Help in compiling with Visual C++ 5.0 (Message 1 to 4 of 4)
Subject: Help in compiling with Visual C++ 5.0
Date: 8 May 1998 15:37:16
Message: <35535EEB.DD102ACC@com.pcnet.ro>
If I compile the "pvengine" workshop using Visual C++ 4.0 or 5.0 the
editor tabs with names (for example Messages, Untitled and others) look
distorted.
If I compile it with Borland 5.2 my tabs look very well. What shall I do
to compile it using Visual C++?
Thank you very much for helping me!
Subject: Re: Help in compiling with Visual C++ 5.0
Date: 9 May 1998 07:38:44
Message: <35583f8b.26683458@news.povray.org>
Gabriela Matei <csp### [at] compcnetro> wrote:
>If I compile the "pvengine" workshop using Visual C++ 4.0 or 5.0 the>editor tabs with names (for example Messages, Untitled and others) look>distorted.>If I compile it with Borland 5.2 my tabs look very well. What shall I do>to compile it using Visual C++?>>Thank you very much for helping me!>>
Change the code in PVTEXT.C (function 'initialise_tabbed_window ()' and comment
out the bit that sets the font (it's at the end of the function). That should
fix it (I hope).
Date: 13 May 1998 07:15:40
Message: <355980DB.89429723@aol.com>
It worked for me, and that had been bugging me for awhile. Although I'm not
currently making any additions to POV-Ray, it's nice to finally be able to compile
the source. The only downside is that I did a few tests and the VC++ compile is a
lot slower : (
Now can anyone help me make any sense of this stuff! (hee hee)
-Mike
povray.org admin team wrote:
> Change the code in PVTEXT.C (function 'initialise_tabbed_window ()' and comment> out the bit that sets the font (it's at the end of the function). That should> fix it (I hope).
Date: 31 May 1998 23:10:44
Message: <6kt64f$2o8$1@oz.aussie.org>
Now that you have a compile in Visual C++, it would be easy to split the
final image render into 2 threads so that it takes advantage of dual
processor machines like mine. I would be interested in trying it out for
you. My computer is a dual Pentium Pro 200 and I have been looking for
someone to do a recompile so that POV_Ray runs multi-threaded.
To increase the speed you might want to take a look at the PovPro readme
file. Vadim lists a few things that he identified to speed up the program
execution. If you don't have it, I can send it to you.
remove "not" to e-mail
Stephan
Mike Hough wrote in message <355980DB.89429723@aol.com>...
>It worked for me, and that had been bugging me for awhile. Although I'm not>currently making any additions to POV-Ray, it's nice to finally be able to
compile
compile is a
>lot slower : (>>Now can anyone help me make any sense of this stuff! (hee hee)>>-Mike
