POV-Ray : Newsgroups : povray.pov4.discussion.general : Next Generation SDL Brainstorming Server Time
30 Apr 2024 15:11:58 EDT (-0400)
  Next Generation SDL Brainstorming (Message 83 to 92 of 92)
Subject: Re: Next Generation SDL Brainstorming
Date: 11 Apr 2009 01:00:00
Message: <web.49e022ecad594047722e13220@news.povray.org>
SharkD <mik### [at] gmailcom> wrote:
> I agree with all your points so far. I'd just like to add that I like
> the Lua scripting language because it has a small footprint and comes
> without a lot of baggage. However, some might *prefer* all the baggage
> that comes with a language such as Python.
I've never had a look at Lua - until right now. I guess I'd like it, too.
As a matter of fact, I guess it would serve as the ideal basis for a next
generation SDL:
- It comes with a free parser designed to be integrated into other software.
- It runs on a virtual machine. (someone say "functions" and "rendering-time
execution"!)
- It allows to parse strings into code, and execute it (someone say "macro"!);
or (didn't check but simply expect it) save the code to file for later
execution, like those height field macros do.
- I think the syntax is not ideal, and a few features are missing (like native
vector support); however, with Lua being free open source, nothing hinders us
from modifying the language to suit the needs of POV-Ray.
- It includes a host of features I would want to see in a POV 4 SDL anyway, like
multithreading support (would need to be checked though whether it could
actually benefit from SMP, or whether that would require additional work);
functions returning a list of values; user data types being simulated by
associative arrays, with a special shorthand form to access them.
As a matter of fact, if Lua was a good deal closer to C, I might already be
jumping up shouting "that's our language!"
So maybe the way to go is take Lua as a basis (it seems to have a very well
designed framework), and just modify/extend the language syntax to better suit
POV's needs.
We definitely want vector literals, that's for sure.
Date: 11 Apr 2009 01:05:00
Message: <web.49e024efad594047722e13220@news.povray.org>
> However, a vector is just another type of array that uses a different
> syntax ("<" and ">" instead of "{" and "}"), so there's no real need to
> keep both, technically.
Oh, there is: We can do math with vectors. And we're using them so frequently
that we may want them to be optimized.
Date: 11 Apr 2009 01:20:01
Message: <web.49e027f9ad594047722e13220@news.povray.org>
> > - The scripting language should also be designed so that it's easy to
> >   flexibly read, parse and write data files (as well as handle the data
> >   itself). This would allow writing things like 3DS or OBJ file format
> >   importers as libraries. (This is an example of something which should
> >   definitely be a library rather than a core feature.)
> I agree with this as well. I wrote a parser for Lua once, so I know how
> difficult it can be. Are there any examples of existing languages we can
> compare to that were designed with this aspect in mind?
I think there's no need to have dedicated support for parsing other file formats
in the SDL language syntax itself: A set of library functions should do, I
guess. Which would also mean that there wouldn't be need to implement it right
from the start.
Date: 11 Apr 2009 01:34:55
Message: <49e02bff$1@news.povray.org>
Well, there's good news:
"Lua is implemented as a library, written in C. Being an extension
language, Lua has no notion of a ``main'' program: it only works
embedded in a host client, called the embedding program. This host
program can invoke functions to execute a piece of code in Lua, can
write and read Lua variables, and can register C functions to be called
by Lua code. Through the use of C functions, Lua can be augmented to
cope with a wide range of different domains, thus creating customized
programming languages sharing a syntactical framework."
The compiled bytecode is also indistinguishable from C.
-Mike
Date: 11 Apr 2009 01:39:35
Message: <49e02d17$1@news.povray.org>
> from the start.
No, you got it backwards. The aim is to make POV SDL easy to parse by
other programs. I've already written a Lua parser (specifically, a
pretty-printer for program source code) that anyone is welcome to adapt
if things end up going that way.
-Mike
Date: 11 Apr 2009 02:29:38
Message: <49e038d2@news.povray.org>
  I think you misunderstood what I wrote.
  I said that the SDL itself should be as flexible and expressive as possible
so that it will be possible (and preferably easy) to write file format parser
in SDL.
Date: 11 Apr 2009 02:33:10
Message: <49e039a6@news.povray.org>
  I don't think you understood him. I believe he meant "if Lua was a good
deal closer to C *in syntax*".
Date: 11 Apr 2009 05:45:03
Message: <web.49e065bead59404719d16df90@news.povray.org>
> > from the start.
?? Your statement doesn't parse to me in this context.
The previous post I was referring to proposed that *POV* should be able to parse
*other* formats.
This was plain and clear: .obj and .df3 were explicitly mentioned - which are
file formats, not programs.
Date: 11 Apr 2009 05:45:05
Message: <web.49e06653ad59404719d16df90@news.povray.org>
Exactly.
Date: 11 Apr 2009 14:30:54
Message: <49e0e1de$1@news.povray.org>
>>> from the start.
> *other* formats.
Woops! My mistake.
-Mike
