose realtime 3d shapes which need to interact properly with
: the background. Thanks in advance
  Before somebody answers you with the classical answer "make a gradient
pigment from black to white with ambient finish set to 1 and apply it to the
whole scene in the direction of the camera" let me warn you a bit:
  This is one solution, but it's not an easy one. Also you have to be
careful. If you render the image normally, you will get only 256 z-values,
which isn't enough in most cases.
  Why isn't it easy?
  Usually you have all your scene already textured. You would have to comment
out all the texturing before you can apply the gradient texture to the scene.
If the scene is very complex, this may be a pain.
  If you do this, the easiest way to apply the pigment to the whole scene
may be using the #default directive.
  To get higher accuracy (ie. to get more than 256 values) you have to output
to PNG with color resolution of 16 bits per pixel (so you get 65535 z-values).
  The problem here is how do you read the PNG...
  I don't remember if targa supports 16 bits per pixel.
  I know of no other easy way to do this.
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp -*/
Date: 16 Feb 1999 12:21:38
Message: <36c9a922.0@news.povray.org>
It does support the red/green format that POV understands for height fields.
You'll want to read up on the hf_gray_16 keyword.
Date: 17 Feb 1999 07:46:02
Message: <m3d8399p2c.fsf@clodomir.rezel.enst.fr>
"Joan Lavoipierre" <xdz### [at] dialpipexcom> writes:
> with rendered images?
[I know, I saw Nieminen's post.  But I tried to post this *before* he
posted his thing (and did not manage).  This is a mere solution for
increasing the number of levels in the output, that needs no 16-bit
level.  Ju just use all the 24 bits.]
Colour-code it.  Render a second image with the same objects for which
the texture is changed to something like:
    gradient <grad-vector>
    colour_map {
      [0/256 1/256 colour rgb 0 colour rgb <0,0,1>]
      [1/256 2/256 colour rgb <0,1/255,0> colour rgb <0,1/255,1>]
      [2/256 3/256 colour rgb <0,2/255,0> colour rgb <0,2/255,1>]
      [255/256 256/256 colour rgb <0,255/255,0> colour rgb <0,255/255,1>]
  finish {
    ambient 1
    diffuse 0
If <grad-vector> is correctly set to be parallel to your camera
direction, and if you translate your texture a bit, then you get a
colour depending on the distance from the focal plane.
The given example gives 65536 levels of accuracy.  If you need more,
you just have to fiddle a bit more and add a colour component on the
red channel.  You see the point.
The last trick gives you 24 bit depth, that is 16 million or so.
Should be enough.
Roland.
Roland Mas
- Ogenki desuka, yau de poêle ?
- Genki desu, ture en zinc.
Date: 17 Feb 1999 13:00:50
Message: <m3hfsmzaww.fsf@clodomir.rezel.enst.fr>
    colour_map {
  finish {
    ambient 1
    diffuse 0
Should be enough.
Roland.
Roland Mas
Sauvez un arbre, tuez un castor.
Date: 18 Feb 1999 07:49:20
Message: <36cc0c50.0@news.povray.org>
Which means? Is this phonetic for a normal French saying? Just curious. :-)
Rudy Velthuis
Date: 18 Feb 1999 08:29:16
Message: <m3soc3c02b.fsf@clodomir.rezel.enst.fr>
"Rudy Velthuis" <rve### [at] gmxnet> writes:
> curious. :-)
Nope.  It's just a really old and cheesy French joke that has been
half-translated into Japanese.  I'm afraid I could not translate it
into English.
Sorry,
Roland.
PS: The saying in my signature is a Japanese one.  Translates into: if
it doesn't work when you push, try pulling.
R.
Roland Mas
Oshitemo damedara, hiite mina. -- Proverbe japonais
Date: 18 Feb 1999 15:58:05
Message: <36cc7edd.0@news.povray.org>
Roland Mas schrieb in Nachricht ...
>R.
>Roland Mas
Perhaps the Japanese are right about that, but the other way doesn't work
(pushing instead of pulling). I'm a dentist, I should know.
Rudy Velthuis
Date: 19 Feb 1999 08:28:01
Message: <36cd66e1.0@news.povray.org>
Roland Mas <rol### [at] casimirrezelenstfr> wrote:
:       [0/256 1/256 colour rgb 0 colour rgb <0,0,1>]
:       [1/256 2/256 colour rgb <0,1/255,0> colour rgb <0,1/255,1>]
:       [2/256 3/256 colour rgb <0,2/255,0> colour rgb <0,2/255,1>]
:       [255/256 256/256 colour rgb <0,255/255,0> colour rgb <0,255/255,1>]
  Perhaps you could generate this automatically with #while-loops.
Date: 19 Feb 1999 11:53:44
Message: <36CD9614.47BB@t-online.de>
Joan Lavoipierre wrote:
> Hi all,
I did this once for povray 2.2.
I added a new commandline option, that set a global flag. In the tracing
engine, where the single rays are spawned, I checked after the first
intersection (or a missing intersection), whether the global flag was
set. If z buffer was wanted, I calculated the distance from the
intersection point to the screen pixel. The result was the z-buffer
entry.
I used the RGB value to code a 24bit float (16 bit mantissa, 8 bit
exponent) and returned this new RGB value instead of the color one. With
a little postprocessing (calculating min/max z values, normalizing), I
converted the 24 bit float image into a 16 bit grayscale image.
Unfortunately, I don't have the source any more.
Heiko.
Date: 19 Feb 1999 12:47:00
Message: <m3iucycmln.fsf@clodomir.rezel.enst.fr>
Nieminen Mika <war### [at] cctutfi> writes:
Yeah, sure.  That was just to show the point (it's more explicit to
show the result of the parsing of the loop than to show the loop).
  Anyway, I would not do it with a #while loop, rather with a Perl
program.  If I ever need to write such a program, I guess it could
easily be made universal enough so that it be able to take any POV-Ray
scene file (with the textures and all) and change everything to the
convenient z-buffer texture.  No need to make it by hand!
Roland.
Roland Mas
Sauvez les castors, plantez des arbres.
Date: 22 Feb 1999 05:52:29
Message: <36D1373F.EBB8B65@linux.itam.cas.cz>
But size of color_map is limited.
