POV-Ray : Newsgroups : povray.programming : mixing POV code with C++ Server Time
15 Jul 2025 01:20:07 EDT (-0400)
  mixing POV code with C++ (Message 1 to 10 of 29)
Subject: mixing POV code with C++
Date: 9 Feb 1999 23:15:51
Message: <36C107FA.E5776109@public.uni-hamburg.de>
Hi everyone !
Has anyone tried to mix the official POV source code with self-written
C++ code ?
I am using VC5.0 and the compiler does not even recognize the C++
spezific keywords.
Subject: Re: mixing POV code with C++
Date: 10 Feb 1999 02:28:59
Message: <36c1353b.0@news.povray.org>
Daniel Fenner ha scritto nel messaggio
<36C107FA.E5776109@public.uni-hamburg.de>...
>Hi everyone !
>C++ code ?
>spezific keywords.
The files have a *.c extension, so the compiler disables C++ syntax. Try to
force C++ compilation: I don't know if there is such an option, you can
anyway rename the files from *.c to *.cpp and try.
Hi
Date: 10 Feb 1999 08:37:55
Message: <36c18bb3.0@news.povray.org>
Also, remember to expose you c interface via extern "c" {  <prototypes> }
As an example header, that compiles in both C and C++ for VC5.0:
#ifdef __cplusplus
extern "C"
#endif
// C Interface for TarFileSystemDatabase
void       TF_caseSensitive(int flag);
int        TF_addTarFile(const char *filename);
int        TF_addTarFiles(const char *directory);
FILE         *TF_file(const char *filename,const char *mode);
unsigned long TF_sizeOf(const char *filename);
#ifdef __cplusplus
#endif
Date: 10 Feb 1999 11:55:57
Message: <36c1ba1d.0@news.povray.org>
"Nigel Stewart" <nigels> wrote:
: #ifdef __cplusplus
: extern "C"
: #endif
: #endif
  How can this work?
main(i){char*_="BdsyFBThhHFBThhHFRz]NFTITQF|DJIFHQhhF";while(i=
*_++)for(;i>1;printf("%s",i-70?i&1?"[]":" ":(i=0,"\n")),i/=2);} /*- Warp. -*/
Date: 10 Feb 1999 14:16:20
Message: <36c1db04.0@news.povray.org>
Nieminen Mika schrieb in Nachricht <36c1ba1d.0@news.povray.org>...
>: extern "C"
/* insert: */
>: #endif
>: #endif
>  How can this work?
Then it will work. I've seen this in *all* (Windows-)API header files I've
ever seen.
Subject: Re:Re: mixing POV code with C++
Date: 11 Feb 1999 15:49:35
Message: <36C3426B.32FC9456@public.uni-hamburg.de>
Hi everybody !
First of all : Thanks for the quick response !
some more questions/remarks concerning POV and C++
1)  I guess 'extern "C" {...}' is used to include C headers into C++
files
    (correct me if I am wrong)
    What I need is the opposite : including a C++ header into a C file.
2)  As a work-around I compiled the hole source code as C++. (the option
    for VC5.0 is /TP) I'm not completly happy with this. A lot of things
    had to be changed (prototypes and typecasts mainly) Furthermore the
    linker now produces some unresolved references I can not explain.
    I used /FORCE and had luck :->.
    Does anyone know a 'nicer' way to solve this problem ?
Thanx
      Daniel
Date: 12 Feb 1999 01:39:30
Message: <36C3CD62.D5AEBC35@geocities.com>
Daniel Fenner wrote:
> Hi everybody !
> files
Yes.
Valid C code is Valid C++ code.
'extern "C"' will prevent the name mangling.
Therefore, write the accessing of your C++ stuffs in a standard C way, plus
use the extern "C" around its definitions in your header files that are to
be included in the plain C code.
Of course, it is possible that a slight redesign in your code may be needed,
as C has no clue as to how to handle C++ specifics. That is to say, you
might need to create some kind of C compatible wrapper around your C++
objects, depending on how the latter are structured and used.
(I think this is just an elaboration on what Nigel posted earlier)
Date: 12 Feb 1999 02:25:01
Message: <36c3d74d.0@news.povray.org>
In article <36C3426B.32FC9456@public.uni-hamburg.de> , Daniel Fenner
> files
Some compilers allow to enforce this with a cdecl declaration of a function.
Instead of
void foo();
you would write
void cdecl foo();
However, cdecl is _not_ an ISO C or ISO C++ keyword and might not work with
your compiler.
Hmm, this is strange. Where were these changes required? In the core code or
in the platform specific code? The core code itself should compile without
error using a C++ compiler...if it does not, it would be very interesting
where VC had problems.
    Thorsten
Subject: Re: POV source errors
Date: 12 Feb 1999 03:14:33
Message: <36C3E3A8.E381FEDB@geocities.com>
Just as an aside, when I built the source using VC 5, I get about 710 warnings.
In my experience this is not the best state to leave code in, so what's the
current status on this? (i.e. is it a known and desired state, just something
that needs time to get to, just something to annoy MS compiler users... :-)
Date: 12 Feb 1999 08:17:40
Message: <36c429f4.0@news.povray.org>
On Fri, 12 Feb 1999 00:17:44 -0800, Jon A. Cruz <jon### [at] geocitiescom> wrote:
You only get 710? :)  Most of them are precision warnings, which are really
kind of a nitpicky kind of warning anyway.  I've always just ignored them,
until I can find the time to sit down and fix every single one, or someone
else can.  There's definitely a lot of float->double->float conversions going
on in various places, but fixing them would be quite a chore.
